Question about Eureka Luxury Family 8-Person 2-Room Titan Tent
Eureka vacuum won't stay running
I have a central Eureka vacuum, model CV160IF. It quit all together the other day. I removed the canister and it was VERY full. It has a cloth filter which I cleaned as best I could without removing it. It had tripped the breaker so I reset it and reset the unit and it came on. Now it only runs for about a minute, suction is great but it quits. I can tell there is still some fine dust inside the cloth filter. I put a platic bag around the bottom and tried to work as much of it out as possible but I can't get it all out and I'm not sure how the cloth filter comes out. All I can find on the Eureka website is there's some kind of ring that has to be removed and reinstalled properly but I haven't figured that out yet. I'm wondering if there's some sort of internal switch or resistor that may be gone instead. I'm going to keep trying to figure out how the filter comes out but thought I would do this at the same time. Any ideas? Thanks for your help.
DRJ
    Scholar:
  • 95 Answers
There is a relay in the system. Based on your description it sounds like yours is bad. The cloth filter is a big pain to remove. I would recommend burrowing a shop vac from a friend and cleaning it that way.
Posted on Feb 04, 2009
Eureka Mighty Mite 3670 Bagged Canister Vacuum just stopped working
Should be under warranty. Take it to a warranty center for repair
Jan 05, 2014 | Eureka Mighty Mite 3670 Bagged Canister...
Where is the reset button on my eureka canister vac
with out knowing the model # i can't say for sure. however most of the eureka canister vacuum's ive worked on do not have a reset button. If its not working is probably the cord or switch that has gone bad. hope this helps
Jan 14, 2013 | Eureka Vacuums
I can't find a user manual for my Eureka Model UMC-18 central vacuum system!
I have a manual that I can send you, drop me a line at my email and I will attach it back to you.
thanks
Mark
bartmkh@yahoo.ca
Nov 11, 2010 | Eureka 1810 Central System Vacuum
I am buying a central vac system, can you tell me the better of the easy flo or nutone brand. I want the one with the least problems. It appears to me that the easy flo has fewer problems, thank you
between the two brands... stay away from the nutone. If you can get it, the Beam, Eureka, or even the Electrolux and Kenmore(sears) would still be better. The warranty would be better on the Beam and Eureka (7 or 10 and one model is even 15 years)
Good luck on your purchase.
Mark
Nov 09, 2010 | Easy Flo EF1525 Central System Vacuum
Canister turns on but no suction in house
sounds like there could be a clog in the lines, Check the pipes running through your attic/basement, and see if there's something blocking the piping.
If you can't seem to find the problem, I'd suggest looking into having someone who services central vacuums come and take a look. They'd have the proper tools and knowledge to help you in person
Apr 19, 2010 | Eureka 1810 Central System Vacuum
Dirt is being trapped in the filter area instead of canister.
The canister has a filter as well. It needs to be replaced or cleaned. A damaged canister filter will feed dirt into the HEPA filter. (and the motor)
An improperly installed filter can allow dirt to bypass the canister filter and collect in the HEPA filter.
I suggest a new canister filter and then clean it carefully every week.
Here is a list of the filters for your vacuum.
Apr 16, 2010 | Eureka 5893AVZ Bagless Upright Cyclonic...
Eureka 6993 power switch will not stay on
Did you eer figure out the solution? Mine is doing the same thing...
Jun 23, 2009 | Eureka 6993 Canister Vacuum
9 month old electrolux oxygen vacuum just quit
my electrolux oxygen canister just quit- i think it's the sumo board and the whole fuse problem why does this keep happening over and over (my 4th time w/ this model) and where can I buy a replacement sumo board myself?
Jun 19, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Central vacuum won't turn on
Check your filter to make sure that it is seated completely in the unit. There is a switch at the top that the filter has to press before the unit will run. It is there to protect the unit from running without a filter. If you remove the filter, and look up into the unit, you will see it. It's a longish white plastic piece that you can depress by hand. Listen for the faint click while you are inserting the filter to be sure the filter is depressing the switch. Good luck!
Jul 21, 2008 | Eureka Whirlwind Litespeed 5740 Bagless...
Eureka canister vacuum model 6865- cleaning
70227 is the part number for the owner manual, but you would have to have it order it. You can call 1-800-282-2886, this is Eureka's customer service, they don't have it in their data base, but maybe they can find something for you.
Mar 10, 2008 | Vacuums
Eureka Luxury Family 8-Person 2-Room Titan Tent Logo
313 people viewed this question
Top Eureka Sport & Outdoor - Others Experts
Are you an Eureka Sport and Outdoor - Other Expert? Answer questions, earn points and help others
