Black background with white haze around the text.
I have tryed replacing the main charge unit, transfer/sep unit, pre transfer unit and the drum. adjusted main charge bias up to max and down to min with no effect. please help me if you can.
  • koma1971 Jan 16, 2009
    it is a canon imagrunner 7095. and it has close to 4 mil copies on it.
  • Mike May 11, 2010
    what model and make machine
  • 100 Answers
The prevailing thought at this time is that electrical noise caused by dust in the clutch, CL8, is the culprit.
As this investigation has progressed, a minor modification was made to a few sample DC Controllers to attempt to eliminate the electrical noise. Upon realization that the dust in the clutch is the cause, we no longer believe the resolution is a modified controller. Additionally, there were only a few of these controllers created to use in a few beta sights to evaluate the results. No more modified DC Controllers exist.
Although cleaning the clutch may resolve your immediate problem, we need sample paper feed assemblies to continue to investigate the cause. We would greatly appreciate anyone who can supply a paper feed assembly. Please call the TSC, and refer to me and / or this forum post and we will try to
ALSO NOTE
Clutch was replaced first. No change,still black copies. Replaced unit and problem went away until now
Hopefully, this will help shed some more light on all of the trouble and speculation regarding this particular CQ issue.
The revision 120 DCC seems to have been taking care of the black copies with halo CQ issue.
The new and/or modified DCC is capable of filtering out the electrical noise that is caused by the stray metallic dust that accumulates inside some of the clutches.
Therefore the HVT circuit on the revision 120 DCC's should not be affected by this anymore.
Hope this helps someone save on time continuing to look for the answer,
... it appears as though this one probably took input from several different sources to get to the bottom of this issue. When facts are coupled with well thought out theories, this forum can be a great tool for all
Canon USA's and CINC's (Canon Inc., Japan) investigation had led to the belief that replacement of the clutch would be the resolution to this problem. In an effort to bring the latest information to the field, we decided to post what we knew at that time. However, the investigation was not complete. New information, gathered from our investigation, has yielded a greater depth of understanding which has led us to the following update to this problem. Please note the following:
We looked closely at how many machines use this clutch and also at examples of the same model number at different locations. Based on the results of this analysis, we determined that the most effective and quickest way to resolve this symptom is to update the DC Controller PCBs. This was mentioned earlier as a possible remedy, but was not, at that time, a definitive resolution. Beta testing was being done concurrently at the time of Bill's posting. We now feel this will be an effective solution to this problem. You can expect to see an update program to start soon
All of this is from the Canon forum, Such a wierd problem I read up on it. I would replace the dc controler and the paper deck one feed assembly if you can or at least the clutch. Good luck! You need that revision dc controler, You could contact Nation-wide repair and see if they can update or exchange for yours.
Posted on Jan 17, 2009
Color printing is printed with a yellow background in bizhub c450
have you replace the Transfer belt.??? It also has a transfer roller for yellow. (Called First Transfer) since it is transferring yellow off the drum. You have replaced the yellow image unit???? 2nd transfer is to the paper!!!
May 18, 2016 | Konica Minolta bizhub C450P Laser Printer
How to rest toner from black background
If the copy is dirty background first clean the optical parts component,mirror,lamp,charge corona,transfer unit.If it is OK verify the imaging unit developer and drum,if necessary change it.
Nov 30, 2013 | Konica Minolta Genuine Di181 Di-181 Ep1085...
Dell 1815dn - when faxing, the fax goes through but all pages are black. when attempting to scan, pages are black. when trying to scan to a PDF file, the file is blank or black.
Welcome to Fixya
Try to print a document and see if you will be getting same issue. Try to copy a document and see if same thing will happen also. Check if the cartridges are not running out of ink.
Thank you for using Fixya!
Aug 02, 2011 | Dell 1815dn All-In-One Laser Printer
Canon PC921 Replaced toner, bad copies. Is there a separate drum to be replaced?
yes that it 's the most possibillity.
but you must be assure that :
- the paper is not moist. (it makes pale copies)
- the glass has you cleaned up. (it makes black background uneven)
- the transfer unit is not dirty. (it makes black background)
May 21, 2011 | Canon PC-921 Black and White Copier
Ir5000 error code e000062-000. how do I clear it?
E061
Main Cause The laser shutter is faulty. The laser unit is faulty. The potential measurement
PCB is faulty. The DC controller PCB is faulty.
Mode of
Detection
0001 As the result of potential control, the drum surface potential (VL2)
of the white background is about 200 V (generating solid black images).
0002 The primary charging output used for print output and the drum
surface potential after laser output has been made are about 200 V
IF you are meaning E602 - replace hdd and system software
Feb 16, 2010 | Canon imageRUNNER 5000 Copier
Black Haze
It can be one of two things... It may be the drum needs to be replaced or it could be the fixinf film is ripped and damaged. It maybe the transfer unit or the developing unit?
Jul 28, 2009 | Canon ImageRUNNER 330s Copier
When we print black type on a white background, the background comes out gray and gets rapidly worse from one sheet to another. Although we have calibrated and done all of the other maintenance and...
this could be a problem of black drum,unit(needs change)it is cause by defective cleaning blade or the charge roller inside the drum unit hopethis will help
Jul 27, 2009 | Canon Office Equipment & Supplies
Dell 1815dn laser printer prints completely black pages
1. Charge – Print Quality (PQ) -- The charge roller evenly distributes a negative charge on the photoconductor (PC) drum. This evenly distributed charge acts as the film that is discharged (exposed) by the laser to create the latent image.
a. Print Quality effected: Faint, Entire Black background, Grey Fog/Haze
b. Parts Involved:
i. Drum -- A drum cartridge is coated with a photoconductive material that allows electricity to pass when exposed to light. As an example of why this can be the failure, if you leave a drum out in light long enough, you will get dark backgrounds or just black pages. However, drums do wear out over time too; specifically the photo material the drum is coated with. As this degrades, more of the positive electricity on the inside of the drum gets through and grabs toner, as if the laser wrote to every square inch of it. A damaged or defective PC drum can cause black streaks/lines, voids, speckles and various other print quality problems.
ii. Charge Roller Also known as the BCR or Bias Charge Roll. The charge roller pulls double duty. It energizes the outside of the drum with negative energy and as a result it cleans any previous latent images. If the charge roller were failing to energize either due to the HVPS or the charge roller itself, it wouldn’t clean any previous unused toner deposits from the last revolution would start to accumulate and appear on paper more and more causing haze. A missing charge roller causes completely black pages.
iii. HVPS – High Voltage Power Supply -- Responsible for charging components such as the inside of the drum, the charge roller, and transfer roller. If the HVPS does not give enough to the charge roller it can fail in erasing the drum, causing entirely Black pages to be printed.
Apr 16, 2009 | Dell 1815dn All-In-One Laser Printer
Toshiba e-studio 232 code C970
C970: HVT or charge corona.
Remove main charge and trans/sep. coratron units and check --- make sure wires are not broke, clean grid, clean canals of units.
Replace and part needed.
If coratron units are fine --- replace HVT ( high voltage transformer).
Jan 31, 2009 | Toshiba e-Studio 232 Black and White...
Gray background, but copied text is visible
With toner being dropped I would take a close look at the cleaning unit next to the drum. Sometimes they become clogged or wear out. Inside the machine, can you see toner that has spilled or piled up? If so that is an indication of a faulty cleaning unit.
MM85
May 23, 2008 | Canon NP 7130 Black and White Copier
70 people viewed this question
jasbo
jasbo
