Question about Air Tools & Compressors
Brake lights How easy is it to replace the turn signal switch for an '07 chevy 1500?
    Problem Solver:
  • 5 Answers
You will need a book for it but is easy if you know how to remove Air BAG as you will need to pull your steering wheel to get at it then replace all parts you pulled if the AIR BAG is a show stopper then will need a pro to handle it half day job is your Dimmer goes out it is lower of the colum much easier has rod from switch going down from turn switch hope this helps you some.
Posted on Jan 26, 2009
89 Chevy 1500. Break lights and rear turn signals quit working ... I'm clueless. Help?
Since power from the brake light switch goes thru the turn signal switch, have you checked the turn signal switch for power in and out on each circuit ?
Jun 01, 2013 | Cars & Trucks
1993 chevy silverado parking lamps go of when i turn on headlights, signal lights flicker when i press on brake.
Yes I would look for a ground circuit problem. I would look at the ground wires for the headlights first. Even run a new ground wire for the tail lights to see if it helps.
Could be a ground connection for the body to frame or body to battery.
Aug 10, 2012 | Chevrolet Silverado 1500 Cars & Trucks
2007 chevy impala brake light and left turn signal not working
Fast flashing dash signals mean there is a bulb issue-DEFINATELY!
Aug 07, 2012 | 2007 Chevrolet Impala LS Sedan New Cars
2003 chevy 1500 rear brake lights not working, but over the cab break light is. bulbs look good, the running lights work.
sounds like a bad turn signal switch . both side brake lights run through it but the third brake l;ight runs direct from the brake light switch .- play with the hazard button a few times and if the start working you need the turn signal switch
Feb 13, 2011 | 2003 Chevrolet Silverado 1500
I have a 94 chevy 1500 and the brake lights are dim and wire from brake switch gets hot brake is on then it blows a fuse. traced all wires and replaced brake switch. what else could it be?
Possibly a short in the directional switch in the steering wheel. Your brake lights use the same filament as the turn signals, so the brake light wiring goes thru the directional switch. Does one wire from the brake light switch go up the steering column?
Sep 16, 2010 | 1994 Chevrolet C1500
Brake wiring diagram chevy lumina
why not just replace the turn signal switch must faster and safer . buy one from your local parts house then you can see its not that easy to install but you can do it with a little help
Aug 26, 2009 | 1997 Chevrolet Lumina
No brake lights
check the grounding on the swich cicuit
Jul 20, 2009 | 1990 Chevrolet K1500
Brake lights 1997 Chevy Lumina
i would check the bulbs first. then continue to the brake switch
Sep 10, 2008 | 1997 Chevrolet Lumina
Brake lights
check out the brake light switch located on the brake peddle. Could be out of adjustment or burned out.
Jul 03, 2008 | 1994 Chevrolet K1500
Air Tools & Compressors Logo
51 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
