Question about HP OfficeJet 7110 All-In-One Thermal Printer
Hp officejet 7110 battery and cmos location
When I try 2 print any report it says supply expired, which means the ink is out dated, but I have heard that if I take the battery out for a day it will reset. Can U tell me where the battery is located? T.I.A. Magical1
  • 1 more comment
  • Magical 1
    Magical 1 Jun 23, 2007
    Hey dip stick i'm looking for a work around,not the obvious!
  • stoaway Nov 17, 2008
    Battery Location?
  • marc orlando Mar 07, 2015
    this is a question. Will removing the cmos battery wires as opposed to removing the battery also disable the ink expiration message?
  • 225 Answers
The battery is located behind the left front cover. Open the printer, grasp the left front cover from inside the printer and pull to open. Look inside the printer to left and you will see it.
It is enough to remove for a minute to reset the expiration.
But I'm afraid after that the printer may not keep the date and time when turn off.
Posted on Dec 17, 2008
I attached the picture of where the battery is....hp officejet 7110 battery and cmos location - 3debdc9.jpg
Posted on Jan 05, 2010
THE SOLUTION from Dimitar Todorov WORKS! Looked for a full day and tried several solutions suggested by HP, other sites and here. This is only one that worked for me. Had the "expired Ink cartridge" message showing for both black and color cartridges. Hell, after nothing else worked, I thought I was going to need a new printer. Then I found Dimitar's solution. THANK YOU.
Opened the Carriage latch. Unplugged the power. Pulled the front left cover off as directed. Had to orient myself to the correct direction to look from the picture. l Found the battery. Slipped a business card between the contact and the battery for about two minutes to disconnect. Removed it, reconnected power and closed the carriage. Was easy to reset the correct date and time by going into menu for fax setup. "Expired Ink" message was gone (apparently, battery power keeps it in cmos when powered down). My 7110 works/prints fine now using the same cartridges that had been previously labeled as "expired".
Posted on Nov 02, 2011
  • 432 Answers
Have you tried changing the ink cartridges? Ray
Posted on Jun 20, 2007
  • aj2356 Sep 10, 2011
    The whole idea is to prevent HP from extorting more money from us through requiring us to buy products that we do not need.
How to troubleshoot printer
Printer icon still in ur computer,u tried to print a page,printer beeps or shaking of gears about to print,but never did?Yes.How long is the inks cartridge or cartridges been in ur printer?Like a year?Yes.Doesn't matter how many pages u printed even only few pages,the the inks cartridges is dead,it out dated and the cartriges it dry up.Requiring new inks cartridges.Pinters manufactures all of them make their money not on the printers hardwares,it so cheap alot of printers like they giving it away,but the inks cartridges themself cost u like $40 to $50 bucks for a pair of inks cartriges and the expiration date only a year.That if only u printed like 40 pages or less or those cartriges will run out inks before the expiration date.
Jan 27, 2011 | Televison & Video
The yellow won't print at all in test print. It is a new cartridge. The rest print fine.
When you say it is a new cartridge, do you mean fresh off the shelf with a good expiration date or just opened out of the box? Ink cartridges will go bad in the box sealed and unopened over a period of time. Check the expiration date on the box even if recently purchased.
Jan 02, 2011 | Brother MFC255CW All-in-One InkJet Printer
The ink cartridges keep expiring and they are nearly all full .my machine is a hp photo smart 3310 all in one.How do i by pass the expiry dates on cartridges
Each ink cartridge has an expiration date to protect the printing system and ensure good ink quality. The cartridge expire date appears on line 53 of the self test report.Printing can continue without replacing the ink cartridge. Follow the instructions that appear on the HP product or on the computer. However, HP recommends replacing the expired ink cartridges. HP cannot guarantee the quality or reliability of expired ink cartridges. Service or repairs required as a result of using expired ink are not covered under warranty
As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. Reset the product
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ).
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button .
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 16, 2010 | Office Equipment & Supplies
How to use ink I have purchased?
i don't know what printer do you have, but HP print cartridges are resetable, just find it on google, type your printer type and reset cartridge
Jul 10, 2009 | HP Office Equipment & Supplies
HP Officejet 9110 empty or expired cartridge error
You were a bit vague in your report as to what the exact error is that you are plagued with. Perhaps you have more than one. The 9100’s ink cartridges are “smart cartridges.” They each have a chip in them that reports various cartridge statuses directly to the printer. Diagnosing the problem correctly requires the identification of the particular error message. You can find a list of the error messages and what they mean here:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=376170&prodTypeId=18972&prodSeriesId=376170&objectID=c00067620
I think that you are experiencing an “INK CARTRIDGE EXPIRED” error. This error is not related to the ‘volume’ of the ink within the cartridge(s) but rather to the actual expiration ‘date(s)’ on the cartridge(s). The expiration date is encoded on the chip that resides on the cartridge. The actual expiration date appears to relate to the date two years after the date that is stamped on the cartridge label. I can’t change the expiration date on the chip—at least not easily or inexpensively—but I have discovered a way around it.
