Question about Canon PowerShot A720 IS Digital Camera
Canon power shot a270 is lens error
I can take pictures with the camera but when turning off it gives a lens error turn off camera and the lens does not close all the way. how can i fix this problem. thank you
    Sergeant:
  • 367 Answers
Try to remove battery with lens out then put battery back in. If problem is still there you can gently try to push in the lens as its going in but service is recommended.
Posted on Jan 20, 2009
Shooting is not possible, turn the power switch to off and on or reinstall the battery
Hi there :the Error 99 is a comunication error between camera body and lens .are you using Canon lens?Try the camera body with a/another Canon lens in Camera body and try the lens on another Canon camera.With this troubleshoting you can know if the camera body is failing or lens is failing.I hope this information will help you.
Nov 29, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
Got a lens error message and the camera turned off
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Aug 01, 2010 | Canon PowerShot SX10 IS Digital Camera
When Turning on the Canon Power Shot A530 the
Here are some things that you can do to try to correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
Dec 21, 2009 | Canon PowerShot A530 Digital Camera
Canon power shot sx100is LENS ERROR
Don't want to get your hopes up too high, but here are some things that you can do to try to correct it. They only seem to work for about 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 15, 2009 | Canon PowerShot SX100 IS Digital Camera
E 18 problem
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 09, 2008 | Canon PowerShot A520 Digital Camera
E 18 problem
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Aug 09, 2008 | Canon PowerShot A40 Digital Camera
E 18 problem
Hello there,
Jul 22, 2008 | Canon PowerShot SD200 / IXUS 30 Digital...
E 18 problem
Hello there,
Jun 09, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
E 18 problem
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're still worth a try. Good luck! :
Feb 13, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Canon PowerShot A720 IS Digital Camera Logo
413 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
