Question about Samsung SlimFit TX-T2782 HDTV
Problem with sumsung tx-t2782
The tv does not turn on and the red standby light is off.
  • rare_48192 Mar 18, 2009
    no POWER..period! Took it in to service would cost 148.00 to fix compasater and thermaster.. IT IS ONLY 1 YEAR 5 MONS OLD... IM SO MAD I COULD SPIT... told SAMSUNG I WILL NEVER BUY THERE PRODUCT AGAIN!!! paid almost 400.00 for this and in this short amount of time...i will NOT SPEND ANOHTER 150.00 TO FIX.... THIS JUST SHOULD NOT HAPPEN!!!! I've had it with samsung! Linda
Compasater / thermaster
Posted on Mar 18, 2009
    compasater & termaster...AND $148.00 !!! total BS for this TV
Panasonic TX-P42X10B wont turn on - goes into standby
Hard to troubleshoot with just this info, the red light can be helpful if its 10 blinks repeating over and over replace the power supply first then the A board. Voltages check on the power supply would narrow down the culprit.
Post again if you measure the power supply voltages
May 03, 2012 | Televison & Video
I have a samsung tx-t2782 with red green and blue pinstripe running horizontal across top of screen. not a ground loop and theres no magnetic interference.
hello spins,
If your problem just pinstripe on top of screen , but picture ok (normal in picture), try it to enter the factory mode. In standby position press info-menu-mute-power. Enter to deflection adjustment- choose - vamp (VA) or v shift (VS). Change value data by pressing + (or right cursor) and - (or left cursor) to shift or increasse amp. If it work, your tv will normal.
But its nor working, you should call samsung technician.
Good luck.
Mar 30, 2011 | Samsung SlimFit TX-T2782 HDTV
My television is a Samsung Slimfit tx-t2782 and I'm having problems with the tv staying on. Everytime I plug it in it comes on for a few seconds it shuts itself off. I was wondering if there is anything I...
I AM HAVING THE EXACT SAME PROBLEM WITH MINE ! But before mine turns off, it shows a blurry squiggly red mark on the screen then shuts off and wont turn back on sometimes for several hours.. And everytime I CAN get it back on, I have to unlpug the whole thing and plug it back in...
Nov 09, 2010 | Samsung SlimFit TX-S3082WH 30" TV
SlimFit HDTV TX-T2782 TV will not turn on
are you outlets functioning properly? if yes and your sure its the tv, then it sounds like the power supply in the unit has gone bad, or it make be fused, which in that case you would just need to reset it or replace the fuse. I would try trouble shooting on your on first, as a repair can sometimes cost as much as the unit
Mar 09, 2010 | Samsung SlimFit TX-T2782 HDTV
Samsung TX-T2782 Slimfit TV, power turns on, but no video, audio still working.
Resolder the video board that have the long neck CRT(tv tube)have holes connected to the board.
Nov 23, 2009 | Samsung SlimFit TX-T2782 HDTV
Tv turns off after about 20 secs.
Sounds like a bad inverter. Does the screen still show that the power is on? If so, then shine a bright light at it. If you can still see the image, then you have your answer.
-=/ Daft Tech /=-
Oct 23, 2009 | Samsung SlimFit TX-T2782 HDTV
No power, TV set just died after 1 year, brought brand new.
my samsung tv has been by lightening ( model tx-t2782) what are the steps to testing voltages in different areas.
EMAIL: shadowsolution_6000@yahoo.com
Sep 07, 2009 | Samsung SlimFit TX-T2782 HDTV
Tx-t2782 tv will not come back on
I tried unplugging and plugging again and again but no luck... the TV shows no signs of life.
Jan 08, 2009 | Samsung SlimFit TX-T2782 HDTV
TV won't turn on
Shorted problem. Maybe in primary or secondary power supply. Need a repairman. Busted regulator, or shorted diode.
Apr 17, 2008 | Samsung SlimFit TX-T2782 HDTV
Samsung SlimFit TX-T2782 HDTV Logo
660 people viewed this question
Henry  Thomas
Henry Thomas