The date on the cartridge corresponds to the date on the printer itself. You just need to send the printer back in time to a period before the expiration date and you should be able to print again. A time machine is probably out of the question. Instead, reset the date on the printer to reflect a suitable date.
This could conceivably have some negative consequences that I haven’t experienced yet. I’ve only just discovered this ‘hack’. Though I haven’t tested it, the newly assigned, incorrect date will probably appear on any subsequently received fax transmissions. I can also conceive of networking issues if your printer is networked. Some network related instructions require that all network nodes (all devices on the network—computers, printers, etc.) report a time (and date) within just a few minutes of each other to communicate. You’ll just have to try it in your network and see if everything functions properly or within acceptable limits.
To change the date on the 9100 printer, you’ll need to access the ‘Maintenance’ menu. Just below the LCD panel on the front of the printer there are a series of buttons as follows:
[Return], [Up] & [Down], [Accept], [Left], and [Right]. They each have their own unique symbol, but I’m sure you can understand my descriptions. Press and hold BOTH, the [Up] and the [Down] buttons at the same time while you press and release the [Accept] button—then release the other two buttons. If you weren’t taken directly to the ‘Maintenance’ menu (# 10), then use the [Up] or [Down] arrow button to navigate to it and then choose the [Accept] button to select it. Similarly select the ‘Set date and time’ option, and follow the prompts to make the necessary changes using the appropriate buttons.
Once you have changed the date and time you may have to turn the printer off and then back on again before the printer will recognize the cartridge(s). In my case, the printer went through an extensive print head alignment.
Jan 27, 2009 | HP Officejet 9110 All-In-One InkJet...
Supply expired
You can't. Cartridges have a date bomb built in, they may be expired.
Jan 20, 2009 | HP OfficeJet d145 InkJet Printer
Officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Aug 07, 2008 | HP OfficeJet D135 All-In-One InkJet...
Change all ink message
Your Lexmark cartridges may be like my HP ones--they have a chip that the machine reads so they cannot be reused without doing some tricks to fool the printer.
My HP remembers the last 2 or 3 cartridges and also will not use ones that have passed the expiration date that is stamped on the cartridge. I'll tell you what worked for my HP.
Check the date on your ink cartridge.  I bet it has expired. If you put in a "new"cartridge but it is even an HP one with an older date, it may not work.
I had my printer stop in the middle of a print job.  It was printing fine and suddenly would not print.  So I refilled the cartridge with an ink kit I had on hand and reinserted it--no go!  Then I opened a remanufactured cartridge I had bought some time ago and inserted it.  No go, despite the fact I could see ink coming from the jets.  I finally gave up and bought a new HP ink cartridge, and it worked just fine.  But it bugged me why the new one would work and the other two that seemed just fine would not.
Later I learned that HP has a chip that reads the expiration date on the cartridges and that is what keeps those old ones from printing.  I found one trick of setting my date on my computer back to a year earlier than the exp date on the cartridge.  I saw the date on the remanufactured one I had tried earlier was 2005, so I set my computer date to today date but year 2004.  After forcing me to do print alignments several times and take the remanufactured cartridge out and put it back, I got it to print just fine.  And that 2005 cartridge that would not work earlier is what I am printing with right now.
Be advised, though, if you try the date setback, that HP printer will buck and try every way to not let you use that old cartridge.  You must say no to reflashing if HP tries to pull that on you.  And you will take out and put back that same cartridge multiple times and keep printing alignment sheets 3 or 4 times before you are successful.  But, if you persist, you can get it to work.
Oct 25, 2007 | Lexmark X63 InkJet Printer
Printer
Top Solution thanks - Take that HP!
Slight amendment as battery is hard to remove:
The battery is accessed by opening top then can be seen on extreme left at front. No need to take it out, slip a strip of plastic like an old credit card under the clip on top of battery to insulate it. Then do a soft reset (# and 6 and power down) with the battery insulated. Power up - Power down, remove insulator power up. Eureka!
Jan 24, 2007 | HP Officejet 7130 All-In-One InkJet...
HP OfficeJet 7110 All-In-One Thermal Printer Logo
2,609 people viewed this question
Clive
Clive
