Question about Whirlpool Electronic Window Air Conditioner ACQ158XR
Fan motor in window ac/heat unit turns slow or not at all
I have a whirlpool ace124xjo heating and a/c unit
The fan motor went bad
replaced it with a new one ,Now when i turn it on it turns real slow and sometimes not at all. If i spin the fan it will start to spin for a little while then stops
Is it possible the capisitor is bad or what else can i check
thanks Tim
  • 306 Answers
Did you change the capacitor when you changed the fan? If you didn't you need to. And that capacitor is a dual one running the compressor and fan. So make a diagram of it what wires go where the area is real tight and some wires are the same color. You might make labels to be a little easier. Also get the same size capacitor when you change it.
Posted on Jan 17, 2009
I have a Goodman CPLE30-1A outside unit and the fan stop spinning. The fan stop spinning so I turn off the main power to the unit and I can spin the fan with the power turn off so I'm not sure if its...
Hello
There are a few things here that could be wrong.
1 Fan motor start capacitor is bad.Silver battery looking device on side of fan.Remove and replace with a new one.
2 Contactor for fan motor is pitted or burnt .If this is the case you will need a new contactor.
3 Fan motor is bad.Check top two before assuming this.
Check all fuses and circut breakers also.
Aug 29, 2011 | Goodman CKL42AR42 Air Conditioner
95 lexus es300 over heats when ac is turn on
Is your radiator cooling fan operating when the A/C is turned on? The cooling fan should be running at all times with the A/C on. If it does not, then your problem is being caused by a bad cooling fan motor, a bad cooling fan relay, a broken fan motor circuit, or broken fan control circuit.
Aug 27, 2011 | Lexus ES 300 Cars & Trucks
When the unit is turned on. I can hear the AC pump kick on and run. But the blower fan motor will not turn on at any fan speed. No setting on the AC will get the blower fan to turn on?
Sounds like then fan has died or the run capacitor has die. All motors that run on single phase mains need a capacitor to start them spinning. These are quite cheap & simple to replace usually - worth just replacing if you feel you can't test it. Looks a bit like a 'D' cell battery with 2 leads hanging out. Could also be that the unit is not cooling/heating and the temp sensor will not activate fan until heating/cooling coolant has passed room temp. - Rick
Jun 12, 2011 | LG Electronic Window Air Conditioner
I have a bryant AC/heat pump unit. Today I noticed that the air coming from the vents is just warm air, so i went out and the unit in not running condencer nor the fan. (it is the 661cj030-e unit).the only...
YES. It seems your capacitor is bad.
It must be replaced with the exact specifications as the original.
IE: MFD and VOLTAGE for the compressor and fan motor.
Example...35+5 370 vac.
Jun 27, 2010 | Heating & Cooling
My heat pump fan will not turn
First, with the unit not running, check to make sure the fan spins freely. Next check the capacitor. You can do that with a multimeter or look at it and if it looks swollen then it is most likely bad. Replace it with one of the same rating. If the capacitor is good then use an ohmmeter to check the fan motor windings. Also check the condition of your contactor and make sure the ciruit breakers are closed and the fuses are good. The breakers should be off before you check the capacitor, fan motor, and contactor.
Jun 04, 2010 | Amana Heating & Cooling
Fan isn't turning
turn the power off, take the cover off the top and try to spin it. If it spins hard then it was the motor. If it spins easy the the capacitor is probably bad which
would cause the fan to go bad.
Usually this can be a dual capacitor which also controls the compressor. Sometimes just replacing
the capcitor can do the trick, if not then the worst
is that you will have to replace the motor and still use the new capacitor
Feb 02, 2010 | Heating & Cooling
Carrier 38CKC042300. oUTSIDE UNIT FAN WAS TURNING REAL SLOW. ac UNIT IS OFF BUT FAN TO OUTSIDE UNIT IS STILL TURNING. sHOULD NOT BE TURNING AT ALL WITH AC UNIT OFF
The outside fan may run if the unit is in defrost mode this is normal for most heat pumps it is there way of trying to keep the outside unit from staying iced over so the next time the unit runs it will have air flow through the coil and the ice will not be there to prevent air flow.
Jan 12, 2010 | Carrier 38CKC042 Air Conditioner
I have a cple18-1c at my home. it is making a
Fan motor is out or possibly the capacitor to the fan is bad. Would have capacitor replaced first then replace the motor if the capacitor didn't solve you problems.
Good Luck on repairs
Dave
Dec 08, 2009 | Goodman CPLE24-1 Air Conditioner
Whirlpool Electronic Window Air Conditioner ACQ158XR Logo
1,546 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
