Question about Desa International CBN20T Heater
The heater won't stay lit
I have a propane wall mount heater and the pilite light stays lite but when you turn it up to kick on the burner lights and will stay lite for a few seconds and kicks off and the pilite light goes out too. Any suggestions on how to fix it, It is only 2 months old. our heater won't stay lit - we hear a click right before it goes out.
  • Anonymous Mar 13, 2014
    When you turn them on the indicator light turns on for a moment, then goes out
  • 51 Answers
CHECK YOUR EXHAUST VENT MAKE SURE THAT IT IS NOT PLUGGED OVER HEATING THE UNIT.ALSO IF IT HAS A FLAME SENSE BAR CLEAN IT AND CLEAN ALL SENSOR OFF.AND MAKE SURE ALL WIRE CONNECTIONS ARE PLUGGED IN TIGHT.
Posted on Jan 16, 2009
2 Suggested Answers
FixFree
  • 12 Answers
SOURCE: the heater won't stay lit
Hi Tiffany,
When a gas applaince goes off it is usually because of a safety precaution. When the unit dies not detect a flame, it will shut off so that it does not fill with gas and cause damage. A flame sensor is a metal toothpick type item that is in the flame area and could be dirty, although it is two months old, this may be another problem.
But if it is charred, you will need to clean it using a soft cloth or even a well used dollar bill. Don't use abrasives, it will take the coating off of the part and cause it to wear faster.
If you are unsure, below is a link to the manufacturers website, you can get the technical information there.
Click here for Heater Manual
Thanks,
Paul
Posted on Jan 28, 2009
I have a nexgrill propane patio heater the pilot light works but when i turn it to lo or high after a minute or so the pilot light stays on but the burner wont light
Propane Patio Heater Troubleshooting - YouTube
? 6:54
www.youtube.com/watch?v=BqYIWuDUZOUDec 12, 2008 - Uploaded by PatioShoppers Great tips about troubleshooting your outdoor patio heater. ...Pilot Light Won't Stay Lit - How to Replace a Broken Thermo Couple on Furnace ...
May 12, 2014 | Williams 2509612 Ceramic Mid-Size Heater
My Delonghi Propane Heater will not stay lit.
this sounds strangely like a safety switch problem , ill bet the device that confirms the pilot lite lit before going to main burner has a problem
Jan 19, 2013 | DeLonghi SafeHeat Heater
Pilot won't stay on
Burners don't have anything to do with the problem of pilot not lighting. Is the problem that flame will not 'stay' lit? Or you can't even get a flame to ignite? If former: possible bad pilot generator or bad gas valve. If latter, possible bad gas valve or no fuel to ignite.
Dec 23, 2012 | Hayward H Series Pool & Spa Heater 400k...
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Heater will light up and then it just cuts off. Pilot stays lit.
thermostat is probably bad if pilot stays lit but burners go out
Oct 27, 2009 | Desa International GWP20T GLOWARM Wall...
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Hi Tiffany,
Thanks,
Paul
Dec 26, 2008 | Desa International GWP20T GLOWARM Wall...
Pilot lights (not always) but gas will not flow into burner
First Clean the ignitor assembly and make sure the flame is reaching the flame sensor strongly.
You may need to replace the flame sensor.
Sep 19, 2008 | Bosch 1600H-LP Liquid Propane AquaStar...
Desa International CBN20T Heater Logo
391 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
