Question about Ariens 34 In. Zoom Series Riding Mower
Very heavy smoke on start-up & primer bulb prob.
Each time I start my Ariens snow blower it smokes very heavily for about 5 seconds, then clears. 6-8 starts so far. The oil level is right; just to top of full mark. This started after tipping it on it's front as specified in the repair manual to grease the fittings underneath for the drive wheels.
The primer bulb does not prime carb. It pushes air out the tube when I disconnect it from the carb. and push it.
  • Mike Rice Jan 19, 2009
    After about 5 seconds the smoke stops. If I shut off the engine wait even 10 seconds, and start it again the smoke starts again. I have blown my whole driveway and restarted it and it still smokes again for 5 seconds. The primer bulb doesn't work either when the tube is attached to the carb, but works fine when disconnected.
    Scholar:
  • 76 Answers
It should be fine, it's just some oil that seeped through and is now in the muffler. Just let it run for a while to burn off what is in the muffler you may also have a little bit in the carb, if you want to check the carb just pull the bowl off to see if there is any thing for oil in there, be sure to shut the fuel off or clamp it off with needle nose vise grips before you pull the bowl off. Otherwise everything will be ok just run it for a while and keep an eye on the oil level.
Posted on Jan 17, 2009
  • Mark Tripp
    Mark Tripp Jan 21, 2009
    I'm gonna do some investigating on this for you, so please check back in a day or 2.
Why do I have hard time starting my ariens snowblower when cold?
does it have a primer bulb been seeing a lot of the bulbs with cracks
Feb 17, 2015 | Ariens Deluxe 28 Model 921022 St28le 2...
Procedure to start single stage electic start toro snow thrower
plug in Electric start. Push Choke to 'ON'. press Primer Bulb about 2 times. Turn Key to 'ON' Press Starter.
If you didn't run it completely dry of Gas last season I bet the Ethanol gas messed up your carburetor
Dec 15, 2014 | Toro Power Clear 621 ZE 21 163cc Single...
Fuel primer
The primer bulb fills the bowl of the carburetor on initial start-up. Most primer bulbs are depressed 4-6 times. Set the choke at half and either pull the starter cord four times. If it doesn't start, re-prime and take the choke off.
Mar 16, 2014 | Garden
Ariens snowblower problems
The snow blower does not throw snow. Snow jams up in the chute
Jan 04, 2014 | Motorcycles
Blowing white smoke
use a good gas additive and non ethynol gas
should clear it up
Dec 07, 2013 | Cub Cadet Snow Blowers. 26 in. Two-Stage...
Engine wont start
press the primer 5 or 6 times full choke and make sure idle lever is up a little when it starts take choke off one notch at a time then rev engine slowly
Dec 21, 2012 | Ariens Deluxe 28 Model 921022 St28le 2...
I have a Toro S620 snow blower, I push the primer bulb and it starts right up then dies. If I keep pushing the primer bulb continualy it will keep running but the moment I quit it dies.
The carburetor bowl needs to be taken off and most likely the float and needle need replacing. When you prime the carb, this is shooting gas straight to the carb instead of traveling though the jets. This is a very easy task, but I know if you're using a snow blower you need it quick. The kit is about $5 and be sure to take your machines info with you.
Dec 30, 2010 | Toro Snow Blower Scraper For S200 s620 New...
Craftsman 247 88190 0 snow blower auger frozen
my auger and impeller froze too. fixed by clearing all snow, ice,stone build up behind impeller it works fine now.. hope that helps
Jan 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Ariens 34 In. Zoom Series Riding Mower Logo
295 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
