Question about Plantronics 510 Voyager Headset - PLN-510 Headset
My Plantronics Voyager 510 will not go into pairing mode.
When I hold the volume + button and the call control button simultaneously as directed in the manual, My Voyager 510 does not go into pairing mode, blinking blue and red. It just continues to blink blue even though I have held the buttons for several minutes. I am trying to pair with an iPhone 3G.
  • 3 more comments
  • Anonymous Jan 22, 2009
    I have the same situation....read the manual for a factory reset function but can't seem to find it either
  • Anonymous Mar 26, 2009
    I tried resetting my 3G iPhone and then pairing with my Plantronics 510 as I have in the past with my RAZR phone. The iPhone searches endlessly for the bluetooth connection with no result.
  • Anonymous Apr 02, 2009
    I have a Plantronics 510 and a Blackberry. They would sync fine for a while but then the 510 stopped and it will not go into pairing mode now.
  • thirukumar Apr 13, 2009
    same here . The status in iPhone says its Paired but it keeps searching for the device with no results.
  • vmkfire1 Apr 16, 2009
    My 510 will not go into pairing mode either when the instructions are followed. It just turns on and then off.
I actually got this to work with my iphone 3G S. i pressed the little black button then saw a blue light flash, and then i pressed and held the + volume button and the call control button until it started blinking blue and red and my iphone picked it up instantly. it did take a couple of times to get the headset to go into pairing though
Posted on Oct 19, 2009
  • jgraham113 Apr 30, 2011
    Here's another part of this puzzle. Following the directions, I couldn't get any of the little lights to flash. One thing I tried was to keep the earset plugged into the charger with the blue light on. Then I followed the instructions, the lights (blue and red) flashed, my 3gs found it, they mated and are living happily ever after, so far.
Make sure your headset is not already paired with a device like a computer. Mine would not enter pairing mode at all. I discovered my laptop was paired with the headset already. I ended that connection and my headset went into pairing mode ( flash red/ blue).
Posted on Jul 22, 2009
My blue light won't flash when the headset is on, somehow i turned it off.
Posted on Feb 06, 2009
How do i connect my plantronics 510 voyager headset to my blackberry
Once you make your BlackBerry discoverable, then put the Plantronics Voyager 510 into pairing mode by holding the call control and volume up buttons at the same time until the headset flashes red and blue. Here is the link below for the 510 pairing instructions.
Plantronics Voyager 510 Pairing Instructions
Good luck from Headsets Direct!
Oct 19, 2011 | Plantronics 510 Voyager Headset - PLN-510...
Tip
How to Pair or Connect the Plantronics 510 Bluetooth Headset to your Bluetooth...
1. Turn on Bluetooth within your phone - Consult phone instruction booklet
2. Put phone into pairing mode - Consult phone instruction booklet
3. Put headset into pairing mode - With headset on, press and hold call button and the volume up simultaneously until the headset begins to flash red and blue.
4. Select "Add new device" on your phone.
5. Select the Plantronics headset when prompted. Enter "0000" as passcode.
6. Your 510 headset will now have a continuous blue light blinking.
7. Choose "Yes" if your phones asks if you want to bond to the 510 bluetooth headset.
8. Your phone is now paired with the Plantronics 510 headset and ready for use.
on Jul 14, 2010 | Cell Phones
When trying to pair my plantronics voyager 50 to my iphone, i am attempting to get the blue and red light to flash by pushing the up volume and the call button. but no flashes occur, even after 60 seconds...
  1. Turn on Bluetooth within your phone. Put phone into pairing mode.Put headset into pairing mode - With headset on, press and hold call button and the volume up simultaneously until the headset begins to flash red and blue.
  2. Pick the headset for Plantronics when prompted. Enter "0000" (four zeros)
  3. you should now have a continuous blue light blinking.
  4. Choose "Yes" if your phones asks if you want to bond to the Voyager 510 bluetooth headset.
Good luck from Headsets Direct - 800-914-7996.
Aug 13, 2011 | Plantronics 510 Voyager Headset - PLN-510...
