Question about Remote Starter with Keyless Entry
Just put in bulldog remote start
When i plug in the power wire ,it makes a clicking sound and dash lights flash
  • 112 Answers
Have to hit unlock to stop it... and learn tach..
Posted on Jan 26, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
I installed a bulldog RS1100 remote starter. Afterwards when I tried to remote start it the only response I received was the parking lights flashing three times.
Check that the blue wire goes to the -input. If it is then check each of your other wire connections to be sure they are secure and have not slipped.
Dec 14, 2014 | Bulldog Vehicle Parts & Accessories
1999 Durango
try buuldog manufacturer on line help ,possibly needs programming via sequence on remote button
Jan 12, 2014 | DLX 500 Remote Car Starter
When I plug in the red power wires, the module starts clicking
IT IS IN SAFE MODE AND NEEDS TO BE INITIALIZED BY DOING THE FOLLOWING:
If you have a 4 button remote, you must ground the black/blue hood pin wire (raise hood if hood switch is installed). Apply 12volts to blue/black brake wire (press and hold brake pedal if wire is installed). Press and hold any button on your remote until clicking and flashing stops. Unit will now respond to the remote. Remove ground from hood pin wire and voltage from brake wire. If you have a 2 button remote, hold brake and press any button on the remote until clicking and flashing stops.
Dec 27, 2010 | Remote Starter with Keyless Entry
Have model #RS82 installed it on a 2001 Dodge Dakota(no alarms or power windows, did not connect red&black#2,blackwhite#3, &black white #3 wire from the 9 pin harness. After making all connections...
Did you install the hood pin switch? If so, does the blower and dash lights come on when you press the start button on your remote? I have one installed on my 2005 and it works great. I did not install the hood pin switch ( Not the best idea if you take the vehicle to a mechanic for engine repair.) But I shorted the wire as if the hood were closed all the time.
Nov 28, 2010 | Bulldog Remote Starter & T-Harness Kit for...
When i juck the power, parking lights blink
Oct 23, 2010 | Remote Starter with Keyless Entry
I have a 2004 tacoma. Remote starter doesn't work. Dash lights on right side of the dash are dim. Remote starter was pro installed 4 years ago. Any ideas? Thanks
look under dash for the unit, remove the 2 fuses in red jackets wait 2 minute then replace fuses
if you have a 4 BUTTON REMOTE CONTROL:
You will need to take the unit out of safety mode, to do this you will
need to ground the hood pin switch wire, then put your foot on the brake,
next hit any button on the remote and the clicking will stop. Then you will
need to take the hood pin switch wire off of ground and take your foot off
of the brake and see if the remote will work with the unit
if you have a 2 BUTTON REMOTE CONTROL:
need to put your foot on the brake, next hit any button on the remote and
the clicking will stop. Then you will need to take your foot off of the
Dec 15, 2009 | Bulldog Remote Starter & T-Harness Kit for...
Alarm is intermitent on 98 Olds aurora
THERE IS A SHORT IN THE UNIT OR THE WIRING, I WOULD STRONGLY RECOMMEND TAKING IT TO A MACHANIC TO LOOK AT OR REMOVE THE UNIT YOUR SELF, YOU SHOULD JUST BE ABLE TO REMOVE THE 2 FUSES ON THE BIG RED WIRES
Jul 20, 2009 | Bulldog Remote Starter & T-Harness Kit for...
HOW TO PROGRAM REMOTE
unplug the main harness from the unit for 2 min, then plug it back in and press any button on the remote, the parking lights should flash when a new remote is programmed
Apr 26, 2009 | Remote Starter with Keyless Entry
We put a bulldog remote starter in my 2005 chrysler town & country minivan, but when you hit the button it only starts the engine for about 2 seconds then quits. The engine light stays lit until you hit...
Since the vehicle come with the transponder key,(key with security chip inside)You will need to leave a transponder key in the vehicle as close to the ignition as possible(preferably in a hidden location)
Please rate this solution.
Jan 18, 2009 | Chrysler Town & Country Cars & Trucks
Remote Starter with Keyless Entry Logo
313 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
John
John
baire
DROPNDEAL
DROPNDEAL
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
