Question about Dryers
I need a wiring diagram for a hotpoint tumble dryer model vtd00
I replaced the belt on my dryer and i have lost the wiring diagram that i drew out before i disconnected the controls on the facia panel,which consists of a start button, a timer and a low/high heat button, im an electrician by trade and have tried to get it going but i have the connections in the wrong configuration,please help
  • 51 Answers
CALL 1-800-626-2005 ALSO CHECK THEIR WEB PAGE WWW.HOTPOINT.COM
Posted on Jan 16, 2009
The wiring to my hotpoint tumble dryer
You would have had to disassemble the dryer to replace the belt, so the video was correct. The door switch assembly wiring at the front of the dryer mates with a matching connector which you would have separated for cabinet removal. Don't know why you messed with control panel wiring for belt replacement but you can go to www.repairclinic.com and enter tcym 750c to see a list of common replacement parts and maybe a video showing disassembly of a generic Hotpoint dryer. You might be able to get an answer to your wiring question.
Aug 10, 2016 | Hotpoint Dryers
Tip
Whirlpool Dryer Various Test Procedures - Part 1
TEST #1 Supply Connections
This test should only be done after confirming proper voltage at the outlet.
1. Unplug dryer or disconnect power.
2. Remove the cover plate from the back of the dryer.
3. Check that the power cord is firmly connected to the dryer’s wire harness.
4. Access the machine control electronics without disconnecting any wiring to the control board.
5. With an ohmmeter, check for continuity between the neutral (N) terminal of the plug and P8-3 (white wire) on the machine control board. If there is continuity, go to step 6. If there is no continuity, disconnect the white wire of the harness from the power cord. Test the continuity of the power cord neutral wire . If an open circuit is found,
replace the power cord. Otherwise, go to step 6.
6. In a similar way, check the continuity between the L1 terminal of the plug and P9- 2 (black wire) on the control board. If there is continuity, go to step 8. If there is no continuity, check the continuity of the power cord for power cord’s L1 wire. If an open circuit is found, replace the power cord. Otherwise, go to step 7.
7. Replace the main harness.
8. Visually check that the P5 connector is inserted all the way into the machine control electronics.
9. Visually check that the user interface assembly is properly inserted into the front console.
10. If both visual checks pass, replace the user interface assembly.
11. Plug in dryer or reconnect power.
12. Perform the Console Buttons and Indicators Diagnostic test to verify repair.
13. If indicators still do not light, the machine control electronics has failed: Unplug dryer or disconnect power.
Replace the machine control electronics. Plug in dryer or reconnect power. Perform the Console Buttons and Indicators Diagnostic test to verify repair.
TEST #2 Machine Control Power Check
This test is used to determine if power is present at the machine control electronics.
NOTE: The drum light is controlled by the machine control on all models.
2. Open the door.If the drum light illuminates, then power is present at the machine control, and it is functional. Go to TEST #6. If the drum light fails to illuminate, do not assume the machine control electronics needs replacement. Several conditions may cause the drum light not to illuminate, including a bad bulb. If the drum light does not illuminate, go to TEST #1.
TEST #3 Drive Motor Circuit
This test will check the wiring to the motor and the motor itself. The following items are part of this motor system:
Harness/connection Belt/belt switch Drive motor Centrifugal switch Door switch Machine control electronics
2. Access the machine control electronics and measure the resistance across P8-4 and P9-1.
If resistance across P8-4 and P9-1 is in the range of 1 to 6 ohms, replace the machine control electronics.
Otherwise, go to step 3.
3. Check the wiring and components in the path between these measurement points by referring to the appropriate wiring diagram and strip circuit in Section 7.
4. Check the belt switch and drive motor. Access the belt switch and drive motor by removing the front panel/drum assembly. Slowly remove the drum belt from the spring-loaded belt switch tension pulley, gently letting the belt pulley down.
5. Remove the white connector from the drive motor switch.
6. Check for the resistance values of the motor’s Main and Start winding coils. NOTE: Main and Start winding coils must be checked at the motor.WINDING RESISTANCE ω CONTACT POINTS OF MEASUREMENT
MAIN 1.4–2.6 Blue wire in back at pin 4 and bare copper wire on pin 5 of black drive motor switch
START 1.4–2.8 Blue wire in back at pin 4 and bare copper wire on pin 3 of black drive motor switch. If the resistance at the motor is correct, there is an open circuit between the motor and machine control electronics.
Check for failed belt switch. If the Start winding resistance is much greater than 4 ohms, replace the motor.
7. Check the belt switch by measuring resistance between the two blue wires while pushing up the belt switch tension pulley.If the resistance reading goes from infinity to a few ohms as pulley arm closes the switch, belt switch is OK. If not, replace the belt switch. If belt switch is OK and there is still an open circuit, check and repair the wiring harness.
8. Door switch problems can be uncovered in the Door Switch Diagnostic Test; however, if this was not done, the following can be done without applying power to the dryer. Connect an ohmmeter across P8-3 (neutral, white wire) and P8-4 (door, tan wire).With the door properly closed, the ohmmeter should indicate a closed circuit
(0–2 ohms). If not, replace the door switch assembly.
on Apr 11, 2009 | Whirlpool LER4634J Electric Dryer
Hotpoint tcym 750c tumble dryer serial number tcym750c6p. The wires attached to the timer control and start button have disconnected does anyone know how they go back on?
images for Hotpoint tcym 750c tumble dryer wiring
Hotpoint TCYM 750C Style - YouTube
? 3:07
https://www.youtube.com/watch?v=RjQMN6U4PdE
Oct 8, 2012 - Uploaded by Missing Sleep
Hotpoint TCYM 750C Style. Missing Sleep ... How to replacetumble dryer belt Hotpoint, Indesit, Ariston, Creda, Proline etc - Duration: 9:36. by ...
Hotpoint tcym 750c tumble dryer serial number tcym750c6p ...
www.fixya.com/.../t25992053-hotpoint_tcym_750c_tumble_dryer_seria...
48 mins ago - SOURCE: Reconnect wiring on a Hotpoint VTD00 tumble dryer. most electric dryers have a wiring schematic on the back or inside on the back ...
Dec 03, 2015 | Hotpoint Dryers
Rear bearing
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances Need help fixing your appliances
Feb 06, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Cant get top off dryer vtd00
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Jan 17, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
WIRE CONTROL PANEL
Could you please describe the problem you are having?
Oct 16, 2012 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Hotpoint vtd00p thermostat
It could be the thermostat has burnt out or possibly the start capacitor
needs replacing
Aug 30, 2012 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
How to replace belt on samsung dv218ae
Hello & Welcome to FixYa
Please follow the step by step instructions for belt replacement given in this video:
Please get back to me if you have any other questions.
Kevin
Aug 07, 2011 | Samsung DV218AEW Electric Dryer
I have a hotpoint VTD00 tumble dryer and it is heating up but the drum isn't spinning and smells of burning. Thanks, Annmarie
The belt is probably worn out and is slipping,the smell is from the belt slipping on the drum.
Mar 02, 2011 | Hotpoint Dryers
Dryers Logo
855 people viewed this question
Top Dryers Experts
