Question about Whirlpool Washing Machines
No agitate and no spin
Replaced motor coupling - old was o.k.
replaced "dogs" in agitator
checked lid switch - o.k.
fills o.k.
drains o.k.
  • 3 more comments
  • paulemossjr Jan 17, 2009
    Whirlpool LST7233DQ0
  • paulemossjr Jan 18, 2009
    When select spin, that also activates the drain pump. I hear motor noise when I do that. The washer is not currently connected to the water supply so I can only hear the attempt to fill when I select a time wash/fill. I also noticed that I can take both hands and turn the agitator in either direction - machine off. Appreciate your assistance greatly!
    Dogs in agitator replaced.
  • onthethejob1
    onthethejob1 May 11, 2010
    do you hear the motor,,on wash and spin
  • onthethejob1
    what kind of unit model number
  • 640 Answers
Ok,,you need agitator dogs ,,the top auger move booth direction,,worn agitator dogs,,,i need you to fill unit on smal use a poy or bucket i have to know if this washes,,,onthejob
Posted on Jan 18, 2009
My roper washing machine is a top load washer around 5 to 10 years old. It will fill with water but won't agitate, rinse or spin. It will drain. It makes a horrible noise during all cycles except when...
No agitation or spin? try these:
WATER PRESSURE SWITCH: This switch keeps your washer from overflowing. It is responsible for shutting off the power to the fill valve and redirects the power to the timer to start the washing machine running once the correct water level has been reached. Meter check ur water pressure switch?
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash starts - then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well.
Or take the original hose tube and plug one end and blow into it AT the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ?
Sometimes they get busted open or a pin hole and release air causing the water switch diaphragm to not open.
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS. However in G.E models the cam dogs are replaced with what is called an agitator coupler. (located at bottom of tub)
Remember to check the agitator spline as well for worn broken teeth.
By the way my advice is free cuz God is good!
Mar 18, 2015 | Roper Washing Machines
My roper washing machine will fill with water, but will not agitate, rinse or spin, but will drain. It makes a horrible noise during all cycles except when filling with water. What is or could be the...
Mar 17, 2015 | Roper Washing Machines
Whirlpool washer fills sometimes and won't agitate or spin or drain what should i do
Jul 24, 2014 | Whirlpool Washing Machines
LXR7244PQ0 whirlpool top load washer. Problem: Agitator spins when manually turned, wash fills, does not agitate, spin, or drain. I checked lid switch, couplers and rubber piece is fine on motor I have...
Sounds like the motor coupling is bad- it keep the motor and transmission safe when overloaded and its cheap, if the motor is making noise that's the place I'd start. After that it's the motor (make sure it has power when it should) or the transmission- both not cheap.
May 16, 2014 | Washing Machines
No Agitate / No Spinning
If it is a top load washer I would check the lid switch, you should hear a click everytime you close the lid. If that is ok, there is a coupler between the motor and transmission, if it is a whirlpool, maytag, estate, admiral or kenmore.
Jan 26, 2014 | Washing Machines
W600 fornt load washer does not wash or spin. It does fill and drain fine.
Jan 12, 2014 | Asko W600
Help! I replaced the clutch and motor coupling a month ago. Ran great till this week. The wife washed tennis shoes, it quit agitating and spinning-i could hear the motor running fine. I again replaced the...
Have you checked for any damage on the lid switch at all? Washers won't engage the cycle you're having issues with if the lid switch is faulty. usually a magnet or plastic piece that pushes down the piece to engage agitation.
Sep 21, 2017 | Kenmore 22622 Top Load Washer
Replaced the belt and still not agitating, switch seems good
If the machine fills, won't agitate, wont drain or spin, then you need to replace the lid switch.
if machines fills, wont agitate, will drain but not spin, then you need to replace the motor coupling
Feb 08, 2011 | Frigidaire FWS1339A Top Load Washer
Roper RAX7245KQ Washer agitator does not rotate
If you are talking about the upper portion of the agitator (called the "auger") not spinning, you probably need to replace the agitator dogs. The following link epxlains how:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
This is a very simple and inexpenisve repair. The part number is included in the information I provided.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Now...a washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Take note of your symptoms:
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
2. Washer fills, does NOT agitate or spin, but WILL drain - motor coupling.
If you still have questions, please let me know. I hope this information is helpful to you.
Jul 02, 2009 | Washing Machines
Kenmore 70 series
Okay...I'm a little confused on your symptoms. You initially said it fills, but doesn't agitate or spin, but drains.
Then, you finished with the washer filling, no agitate or spin, but now doesn't drain.
Which one is it?
The symptoms you describe are usually associated with the following:
1. Fills, may or may not agitate, won't spin or drain - lid switch.
2. Fills, may or may not agitate, won't spin, but still drains - motor coupling.
3. Fills, may or may not agitate, won't spin or spins slow - gear case.
4. Fills, agitates, spins, but does not drain – water pump.
NOTE: These are the more common failure items with these symptoms.
Double check the lid switch by opening and closing the lid. You should hear a clicking noise to indicate the switch is working. The switch is located under the top panel along the wash tub rim on the right-hand side. If not, check to make sure the lid strike (small plastic piece on the lid itself) is in place. This activates the lid switch when the lid is closed. Also, check the mounting screws along the rim (there are two of them) to see if they are tight.
If the motor coupling were bad, the washer would still drain, but there would be a rattling sound as the washer tries to spin or agitate.
If you need replacement parts, go to searspartsdirect.com and type in your model number in the "Search by Model Number" window. The lid switch can be found under the "Top and Cabinet" heading as item number 11 (part #3949238). Instructions on how to replace are located at the following link:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
If you wish to replace the motor coupling, the part can be found under the “Brake/Clutch/Gearcase/Motor/Pump” heading as item number 13 (part #285753A). If you need instructions on how to replace, just follow this link:
Now, there’s a couple of ways to drain the washer. If it’s a simple lid switch problem, you don’t need to drain the washer to replace the switch. With a broken switch repaired, the washer will run and drain by itself. However, if you wish to drain the tub you can use a shop vac to pull a vacuum on the drain hose. This may take a few times depending on the size of the shop vac. These wash tubs typically have about a 35 gallon capacity. If you do not own a shop vac, you can by-pass the lid switch by jumpering the two BLACK wires at the lid switch connector that is connected to the console. CAUTION: Make sure you UNPLUG the washer before jumpering, then plug back in.
I hope this information is helpful to you. If I’m wrong about the symptoms, please post back and update me on what the washer is or is not doing, so I can assist you further.
May 15, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
143 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
