Question about Nikon F80 35mm Film Camera
Latch for the Film door broke
I don't know exactly how, but the latch for the film door was gone one day. I was taking photos at a wedding, and had to reload my camera and the film door wouldn't clip shut, there for rendering my camera useless. How do I get it fixed, where do I get it fixed and how much am I looking at to get it fixed? Can I buy spare parts and do it myself? I am stuck! Help please :-)
    Champion:
  • Nikon Expert
  • 225 Answers
You could call Nikon Film 1-800-645-6687 to get an estimate. However, as kachbibi1 stated it may be best to purchase a used F80; they cost from $70-$90 US.
Posted on Aug 30, 2010
  • 979 Answers
This is so tedious a job that I would not try it myself unless I was adept in doing this right.Unless the camera costs a lot to start with, I would just get another SLR. I believe the cost in repairing it depending on model and the size, will be about $200. I say this because from experience, I had a $250 camera 20 years ago and the latch broke on mine and he said it would not be worth it to fix it. Unfortunately, it was way out of warranty.
Posted on Feb 11, 2009
How can I get repair parts for my eos elan 7 Canon film door?
Remove front cover to get to latch. Be careful not to touch the flash circuit as it can have a nasty 300 volt shock.
Canon parts phone number: 732-521-7230. They used to take credit cards, not sure if they still do. They are really good about ordering by description.
Jun 11, 2014 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Who can repair the film door latch?
Any camera shop can send this out for repair or to get an estimate. It may not be repairable due to parts not being available.
Feb 01, 2012 | Nikon N75 35mm SLR Camera
I put a fresh new pack of film into my Fuji film instax 210 camera but only used it to take two pictures. The next day when I tried to take a picture, it came out completely white. Why is that? It is very...
Completely white photos on an Instax, or any instant camera means the film has been exposed somehow. Check to be sure the film door is completely closed, and latched properly. If it is, it's possible, though unlikely, that your camera's shutter is stuck open. It'd be easy to check, simply look at the front of your camera into the lens, and see if you see any mechanical bits, now take a picture and see if you see any of them move - movement means working, no movement means not. If the entire camera back opens (I'm not sure if it does) you can also open it and do the same thing, looking to see if you see light through the camera when you're looking through the lens but not taking a picture - if you do the lense is stuck open. This, however, would require removing and wasting whatever film is remaining in it right now.
Aug 30, 2011 | FUJIFILM Instax 210 Film Camera
Film door latch broken
Nikon doesn't supply the film door any more. You can buy a repair kit from USCamera.com to replace the latch on the film door
Jan 02, 2010 | Nikon N6006 35mm SLR Camera
Broken latch on film door
Usually on this level Nikon it was a plastic "hook", part of the door moulding, that was retained by the latch mechanism in the body. The broken part may still be in there - if it is trip the latch and recover it with a tiny screwdriver or even a needle. If you can't find a replacement back door you can try welding the hook back in place with a low-temperature soldering iron - with the tip perfectly clean and a very steady hand - as long as the door is thermoplastic and not thermosetting. If that doesn't work bend a paperclip or similar to exactly the right shape with the free ends (roughened) long enough to extend into the plastic of the door by 4-5mm., heat the wire and push slowly into the edge of the door. There are many variations of this technique that I've used, all require extremely careful work! Best tip: spend more time thinking than doing. Good luck.
Nov 28, 2009 | Nikon N70 35mm SLR Camera
Camera film door will not latch. The door latch
Can it be repaired? It needs a new latch piece. Maybe a new door, if its all one piece.
I do not own one so not sure about that model. Look at the door hinge. If a small lever sticks out of the hinge, it may be easily removed and replaced with a new door. otherwise you need to remove the bottom plate of the camera to replace the door. Be very careful doing so as things could pop out when you open it.
You could also send it in to a repair shop, where they will also clean, lubricate and adjust it before returning.
Is it worth it? Only you can answer that. You might be able to pickup a used one on Ebay, so you have a source of parts.
If you have no reason to keep that particular camera, replace it with a newer Nikon, so you can keep using your flash and lenses.
Oct 04, 2009 | Nikon N6006 35mm SLR Camera
Don't know how to open door latch on nikon 35mm SLR camera
You haven't stated which model you have, but generally most SLR's open by pulling upwards on the film rewind crank (the knob on the left side of the top-plate as viewed from behind). If this doesn't work then add the exact model as a comment to my answer and I'll try to give you specific instructions for your model.
Jun 15, 2009 | Nikon N70 35mm SLR Camera
Can't close door after loading film.
sounds like the door latch broke. (tape) Canon will only replace/upgrade not repair.
ours cracked after a drop then broke replacing the film.
Jan 07, 2009 | Canon Sure Shot Z155 Caption 35mm Point...
Film door latch is loose
Same advice I made to another post. At some point you got to make a decision. There is a lot of plastic pieces that can break. Canon doesn't support the T series from what I've read. You may consider getting another one. You also have to consider that the fix may not work. Then what do you do?
Sep 06, 2008 | Canon T70 35mm SLR Camera
My crystal ball tells me that you are referring to you vintage 1939 Pentax SLR camera! Is that correct?
May 12, 2017 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Nikon F80 35mm Film Camera Logo
239 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