How do I put the unit in discover mode
Putting the Plantronics Voyager 510 into pairing mode:
With headset on, press and hold the call button and the volume up simultaneously until the headset begins to flash red and blue.
Select the Plantronics 510 headset in your phone when prompted and enter 0000 (4 zeros) as the PIN/passcode if prompted. When paired, the Voyager 510 headset should now have a continuous blinking blue light. Here is a link below for the step by step pairing instructions.
http://www.headsetsdirect.com/plantronics-voyager-510-bluetooth-pairing-instructions
Aug 12, 2011 | Plantronics 510 Voyager Headset - PLN-510...
I have htc thunderbolt when i scan it wont find my bluetooth im wondering if there compatible?
Here is a solution that might work on your HTC Thundermug. The User's Guide indicates "activate bluetooth pairing mode by pressing the Power button". It should indicate to press and hold the power button. Pressing and holding resulted in the headset being recognized within 5 seconds by the HTC Thunderbolt. This is a problem with the User's Guide.
How to Pair the Plantronics 510 Headset
Good Luck from Headsets Direct!
Jun 27, 2011 | Plantronics 510 Voyager Headset - PLN-510...
Just purchased the quantico phone trying to pair it with my plantronic 510 headset but need help
Press and hold both the Speak Volume Adjust Buttons on the base unit until
the indicator in the Call Control Button starts to flash.
Press and hold the headset Listen Volume Adjust + Button and headset Call
Control Button until the Status Indicator flashes red and blue.
Pairing completion is indicated when the Call Control Button indicator
illuminates solidly, and the Status Indicator flashes
Here is link to manual if you need it:
http://www.plantronics.com/us/media/media-resources/literature/user_guides/voyager510_ug_gb.pdf?WT.dl=20
Good luck
Apr 16, 2011 | Plantronics 510 Voyager Headset - PLN-510...
How do you sync a plantronics 510?
allanrecht
The steps below will show you how to put your Voyager 510 into pairing mode.
To put the headset into pairing mode:
1 - Start with the headset powered on (the headset will have a blue blinking light).
2 - Press in and hold the + side of the volume button (long, thin and silver) and the Call Control Button (on the
microphone boom, oval shaped) until the headset flashes red, blue, red, blue.
3 - Tell your phone to "Find the new Bluetooth device" (see the User Guide or call a local phone store).
4 - If the phone asks for a User Code or passkey, enter 0000 (four zeros).
Issken
Jan 25, 2010 | Plantronics 510 Voyager Headset - PLN-510...
How to set it up with new phone how do i set up discoverable mode
  1. Turn on both the phone and the headset
  2. To put the headset into pairing mode, at the same time press the Call Control button (side of the headset) AND the volume button marked "+". When the status indicator light flashes between blue and red, you are in pairing mode.
  3. Now use your phones menu to search for bluetooth devices, you should see it say "PLT 510" on the screen. Note, this can take up to 2 minutes.
  4. When it asks for the passkey, enter "0000" (zeros). When the light on the headset turns blue you are successful.
  5. If this fails, try again
  6. If this fails again...reset the headset. To reset, do a long press of the MUTE and volume down buttons simultaneously for about 3 seconds, then try the procedure again.
Oct 16, 2009 | Plantronics 510 Voyager Headset - PLN-510...
How to put my headset in pairing mode
Do not use the power button to sync.
To sync device, Press + button (volume) and Silver button (on boom) at simultaneously. LED Light will blink RED & BLUE. Device ID should appear on your screen.
sometimes it is tricky and you do have to turn on the power
so try it both ways and if the power is on hold the 2 buttons for about 30 seconds to 1 minute if the light stays blue turn off and try again they are not easy to sync the code for pairing if they ask you for 1 is 0000
Dec 03, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Plantronics Voyager 510 & Blackberry Curve
 Plantronics Support Phone Number: 1-800-544-4660
Jan 14, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Plantronics 510 Voyager Headset - PLN-510 Headset Logo
6,405 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
