Question about Bell BE-412CID Corded Phone
412 cid phone
Hi, So many problems...telephone guy was installing another line and I had to turn the phone upside down. 1.The spkr light is now on all the time, and I can't just pick up the handle and be connected to line one. I have to press line 1 and to disconnect i have to press the spkr button. 2.I was set up to hit line 1 then transfer all calls to another line ..no longer works. 3. I can't transfer individual calls anymore.. Can you help me? Thanks Shane
    Novelist:
  • 201 Answers
The picture here is of a Comdial phone I am familiar with but that is not what you are describing. I am not familiar with your specific phone but it sounds like you have the phone in headset mode. There may be a button to turn this feature on/off that was hit by mistake.
Posted on Jul 06, 2007
No manual available to show me howto set speed dial function on my FC 2556 Freedom phone?
kindly download the file via this link:
http://phone.manualsonline.com/manuals/mfg/southwestern_bell/fm2552_1line.html
Southwestern Bell Telephone All Models 2-9193 26955 DKS930 1-Line FC2548 1-Line FF908 900 MHz 1-Line FM144 FM2552 1-Line FM2552/FM2000 FM2552PX FM2560 FM2572 FM4484WW 1-Line FM891B 1-Line FS800 FS900 1-Line FT-412 FT365 GH 3034BL GH 3210 2.4 GHz GH5810 GHz 1-Line
just set the right model if this is not the right one...
---a score of 4 is highly appreciated----- ---if you think this resolution is helpful kindly click on "YES"---- ---you may also leave testimonial----- ---if I help you please help me---
Thank you for choosing fixya
Roger
Sep 02, 2011 | Southwestern Bell Freedom Phone FM2552
How do use my caller id on my kx-t7731 telephone?
Caller ID requires 3 things, service, hardware, and programming. The hardware is a CID card with a part number ending in 93, as in TA62493,82493,TD193 etc. Then system programming in the 900's turn it on for each CO line and the phone needs to be ringing to display CID when the phone rings.
Carl
Apr 21, 2011 | Panasonic KX-T7731 Corded Phone
We have Panasonic KX-T7731 telephones in our office. we have three incoming lines and approx. 7 extensions. the phone co has assured me they've turned on caller id capabilities for all three lines but...
A 3x7 system with 7731 phones tends to show that you have a TA-624/824 series system. CID is delivered to the phones via a xxx93 card and programming. In a 624 it connects to the main board via a ribbon cable and is installed in the system cover. The 82493 cards plug into slots on the main board. Once, or if, the card is installed, it needs to be turned on via programming. At the very minimum, program 900 in system programming turns it on and there are other parameters that you can adjust in the 900's.
Carl
Mar 15, 2011 | Panasonic KX-T7731 Corded Phone
How do i change the recorded message on my voicemail. i cannot find the answer to this question anywhere in my instruction manual. thanks.
Answering system settings
Record your own announcement
Using the telephone base:
Press •/REC while the telephone base is not in use.
Press /CID or /DIR to select Announcement, then press the SELECT softkey.
Press /CID or /DIR to select Mailbox 1 or Mailbox 2, then press the SELECT softkey. The corresponding icon, 1 or 2, flashes on the screen.
The telephone base announces, "Record after the tone. Press 5 when you are done." After the tone, speak towards MIC (microphone) of the telephone base. Press 5 or the STOP softkey when finished recording.
The answering system automatically plays back the newly recorded announcement. Press 5 to stop the playback at any time.
-OR-
Press the MENU softkey when the telephone base is not in use.
Press the SELECT softkey to select Answering sys.
Press (down arrow)CID or (up arrow)DIR to select Mailbox 1 or Mailbox 2, then press the SELECT softkey. The corresponding icon, 1 or 2, flashes on the screen.
Press CID or DIR to select Ans sys setup, then press the SELECT softkey.
Press CID or DIR to select Announcement, then press the SELECT softkey.
The telephone base announces, "To play, press 2. To record, press 7." Press 7 to record and the screen shows Recording announcement ..., or press CANCEL to exit to the previous menu.
The answering system automatically plays back the newly recorded announcement. Press 5 to stop the playback at any time; 2 to replay the recorded announcement; or 7 to record again if desired.
Press CANCEL to exit to the previous menu.
Feb 03, 2011 | Vtech DECT 6.0 Digital Cordless Phone
My att 2 wire keeps flashing red on and off for dsl and then the green wireless light goes off and internet goes down. I get a msg that the broad band cannot connect. I have checked and double checked...
Hi
This is Neo . Check the Filters in the phone line if you have installed the filter . if there is no filters before the telephone , install a filter . Whether the phone line are connected properly and check the wall point where the connection from the DSL and telephones . Check the cords and try changing the RJ11 cords . RJ cors the phone thin cords .
NOTE : FILTERS SHOULD BE INSTALLED FOR TELEPHONES BUT NOT FOR 2 WIRE .
Nov 02, 2010 | 2wire 2700HG-B Router (2700HGB)
Phone will not ring
Try program 81 , you will need the logical ports of the phones you want to make ring
Nov 17, 2009 | Lands Phones
What does New CID=1 mean?
CallerID. CID=1 mean there was one (new) caller ID number recorded by the telephone.
Hope it helps.
Sep 26, 2009 | Uniden 5.8GHz 2-handset with dual-keypad,...
Conference call
To make a Conference Call
1. While on a call, press Cnf/Trn_____.
2. Dial a [DN] (or access an outside line and
dial an external telephone number).
3. Press Cnf/Trn after the called party answers.
All parties are conferenced together.
If you added an outside line to the call, press
Cnf/Trn again before hanging up to allow
the outside parties to continue talking. (If
you do not, the call is disconnected).
Note Some types of outside lines
(“unsupervised”) do not automatically
disconnect when conferenced parties
hang up. In this case, press one of the
flashing buttons to monitor the
conference.
If the parties are still on the line, press Cnf/Trn
+ Spkr, then hang up. When no one is
on the line, press Spkr to disconnect the
lines.
Mar 19, 2009 | Toshiba DKT-2020 Corded Phone
HOW TO CHANGE THE AUTO LINE SELECTION WHEN PICKING UP HANDSET
Sounds like you have two seperate line groups programmed in the system, Program 32 " Automatic Preference " controls the lines the phone will automatically be connected to when the telephone handset is taken off hook or the Spkr button is used.
Apr 24, 2008 | Toshiba DKT-2010 Corded Phone
Conair CID400 Poor Caller ID Display
hi this problem points to 1 main thing: your line voltage is low how many phones are connected on the line? if there are more then 3-4 its too much! you got only 1-2 ? call the phone company and tell them u got a low tone... good luck
Feb 20, 2006 | Conairphone CID 400 (CID400)
Bell BE-412CID Corded Phone Logo
Top Bell Lands Phones Experts
k24674
guyvstewart
ray gallant
Are you a Bell Lands Phone Expert? Answer questions, earn points and help others
