Question about Ovens
Conrol board has 120volts , suppose to be 220 according to repair
Thermometer was good and the light inside oven works but clock is black and all controls black.
Chat Dan gave me this part # for my oven.
AP4102875 Whirlpool part for Maytag  wall oven cwe9000bce -
Is this correct part?  and how do I install it AFTER I open the oven again?
Thanks.
 Deb
  • 86 Answers
SOURCE: GE Double Oven doors locked and circuit not responding
Hi, well this is a brain tester!! I think you need really to look at this in a simple way. Check to see where the door lock wires come from first? Find where the mains power comes into? then if it goes directly to the main control board then check to see if there is any power getting through the board to the otherside where the wires disapear into the cooker. I would consider checking the control board for any signs of burn damage and then look at the clock unit to as these are normally the main components in the cooker that will stop it from working.
Good luck,,,,,,,,,,,,,,,
Posted on Jan 02, 2009
SOURCE: dim light on oven display w30400b jennair
The circuit board is for the display/touch panel. It is mounted on the back of the display panel itself and connected to the other circuit boards by two multipin connectors. When you remove the display panel (3 screws on top, 4 on the bottom) you will be able to GENTLY detach those connectors. They are low voltage and may be handled safety even when the oven is powered, but I agree that turning off the oven circuit breaker is good practice.
To remove the circuit board, GENTLY release the two black plastic tabs; the solder pads are underneath. I too used a 100 mf capacitor because no local supplier had a 68 mf hi-temp. Observe polarity; the (-) lead goes towards the center of the board (away from the edge connector.)
BTW, I had exactly the same symptoms (display goes dim, then goes out altogether.)
Posted on Jan 22, 2009
kachbibi1
  • 979 Answers
SOURCE: Maytag oven needs temp calibration
Take your temp knob off and look in the center of the stem and you should find a small set screw. Using a small precision screwdriver, turn the screw until you see the light come on. (You won't have to turn it far.) Turn it a little at a time, maybe a 1/16 of a turn. Leave your thermometer in the oven with the door closed and at or near the temp probe that is in the oven. This way, you are getting a true reading.
Posted on Feb 15, 2009
farfield
  • 462 Answers
SOURCE: oven wont work but clock still works
First make sure you didn't trip a breaker. You could have power for the electronics on one side of the 220V and that is why the clock still works. Turn off the breaker and then back on even if it looks on. If it does this again you have a sever problem that will require a service call. If the breaker is tripping it could be other than the oven and if so a new one will work ok unless itsin your wiring.
If this helps you please ratre me accordingly Good luck.
Posted on Mar 12, 2009
  • 42 Answers
SOURCE: Whirlpool Double oven control panel
Sounds like you may need a new control panel
Since the keyboard and the control panel cost about the same ($150) get them checked befor you order any parts.
keyboard - part # 8300440
control board part # 830219
Posted on Aug 11, 2009
Oven
We had a 1980's wall type oven that would not control the heat any longer. It had an electronic digital control board , the clock worked fine. To replace the oven new was like $700. We had a Sears repair guy come and he said to use the internet to find a replacement control board. After extensive research using the numbers on the board itself I found a company in Canada that does repairs, (there were a couple of companies offering this service, I can't remember why I picked the Canadian company) they explained that using a new replacement may just give you another board with the same weakness built in. This made sense to me so I took a chance and mailed them the board (shipping to Canada was a bit high) got it back in a couple of weeks, took 5 minutes to re-install and its working great. The repair was just under $140 plus shipping.
Apr 17, 2014 | Ovens
Probe light on convection oven stays on. Clock won't display. Oven still works though.
Sounds like the control board is not communicating correctly with the rest of the unit, consult a professional.
Aug 10, 2012 | Frigidaire 30" Built-In Single Electric...
Oven temp heats higher than set
The control board is bad. One of the relays has fused and you will need to replace the control board.
Jan 07, 2012 | General Ovens
My GE wall Oven Model #jctp18ba1bb is not working.the board is blankm the only thing that works is the oven light.Is there any kind of thermal fuses etc. in this oven.thge control board was replaced 8...
When you say board I assume you mean the electronic clock/timer. This timer directly affects the oven operation. Even if the internal oven fuse is blown or the thermal overload is tripped the electronic timer and oven light will always work. If the oven light works and the electronic timer/clock does not I'd say that the timer/clock is faulty.
Feb 10, 2011 | GE Profile 30" Built-In Single Electric...
Fried a new oven
black is 110.v red is 110 v =220 volts white to center terminal . bare to frame of oven .. the damage could be to the pc board and the eoc ( clock) any fans ect . it may be more than you want to spend .. panel is 155.00 the clock is 155.00 fan 70.00 . you may not need all of this ., oven cost 764.00 / repair it .. mm /
Dec 03, 2009 | Maytag MEW5527D Electric Single Oven
I have a Whirlpool double oven (model RBD275PDS14). The control panel goes blank about every 2-3 months, and the oven won't heat. Although, the light inside the oven will still work. When the panel lights...
Your error code is for a stuck keypad. You can try pressing every button at random several times each to unstick.'
When the control board is changed on these ovens the keypad assembly is supposed to be changed also.
Nov 21, 2009 | Whirlpool Ovens
Oven wont work but clock still works
Mar 12, 2009 | Belling XOU252 Electric Single Oven
Display light faded and now gone
Supposedly the electrolytic capacitors on the display board need to be replaced. See: http://applianceguru.com/forum1/18842.html
Jan 15, 2009 | Thermador SC302T Electric Double Oven
Lighted clock and controls intermittently not working. Oven still heats
HI thanks for the question. its a common problem with the clocks. first it goes a little dimmer. then a little more till it goes so dim you cant even see the temperature that you have in the oven. the clock has to be replaced. or. buy a cheap oven thermometer. and hang on the middle rack, and adjust the temp setting to match the oven temp . save a lot of money this way. thanks. please rate my answer. thanks
Oct 09, 2008 | Jenn-Air Ovens
Oven seems to be going crazy
You may have a problem with the keypad. I suggest that you review my solution at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this with over 1470 folks and most report success.
If it works for you please let me know at the following site:
hutchipop@yahoo.com
Good Luck
Dec 13, 2007 | GE Profile JKP18 Electric Single Oven
Ovens Logo
65 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
