Cant get into my router so i can do port forwarding
Hi i have a thompson speedtouch router, and i need to get into the menu to set up port forwarding. have tried loads of ip addresses in the address bar, but nothing seems to work. please help!
  • 88 Answers
Try for the IP address and admin for the user name.
Posted on Jan 17, 2009
Port forwarding for a thompson
fault or query is not clear and I request that you must specify some more details to where the port is intended.
Dec 14, 2011 | Kenn E. Thompson Router Simulator
No internet connection
Check if you can , by pass the wizard and set the connection manually. Let me find more details for you
Jul 24, 2008 | NetGear RangeMax WPN824 Router
I cannot get my ps3 game to work. it says to consult my routers user manual to enable the setting in the games booklet. i cant because the manual has been lost. it requires a UDP port 9301. and i need to...
You'll need to setup port forwarding on your router.
From a computer use an internet browser such as Internet Explorer.
Assuming the router is using default settings.
1) In the address bar type in
2) You'll be asked for a username and password. Username is 'admin' and the password is 'password', no quotations.
3) Click on 'Port Forwarding / Port Triggering' on the left side bar.
4) Click on the Port Forwarding radio button.
5) Click the 'Add Custom Service' button.
6) For Service Name call it something meaningful, such as 'PS3.
7) For Service Type choose 'TCP/UDP'.
8) For starting port and ending port use '9301'.
9) For server IP use the IP address of the PS3, you can get this in the PS3 menu under Network Settings.
10) Click Apply
UPnP is supported by your router. On the left side bar, click 'UPnP'.
Feb 27, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
How do i do port forwarding on a speedtouch router
Are you using a BT Thompson speed touch? And if you are the ISP may block the ports to prohibit customers hosting servers etc.
Jun 30, 2010 | Alcatel SpeedTouch Pro (3EC18804HC)...
Do i have un install my speed touch modem to install netgear dg834v5
Hi, please note that speedtouch modem and DG834G router will not work together. Rather DG834G will replace the speedtouch modem. Remove the speedtouch modem and follow the below steps:
1. Connect the cable/phone line coming from Internet Service Provider to the WAN port of the router(isolated port).
2. Connect the computer to the router using any one of the 4 available ports.
3. Open the browser(Internet Explorer or Mozilla Firefox).
4. Access the router (usually
5. Login to the router (Username = admin Password = password unless you have changed it).
6. Click 'setup wizard'(at the top of list) from left menu.
7. Select yes and click next.
8. It should give you a "PPPoA Detected" and then click next.
9. Enter the login and Password of ISP click apply.
10. Once the settings are updated click on 'router Status' and click on 'connection status' button(at the bottom of the page).
11. Click on connect button.
12. Connecting to server should show 'connected'.
13. If you receive 'CHAP authentication failed', close the 'connection status' window and click on 'Basic settings'. Check the login and password for ISP and apply the setting again.
14. Open up another browser window and try to access internet.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Nov 05, 2009 | NetGear DG834G Router
I want to open my NAT so i can play xbox live
Okay. If you look at Network connections on Start menu (XP) open network connections...
Then select the on you are connected to... (LAN or WLAN) Click the support tab and you will see something like ""
Well type that into your browser, if it ask you for a password the default is normaly "admin" or "1234" (No quotes)
Temper with the "Gaming" or "Wireless connections" or "port forwarding"
If that does not work, are you sure you got xbox live gold?
(or hit the reset button on the back of your router)
Apr 28, 2009 | Computers & Internet
I have a thompson speedtouch 510 that works just fine but when i add my SPARKLan WRTR-141 it wont get connected neither by the computer or the laptop. i have 2 ethernet cables i added one end of the first...
Have you gone into the SPARKLan and configured it yet? It should be like this Speedtouch>SPARKLan>your computer in to the SPARKLan.
Turn on your new routers SSID so it can be "found" by the wireless devices. You should turn OFF the DHCP server in the Speedtouch and turn DHCP ON in the SPARKLan.
Hope this helps.
Jan 13, 2009 | Computers & Internet
Wireless router problem help fast plz
connected the CST-5 in the following manner.
1). one cable from speedtouch LAN port to sparklan WAN port
2). one cable from sparklan LAN port to the computer network port.
3). disable the DHCP from the parklan (consult your users manual how to do that).
4). restart all of the equipment in the following order. (This is important)
speedtouch, sparklan, computer, laptop.
do not rate the answer till you have the whole thing figure out.
Jan 13, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
Buffalo airstatio whr-hp-g54 router unable to connect to Orange speedtouch
I think the speedtouch modem do you have is a usb modem connection. The best solution is to call your ISP provider and request that you need to replace the usb speedtouch modem to LAN or RG45 connection. But the only problem you encounter if the internet you applied is personal only sometime they cannot provide the LAN connection to personal connection (like globe ISP).
Apr 08, 2008 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
