Question about GE GSH25JFR Side by Side Refrigerator
I have a hotpoint refrigerator hss25gfpjww...symptoms I was having are ghost noises and water not working...the ice does work. I have replaced the water filter and the motherboard and the ghost noises have stopped but the water still does not work...what else could be the problem?
I have a GE. Same 2 problems. I still have the ghost, but I fixed the water. There is a coiled up tubing inside the refrigerator behind the vegetable drawer. It was frozen. I took the drawer out and turned the rerigerator off and left the door open for about 4 hours while we watched tv. Tried to run the water with no success. Just about to give up when all of a sudden water flowed. It happened 1 more time, but not for about 6 months now.
What's the ghost noise solution?
Posted on Jan 17, 2009
Ge hss25gfpjww is not dispending water and ice
HI RICKEY.first thing is first.check water supply ok.Ali good luck
Jun 25, 2012 | Hotpoint HSS25GFP Side by Side...
The water is not working, but ice dispenser is, the make number hss25gfpjww
Clogged water filter or faulty water valve. You have a dual water valve on that unit which explains why the ice maker is working and not the dispenser.
Feb 23, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Have a GE Fridge Hotpoint Model HSS25GFPJWW The ice make, makes ice but the water dispenser (to fill a class) doesn't work. Replaced the filter and it still doesn't work, in Oct 09 it the same thing...
i would ck the water valve . this is a dual valve in the back one side may have burned out and is not opening to let water in one side is for icemker and other for foutain . and also ck the water line inside freshfood see if its frozen. ( if themp is too cold in fresh food side it will freeze . should be about 38 deg .. hope this helps mm
Jan 20, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Water not coming from spout,pressure in the line into door to spo
I have the exact problem with my side by side, water gets to the bottom of the door, and no further. Like Dan said, don't see how to open up the door.
J Bod @
Mar 14, 2009 | Hotpoint HSS25GFP Side by Side...
Ice Maker doesn't work
i press ice dispenser . and ice will not come out an light goses dimm please help
Sep 01, 2008 | Hotpoint HSS25GFP Side by Side...
Hotpoint Ice Maker Stopped Making Ice
ngfam1 At your service!
I came to your service on some days ago!
And gave you some good advice!
But, I did not receive a rating from you yet!
Can you please give me a rating at our site!
Bless, You ngafm1
Jul 04, 2008 | Hotpoint HSS25GFP Side by Side...
Clicking, no water or ice, power problem?
first i wold check the micro switch that the acuator paddle trips next i would replace the watervalves which is the most likely cause of this finally id replace the control bd as some early ges had a promblem with this there is also a solinoid in there for opening the ice chute door but that wouldnt affect the water but may cause a voltage drop if its getting bad id change the water valves the ice is on one valve the door water is on the other
Jan 19, 2008 | Hotpoint HSS25GFP Side by Side...
Hotpoint side by side Model HSS25GFPJWW
Your problems are the power board for sure. I have the same refrigerator and have read dozens of forums and advise pages looking for answers. If you let the problem countinue your fridge will completely stop cooling and all your food will be trash as has happened to me.
Symptoms: Fan in the back starts to make click or flopping sound as it tries to start up. Ice despenser doesent despense ice. water works sometimes. Eventually you notice your food defrosting partially and then refreezing as the defrost timer stops working which is controlled by the power board. Light dims and pulses when you hold the Ice despencer in. If you remove the light for the dispencer your water will work fine as long as the fan isnt making the clicking noise. Fan will eventually start up and run.
FYI GE customer Care is useless
Jan 03, 2008 | Refrigerators
GE GSH25JFR Side by Side Refrigerator Logo
150 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
