Question about Desa International GWP20T GLOWARM Wall Mounted Panel Heater
Heater will not stay lit
We have a model#CBN20T wall mount natural gas heater we can get the pilot light to light but as soon as we let up on the temperature selection knob we hear a click and the pilot goes out. We have occasionally been able to get the heater to stay lit for several hours - then it clicks and goes out.
    Sergeant:
  • 359 Answers
Sounds like the thermocouple is going out this is the part the flame from the pilot burns on and tells the gas valve to stay open by producing a small amount of electrical current in milli-amps these can be purchased @ a good hardware store and you must position as it is when it comes out , and must be the same length , make sure to connect to gas valve clean and tight , also is there a moisture trap in the line if so you might need to turn off gas and make sure it is free of moisture , this is a good place to start with these items
Posted on Jan 17, 2009
How to light the pilot light on a natural gas wall heater
SEt to pilot, Push knob, push pezio ignighter until pilot lights, hold for 30 seconds. if it stays lit turn to on, if it doesn't stay lit, you have a bad thermocouple
Mar 24, 2011 | Vulcan Heating & Cooling
I have a Dyna-Glo natural gas unvented roon heater that is wall mounted. The model is #GH-55(30,000 BTU). The pilot lights,but the main burner shuts off after 10-15 seconds with a fairly loud clunk. Do...
the pilot says on yes ? if not pilot could be blocked and need cleaning out or thermocouple needs changing if pilot is staying on then there could be a limit switch shutting off too soon , or burner needs cleaning
Jan 20, 2011 | Heating & Cooling
Williams 3003622 Wall Mounted 30,000 BTU The pilot light goes out when the main flame shuts down. The pilot light will stay lit for days when heat is not called for but when heat is called for the furnace...
I'm having the same exact problem... At first we thought was the vent... but the way the flames goes out... it seems that there is "not enough oxygen" more than "blown out by the wind"... right after both main & pilot goes out, I can't even light any external flame inside the chamber... and it doesn't feel like the outside cold air coming in... it just feel like there is some sort of gas in the chamber that's so strong, it prevents flame... and the only thing I can think of is that it doesn't have enough oxygen, but too much natural gas, and flame can't sustain.
Nov 02, 2010 | Williams 3003622 Ceramic Wall Mounted...
Wall mounted CBN30T, pilot goes out
IF its balance flue it could be blocked . Burner or orifice blocked lack of air to pilot slightly blocked thermocouple defective .
Mar 03, 2017 | Desa International CBN20T Heater
I have the DESA CBN20T Wall Heater. The pilot
take your gas lines off and blow compressed air though the lines blow out all the dust and stuff too
Nov 06, 2009 | Desa International CBN20T Heater
I have a natural gas pool heater. When I release
Replace the pilot generator. For a quote on the part, send us your heater make and model using the contact form at www.arrowpools.net
Jul 16, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Dyna-glo parts
thermocouples you can buy from any heating spares oulet or national energy a hone well is most common for useing as a replacement
Feb 03, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Natural Gas wall heater
It sounds like the thermocoupler is either not adjusted into the flame properly, or you may have gotten a bad one. The thermocouple is the main thing that makes the pilot work.
Dec 22, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Pilot wont stay lit
A short pilot flame not playing on the thermocouple or a faulty thermocouple , loose connection at the gas where thermocouple is ,
blocked pilot flame to small , air in gas line did he purge the gas line first? other wise you will be there a long time .
Dec 16, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Desa International GWP20T GLOWARM  Wall Mounted Panel Heater Logo
168 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
