Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Leaking oil Soonest I rtart the air compressor the oil is comming from 2 saffty holes in oil cover.
  • kent318 Apr 06, 2009
    same here oil leaking out of oil fill cap.
  • 3 Answers
You may simply have too much oil in the chamber.
Posted on Jan 17, 2009
I have a Ridgid 5 gallon stackable air compressor that when I shut the compressor off, all the air discharges from the tanks. Do you know what the problem is?
You don't say how old this unit is. I had an older one and it had a small rust hole in it's tank. Had to get rid of it because the tank was rusted bad on the inside. Also check all the lines as they could be leaking as well. Also the one I have now leaked air because the compressor was low on oil. I got compressor oil and its ok now. Do not over fill as it will blow oil all over.
Dec 05, 2017 | Ridgid Air Tools & Compressors
How can i fix my ec12 hitachi electric air compressor
This problem is caused by either the starter capacitor or the in-tank check valve. Ez to check. With no air in tank, start compressor; if motor hums or has difficulty suspect capacitor. If motor starts, partially fill tank and unplug the power. Check for air leaking at the pressure switch or air coming out of the air inlet (remove the air filter). If air leaking, replace check valve. If no air leaking, again let out all the from the tank and connect power. Allow the compressor to fill and shut-off. After the compressor fills, again listen for air leaking from the pressure switch unloader valve. If air continues to leak from unloader, replace the check valve. Good luck
Jun 11, 2015 | Hitachi EC12 Portable Electric 2hp Air...
Air leaking from holes in oil filler plug
There's a check valve in the air line between the compressor and tank that sounds like it's failed.
May 14, 2017 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
My craftsman air compressor #919176820 2 HP 12 gallon 200 max psi will not compress over 125 psi
If your compressor is oil-less type, most likely pressure is leaking past piston ring. To verify, remove cover to expose bottom of cylinder (unplug compressor and let out all air). With flashlight, examine the upper-most part of the cylinder (turn motor by hand till piston is at top of stroke). If top of cylinder is scratched, then pressure is leaking past.
For many years now, stores are in a race to have more HP and PSI to attract customers. Customer is really the loser because components used to make the units can not handle the higher pressure. Normally small 115v compressors are set to cut out at 125psi and larger two stage units will cut out at 160psi. Small compressor set to 200psi makes for short lived compressor. Could be compared to driving your car at 100mph all day every day. Longest life is attained when unit is being used at about 60 to 75 % of capacity.
To allow your compressor to reach cutout pressure and keep working for a while, lower cutout to 120psi (pressure switch may be adjustable). To restore to 200psi, replace cylinder/ ring.
If your compressor is oil type, suspect leaking reed valves.
Nov 27, 2011 | Ingersoll Air Tools & Compressors
Head gasket leak but I found out that this part is no longer made due to non production its a centeral pneumatic oil less air compressor 99781,I was letting my air compressor build up air pressure when I...
If it is a head gasket leak and no gasket available. I would make one. You will need to buy a piece of high temp gasket material like garlock and it needs to be the correct thickness as the old material/gasket. Remove the old gasket and trace out a new one and cut it out. Or you can locate 2 bolt holes one on each side of the head put 2 holes in the material and use the bolts to hold it in place. Use a small hammer and tap around the edges. If done correctly while tapping it will cut the material. you can do bolt holes, the complete gasket like this.
Jul 17, 2011 | Air Tools & Compressors
I've got a compair 660A air compressor and have oil leaking out of the body of the oil pump cover.
I didn't think this was a pressure lubed machine. Is it leaking around the shaft seal, behind the flywheel? If it's just the oil leak, and the unit runs/sounds fine otherwise, you could put a gasket and seal kit in it.
You can search online for parts, but probably have better luck calling it a LeRoi 660A. Compair bought them years ago, and let the piston compressor business slowly die.
Mar 15, 2011 | Air Tools & Compressors
The oil dip-stick is blown out of its seat when the compressor runs
Without knowing what make or model you have, check the following:
1. Some, not all, compressor dip sticks have venting holes for the crankcase. If the vent holes are plugged or the check ball is stuck the dip stick will get forced out when the piston comes down.
2. Make sure the oil level is where it's supposed to be. Too much oil in the crankcase will cause the motor to work harder and the excess oil being splashed around the crank case can overwhelm the vents in the case or dip stick and again blow the dip stick out.
3. Worst case, you have worn or broken rings on the piston(s), a hole in a piston or a badly scored cylinder(s) and air is leaking past the piston and creating pressure in the crank case and blowing the dip stick out.
Jan 26, 2011 | Campbell Hausfeld Air Tools & Compressors
The motor is running. Belts and pulleys are turing. oil level is good. No leaking from tank or conectionslbs. Motor runs contiuously tank Air pressure will not rise above 25-50.
While the compressor is running and has reached point of not attaining higher pressure remove air filter and place your gloved finger over the intake hole (be carefull may be hot). If compressor is working properly you will feel suction, if however you feel air blowing out of intake most likely blown head gasket /s and or broken reed valves. Easy to fix however, look for parts at mastertoolparts.com
Nov 03, 2010 | Coleman 6.5hp - 80 Gallon Vertical ASME...
Compressor pumps up fine but then leaks air just below the relief valve. out of a small factory hole in a brass fittting and goe down till compressor starts again.
When the unloader leaks as you describe indicates that the check valve is leaking. Easy to check the condition of the valve. Follow air discharge line from compressor head to tank. The brass or steel fitting that threads into tank is the checkvalve. Remove all air from tank and remove large inspection cap to reveal the teflon seat. If it is cracked or swollen you will need to replace the valve. Parts available at www.toolpartsdirect.com Good luck
Sep 25, 2010 | Hitachi EC12 Portable Electric 2hp Air...
The check valve is leaking on my stanley bostitch cap2000p air compressor.I was trying to take it out to check it or replace it,but,it was so tight in there it broke off while trying to get it out. I need...
If you are talking of the clamshell cover, MANY plastic covers big and small have a few screws and then have molded "rods" on one side and a mating hole in a boss on the other. For these, one has to CAREFULLY pry them apart EVENLY so all seperate evenly..
Apr 28, 2010 | Stanley NEW Bostitch 2 HP 6 Gallon...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
156 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
