Question about Kenmore Washing Machines
My washer wont drain, after the agitator stops it just turns off.
I put the drain hose to a floor drain, emptied washer quickly,no clog.I replaced the pump for it ,but still have the same problem.Whats the next thing to check? Thanks Tim
  • Dan Webster
    Dan Webster May 11, 2010
    make and model
  • 15,935 Answers
It appears your timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Kenmore 110-44182400 washer fills, agitates but will not empty
Hello there and thank you for choosing fixya
A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
5
If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
Apr 10, 2011 | Kenmore 44182 / 44813 / 44814 / 44819 37...
Front load waher will not drain
Hi, your washer water pump, could be burnt out, or clogged up, but first check drain hose for kink, remove back of machine, locate water pump, device that your drain hose are connected to, remove all hoses, pump from washer, and clean, sometimes foreign objects get into it, and prevent pump impeller from spinning, also check water pump winding (coil) with ohm tester, place tester lead, one on each terminal on pump (motor) if you hear beep sound, pump motor o/k, if not, pump burnt out, replace it, but first remove pump, and clean it. after cleaning replace pump, try machine. you could put drain hose, close to floor, into buck, and water will empty by gravity, if water is not emptying, that's evidence your water pump is block, small object (handkerchief, coins etc.) gets into them, from time to time, first clean your water pump, `and check for kink, in drain hoses. . always disconnect power, before attempting any repairs. good luck.
Aug 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Matag neptun front load washer wont drain
You have a clog in your pump; have to dismantle to de-clog. Look carefully.
Tip:
Empty out all pockets in clothing before loading the machine!
Mar 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Feb 28, 2009 | Frigidaire Washing Machines
Washer will empty water or spin out. Agitator works fine. Model: Kenmore 110. 51250100
Turn the washer off, pull it out and unplug it. Look at the drain hose; is it twisted or compressed? If is not then disconnect the drain hose and check it for clogs. If you do not find any, check all of your household drains, particularly the disposal. This is a very common problem. You may have a general plumbing clog some where. If you cannot find a clog and all the drains are running fine, You will need to have a service call.
The best to you and Thank You for using Fix Ya. Your rating is always appreciated.
Aug 24, 2008 | Washing Machines
Maytag Performa washer Waterlevel/agitator problem
CHECK your stand pipe hasn't fell over (the one the drain hose goes to when emptying)If not,Either the pressure switch is broke or there is a hole or split in the pressure switch rubber hose.This switch stops the water when it reaches required level.
Aug 15, 2007 | Maytag Performa PAV2200
Why wont my washer dryer empty the water...???
If the machine fills and agitates but does not drain, something is probably wrong with the drain hose or the pump. The fact that the washer fills and agitates tells you that the motor works and the belt is okay (though some units have a separate belt for the pump and direct-drive washing machines don't have belts). 1) Be sure the drain hose isn't kinked. 2) Check the tab on the lid that strikes the lid switch; if it is broken, the washer may stop during the drain cycle. Press and release the lid switch: if it doesn't click each time you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) The water pump may be broken or clogged with a small article of clothing or the controls may be broken; call an appliance repairperson. courtesy "nagev"
Oct 24, 2006 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
Sal De
fordexpert
Whirlpool
Whirlpool
