My laptop wont charge - Computers & Internet
  • DEKR
    DEKR May 11, 2010
    do you get power at all to it
    Problem Solver:
  • 6 Answers
If your laptop isn't charging, it's usually one of two problems:
1) Your AC adaptor isn't working correctly anymore. It may be faulty, or may simply have endured all the wear and tear it can handle.
2) Your battery is either dead or dying, and is no longer charging correctly.
If the problem is your AC adaptor, a simple replacement will fix the issue. If the problem is your battery, then it gets a little more expensive (batteries usually aren't cheap).
Most laptops come with software to help monitor battery life and so on. Dell, for example, have their "Quickset" software, which can tell you if your battery is operating properly or not.
If you give me more details on the specifics of your laptop, I can help more. Manufacturer/Model?
Hope that helps.
Posted on Jan 17, 2009
I bought a new battery for laptop and it still wont charge
Dell uses proprietary equipment. IF the laptop wont work when plugged in and it is the original Dell charger, you need to check the charger, if the charger wont work then the battery wont charge. Note that it might be the connection on the board inside the laptop especially if the cord got pulled on while plugged into the laptop.
Oct 05, 2015 | Dell Computers & Internet
Its plug in but battery wont charge
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Nov 28, 2012 | HP Compaq nc2400 Notebook
E-machines e442 wont charge when switched on, only charges when off
There is a possibility there is a problem in the DC jack to the laptop, but it would mean dismantling the computer down to the motherboard level to make the repair.
May 19, 2012 | eMachines Computers & Internet
Battery wont charge and laptop wont start using
Check the pin inside the connection (end of the cord) which you put into your machine, or check if the power connection on the circuitboard is damaged (you are able to wiggle it a little bit around)
Dell computer use the pin inside the connection from the adapter to recognise if the adapter you are using is a dell adapter or not. If the pin is damaged, or you are using an adapter from another brand. You will not be able to charge, but only power your pc.
Jan 04, 2010 | Medion Computers & Internet
E machine 510 wont charge!
Yes, remove the battery from the laptop.
Plug-in power adapter and turn ON laptop (without battery).
After the laptop starts up and Windows has settled, put battery back in the laptop.
Allow to charge for a few hours.
Oct 07, 2009 | E-Machines eMachines Desktop PC
Laptop wont charge at all, or turn on
hey friend . .
this indicates that your battery is finished just go and buy new or
the battery need a repair . . . its charged is over . .
Oct 06, 2009 | Computers & Internet
The screen on my laptop will not turn on, when i turn on my laptop the buttons light up but the screen wont come on.
your laptop is completely out of charge juice , charge it. if it is fully charged and still wont work, you need a new computer battery.
Jun 29, 2009 | HP Pavilion dv6000z Notebook
Laptop battery wont charge?
It could be the battery needs replacing ... it shows that the battery is charging but it doesn't keep the charge .....
May 23, 2009 | Compaq Presario 700 470024-192 Notebook
Battery wont charge
pls consult ur service center forthe problem & if this under warranty contact dell directly for this issue......................Sameerayan
Jan 17, 2009 | Dell Inspiron 6000 Notebook
Battery wont work
The battery is dead and it won't charge or hold its charge (all rechargeable batteries have a finite number of charge and discharge cycles). You need to buy a new battery, or just use the laptop connected to the mains supply.
Oct 29, 2008 | HP Compaq Evo Notebook N600c
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
