Question about Whirlpool Washing Machines
Can the water level be increased for the Whirlpool Cabrio 6700
How can I force the machine to wash and rinse with more water. It is damaging items, does not get them clean and does not rinse the soap out even with the 2nd rinse. Model WTW6700TW1 Is there any type of adjustment?
2 Suggested Answers
  • 61 Answers
SOURCE: Can the water level be increased for the Whirlpool Cabrio 6700?
you can not . frist off what type of detergant are you using ? you have to use an He detergant this is a low sudsing detergant formulated for frontload machines and must be used no substutes. next be sure not to overload the machine remeber the water has to be able to pass through the clothes these few things will make a large differance.
Posted on Jan 16, 2009
Low level of rinse water. What can I do?
Possible that the water level sensor has failed and so it does not load to the level set by the program. You will need to check the level sensor to clear the water line of air block or dirt or faulty unit.Try to set a higher water level to the program settings and see if the water fills up on rinse, choose an different program
Mar 14, 2012 | Washing Machines
Hi. I have a Whirlpool Gold Ultimate Care II Quiet Wash plus top loader washing machine. Today as the water went in to rinse the wash it flooded out across the floor from underneath. Is there a filter I...
No problem with Filter.
Pressure switch is not working, it is not sensing the water level. There could be one more reason can cause this issue. Please check the Pressure HOSE whether is punchered or not.
Sep 16, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have the Whirlpool Topload Cabrio washing machine and it will be a year old on Jan. 15, 2011. It is really starting to stink up my laundry room. I have run the wash cycle through with distilled vinegar...
Here is what I do. I run "Tide Washing Machine Cleaner" thru the washer first with HOT water. Then, I recommend running a rinse only with hot water & bleach to rinse the washer out really well and don't forget to leave the lid opened when the washer is not in use.
Jan 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing machine displays an LF error code. Started last week during whitest whites cycle in rinse. I cancelled and just did rinse to finish my load. All other cycles worked and yesterday all started...
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
How do you set the Cabrio to wash a small load?
this one only has 1 setting on water level. same size uses same level
Feb 25, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool washer machine shakes badly when cycle
The problem could an improper leveling of the machine.Also could be bad drum bearings or even damaged ones because of the previous heavy spins.
Apr 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My Whirlpool LSQ8543J has started overflowing after rinse cycle
Replace the water valve where your hoses connect to the washer.
Mar 17, 2009 | Whirlpool LSQ8543J
Jan 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
303 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
