I have a roper washing machine Model # ras8333pqo. water is leaking under the front of the washing machine. It was just a little water, now it in a huge puddle. What is going on.
  • 640 Answers
Defective pump...replace pump
Posted on Jan 17, 2009
Replace Water Pump on Roper Model 8280871
Thanks for posting the solution which helps to solve if anyone has the same problem.
Thanks
Mar 31, 2012 | Washing Machines
I have a roper ras8333pqo. Sometimes the washer will not spin and the motor will sounds as though it is spinning. I rotated the drum. I then closed the lid and it started to spin...is this the coupler? ...
Could be a bad clutch/brake mechanism or a bad coupler.
This video will show how to repair it.
http://www.youtube.com/user/RepairClinic#p/u/0/9K1KHEogf3c
Sep 04, 2011 | Roper RAS8445KQ Top Load Washer
My washing machine is a Roper top load washer. The problem I am having is that the pump from the cold water drain from under the washing machine. Do I need another pump? The hot water will work. I use the...
This model is a direct drive with only one pump, the drain pump. If the drain pump leaks, which is a common problem on these models, it will leak no matter what temperature wash is selected! If you a have a leak on cold, it will probably also leak on warm wash. Your problem is your solenoid operated fill valve on the cold side. Only one fill hose comes off of this combination fill valve to your fill plenum at the top back of your tub. So if it leaks on the cold, but not hot, check for a crack in the plastic housing of the valve on the cold half. The valve is located on the inside back of the machine on top right when looking at the front of the machine. They are fairly inexpensive and easy to replace.
Hope this helps
kcomp1863
Jan 18, 2011 | Roper RAS6233KQ Top Load Washer
Roper RAX7245KQ0 Problem: Washing Machine Leaking Water
This is the best designed life long lasting Whirlpool washing machine. This core design is more than 35 years old and it is so good Made in USA design. Cannot go wrong.... Coming from 1969 Moon landing time where Made in USA matters....
Most of the time in this design, the drain pump leaks. Is the leak is coming from front middle. It might be the drain pump. Careful observation is needed. Check the drain pump seam for possible water marks or brown color water marks. Make sure before changing.
Make sure it is the drain pump. Can be something else too.
Part description for water pump for your model with a video clip how to change it.
https://www.repairclinic.com/PartDetail/Drain-Pump/WP3363394/3296?modelNumber=RAX7245KQ0
Oct 09, 2017 | Whirlpool Washing Machines
Roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
Sep 27, 2009 | Washing Machines
Roper washing model number ras7133pqo leaking
lean it back look st the pump if water on it take it off 2 clips hold it on and check seal looks bad? ...replace thumbs up
VE6GAR 73 88 99
Aug 10, 2009 | Roper RAS8445KQ Top Load Washer
Roper washing machine leaking water
Might be a cracked water valve or dispenser. To get to it you must remove the skin. Click HERE for info on accessing these fine machines.
Feb 22, 2009 | Roper RTW4100SQ Top Load Washer
Leaking washing machine
most likely the pump ..lean washer back pump is help on by 2 clips and the hoses
Nov 15, 2008 | Roper RAS6233KQ Top Load Washer
Washing Machines Logo
90 people viewed this question
Top Washing Machines Experts
