Question about Sony Handycam DCR-TRV330 Digital Camcorder
Receiving error C:31:42. Removed tape, battery, and left opened, but still get error
Receiving error C:31:42. Removed tape, battery, and left opened overnight to remove any condensation, but still get error. Used a different tape, but that didn't help either. Users manual indicates these are the steps to follow. Any suggestions?
  • Judy Srail Jun 19, 2007
    I'll try that. I only left out over night. Thanks.
Help my camera has never been near water or anything and i have the same prob :(
Posted on Sep 20, 2008
    Problem Solver:
  • 15 Answers
How long did you leave it to dry? I had a similar problem and had to leave out my camera for more than a day before the problem was resolved.
Posted on Jun 19, 2007
SOURCE:
My espon stylus sx425w give this error code e01.
If you are just using your printer for the first time, you're receiving this error because there are still protective covers that need to be removed to complete the unpackaging process. Look for small strips of lightly colored tape in the interior areas (where you load paper, ink, etc) and around the sides.
There's some tape on the left side that's particularly common to miss.
May 10, 2012 | Epson Stylus Office Equipment & Supplies
Condensation
Camera has a sensor inside to detect condensation
Condensation can occur if the camera is moved from a cold environment to a warm one.
So open the tape compartment, remove the tape to allow maximum airflow and wait for the camera to warm up
Regarding Condensation please wait
This message comes when your camera hasn't experienced a sudden change of temperature, this could indicate a possible fault.
Thanks for using Fixya
SAM ANDERSON
Sep 22, 2008 | JVC GR-D50 Mini DV Digital Camcorder
Condensation, operation paused, JVC...
Just turn off for half hour and then turn on it will clear
Jul 17, 2008 | JVC Cameras
B209a printer prints blank pages: test, diagnostic, word, etc. I have run all kinds of tests and printer is functionable, but pages are blank.
Check to be sure that the tape on the inkjet cartridges is pulled off. They come with tape to prevent them from drying out before you buy them. This tape needs to be removed before the cartridges can be used. If the tape is removed, have the cartridges been sitting in the printer without being used for months? Maybe the cartridges are dried out. You can try soaking the cartridge's print heads (the bottom shiny part that is rectangular (box) shaped, but not the electrical contacts) in rubbing alcohol overnight. Then re-install and see if they work. If not, you need new cartridges.
Apr 09, 2011 | HP Photosmart C6180 All-In-One InkJet...
Condensation please wait, and does not recoed, open tape door, and does not want to shut, will not record while this is happening, and there is no condensation in the camcorder
I purchased this camcorder used with the condesation error, it arrived in the mail yesterday, I researched the fix and without loosing any screws got it fixed. Here is what I did.
I plugged in the power cord, turned it to auto with the display screen open, the condensation error was blinking, I left it on for about 30 mins to one hour {didn't keep a tab as I was watching my favorite Tv show.} When I checked back the "condensation" error was gone.I then placed it on "off /charge" to charge the battery.
This is the next day and it hasn't return. It is almost unbelievable, the previous owner sold it just because of the error and I hardly did anything much to fix it. I am so happy.
Pecinno on Ebay
Dec 29, 2009 | JVC GR-D30U Camcorder
My Sony TRV118 displays C:31:23 when trying to playback or record. Have tried different tapes, left open for sometime, removed battery. All to no avail.
The camcorder has detected an issue that may require a power reset.
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
Aug 12, 2009 | Sony Handycam DCR-TRV118 Camcorder
C62 error code - NASHUA 8112RE
Is this right out of the box?? If it is, make sure that you have removed all the SHIPPING SCREWS. Check for the one that holds the optical scanner. If this screw is left in the scanner will not move and cause error. ---should be on left side or under left side of optical pan. If all shipping screws are removed, do a once over and check to make sure that all shipping tape and paper are removed. Some companies use tape to hold parts in place.
Jan 03, 2009 | Office Equipment & Supplies
Sharp Viewcam VL-E66U
I let it sit overnight and when I opened the door I nudged the part that holds the tape up. I got the tape out but I think it is still frozen. I will try a different tape and hope it still works. I'll post results.
Thanks
Kate
Sep 07, 2008 | Sharp Viewcam VL-AH151U Camcorder
Sony TRV460 error code C31:22
Manual says probably condensation - see page 121
Dec 11, 2007 | Sony Handycam DCR-TRV330 Digital Camcorder
"Push the reset switch"
I had the same problem with the 'push the rest button' on the display after the tape mechanism jammed up against the tape compartment cover. I figured there was probably a mechanical error, possibly a switch. I dissassembled the camcorder and found the tape compartment cover switch was sticking. Here's how to fix it with some photos to illustrate:
1. Open the tape compartment door and remove the screws in the small plastic cover (fig. 1). Remember to look a which screw came from each hole as they are all different.
2. Remove the plastic part from above the tape mechanism (fig. 2)
3. Remove the screw above the front grip belt mount (fig. 3)
4. Remove the screw above the mic (fig. 4)
5. Remove the battery and take out the screw at the top left under the viewfinder (fig. 5)
6. Take out the screws under the LCD monitor (fig. 6)
7. Remove the two screws from the front underside of the camera body (fig. 7)
8. Now you can slide the front of the camera, together with the curved aluminium top section away from the main body of the camera (fig. 8)
9. It is possible to reach the switch with the front moved forward slightly, but it is possible to take the front off entirely by removing the wiring ribbon with the green tab (fig. 9)
10. Clean the brown switch at the bottom left of the exposed camera front with a soft brush/air (fig. 10 )
11. Reassembly is the reverse of the above procedure.
Hopefully this will mean no more frustration with the 'press reset button' screen.steviedeee.jpgsteviedeee_0.jpgsteviedeee_1.jpgsteviedeee_2.jpgsteviedeee_3.jpgsteviedeee_4.jpgsteviedeee_5.jpgsteviedeee_6.jpgsteviedeee_7.jpgsteviedeee_8.jpg
Jan 21, 2007 | Panasonic NV-GS15 Mini DV Digital...
Sony Handycam DCR-TRV330 Digital Camcorder Logo
840 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
