Won't turn on
I was using my computer all day fine, went to work for a couple hours, and come home to my computer not turning on. The adapter is plugged into the wall, I've tried several outlets, and nothing happens when I turn it on. Even with it plugged in, no lights are showing that it's plugged in, like it usually does. I need help please!! Dell Laptop won't charge. I can't even get it to turn on with the power cord in. It was working fine while plugged in, then it automatically switched to battery power while still plugged in. The battery lasted about 50 mins (which is normal) now I can't get it to run again.
  • BleedinGreen Jan 27, 2009
    I bought a new ac adaptor and problem solved.
    Genius:
  • 1,102 Answers
How old is the system
could be your internal plug for ac may have become lose from plugging and unplugging
or you may just need a new ac cord
try moving it around where it plugs into the laptop if you get a brief connection then it probably is the connection inside the laptop they can be replaced
Posted on Jan 16, 2009
  • DEKR
    DEKR Jan 27, 2009
    okay
    anytime not a problem except i suggested it that you may need a new ac cord if it's not the internal connection
    the new cord solved the problem and you gave me thanks for tryin
I have a 2000 Volvo s80 t6 it was running perfectly fine 2 days ago yesterday I went to leave and the gear shifter would not shift out of park, a couple hours later in tried it again and it worked, it was...
sounds like the solenoid or the relay that locks the lever into park when the key is turned off may be playing up just to check try using the spare key see if you get the same problem hope this helps regards mick
Feb 28, 2015 | Volvo Cars & Trucks
96 GMC Yukon won't turn over
Thats what i would try and if that dont help, maybe check the connections at the starter.
Feb 18, 2013 | 1996 GMC Yukon
1995 miata cranks but won't turn over
Possibly the fuel pump or crankshaft sensor
Oct 20, 2012 | 1995 Mazda MX-5
About 2 weeks ago my check engine light came turned on so i drove home and told my dad about it but when we turned the car on it did not flash. But the the next 2 days it stayed on and the next morning...
Any time you get any check light, you should
be at a repair in a couple of days, or at least
check for codes. Still need it diagnosed and
repaired in a week
Otherwise you waste gas,polute the air or could
cause some damage,as you don't know what the issue
is that set the light
The fact the check light went out, doesn't mean
the problem went away.
Don't clear any codes you find,their needed to diagnose
the system faults
Apr 05, 2011 | 2006 Mitsubishi Eclipse
What does it mean when i turn my laptop on the screen is white.
I can't tell you what it means but it happened to my laptop this morning.
After reading tons of "solutions" nothing worked. Finally, I turned it off, went grocery shopping for a couple of hours and when I came home and turned it back on and it seems to be fine.
I am, however, going to make a recovery disk like the computer has been suggesting since I got it.
Dec 16, 2010 | Epson Viewsonic ViewPanel VE150M Monitor
HP compaq 6735s Shuts facing a very weird problem concerning its power. I have left my laptop charging without use for 3-4 days, today I came back home and wanted to use my laptop, I turned it on and...
Looks like your battery is having a problem. Remove the battery and replace after a couple of hours. If problem remains replace the battery with another to test, if this works, then the problem is with the adapter unit. Get a new one.
Nov 19, 2010 | Computers & Internet
Car turns over but will not run idles rough then stalls degreased engine was able to get running took for test drive ran fine went home let sit for couple of hours went to drive it again turns over but...
sounds like you got the thing wet....DO NOT PRESSURE WASH/STEAM CLEAN ENGINE COMPARTMENT.leave the hood up and hopefully it will dry itself out,or if you can start it, let it run for an hour at least on tickover with all electrics on and a/c on full.A NICE SUNNY DAY WOULD ALSO HELP.....
Aug 18, 2010 | 1994 Lexus GS 300
Acer Aspire One
We have two that went "Dead" like that too. Acer knows all about the problem of losing video. They have a BIOS update that they will send you on a flash drive. Give them a call, have your computer handy to give them numbers and in 3 o 4 days you will e up and running with your Acer One. They are a great little computer. By the way, you will not loose Windows 7 which I am using on my desktop right now. It's better than Vista.
May 28, 2009 | Acer Aspire One PC Notebook
Won't turn on
Sometimes it is the battery not holding the vharge. If that is not the case then it most likely is the adapter connector on the mother board where there could be a broken solder connection or the connector itself may be broken. I had the same problem with my hp laptop and disassembled it abd found a broken solder connection to the motherboard and the adapter connector. I just made a solder connection where it was broken and everything came on normally.
Jun 10, 2008 | Computers & Internet
Computers & Internet Logo
146 people viewed this question
David Payne
David Payne
