Question about JVC AV-48WP30 48" Rear Projection Television
JVC 48" rear projection AV48WP30 is HAUNTED
Great picture, have had the set for two years, no problems. all of a sudden it turns on and off all by itself, have had house power checked, its good, have put on different elec circuit, no change. I have an Onkyo home theatre with subwoof directly behind the set...causes no interference. We have the original JVC remote and the Onkyo remote, which is what we use to control the home theatre, JVC CD/DVD player, and the haunted TV. The set will turn off repeatedly, it also turns itself on in the middle of the night, no alarms set or anything like that. The home theatre obviously is not powering on with it so we dont know when the TV is on at night, unless i have to make a pit stop in the middle of the night, and find it playing to the invisible man! HELP !!
  • michael OConnor Jun 20, 2007
    Bill. Thanks for the reply, really appreciated. While relaxing watching my favorite show, with one eye closed....I decided to remove the batteries in both remotes, still happened. In fact last night the thing was turning off and coming back on, a new tactic. I am calling the repair shop today, cant take the "inconvenience of actually having to get off the couch to turn it back on" !! what a society we have become.... I will post whatever the resolution is for future owners of this set..Thanks again Mike O'Connor AKA "Losing Sleep"
  • 934 Answers
Dear Losing Sleep, The symptoms you're describing sounds like a bad tac switch or two. You might notice a bit of a pattern also, consistent with temp changes. (ie: up in the early AM when house got cooler, and bingo set is on). It's not an expensive repair. Tac switches are an item under a buck a piece. However, this is NOT something you want to tackle yourself... This TV is actually built to self destruct if a less than educated tech opens the back. If you remove the rear cover while the power is on you will destroy all DVI programing inside the DVI (Digital Input Module). The only way to restore the programming is to send the unit to JVC. There is a light sensor inside the TV and when the back is removed with the power on the data is erased from the eprom. You might even take it an extra mile when calling around to find a shop to work on it by asking if they know the correct procedure for opening the back of your TV - - If they do know their answer will be something like this: First turn off set and remove power cord then short pins 1 and 2 on the SB connector of digital input module. Before replacing the rear panel remember to remove the short on the SB connector. Do not turn power on until the rear panel is inserted into the cabinet. If you have to work inside the set with power on remove the two cables going to the DVI module. When you find the right shop take the unit in yourself - you'll save a few bucks that way. Hope this helps. Bill
Posted on Jun 20, 2007
We have an AV48WP30 JVC TV. It has a convergence problem. We followed the instructions posted on the website. When we pulled out the board we discovered the chips were STK392-180. Aren't they supposed...
Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy the whole convergence kit for the repair,yes it cost alots more than most placed,but it put togetther by the professionals reparing thse DLP tvs for years.The kit's will be gaureentee have the wright 2 STK chips and all those resistors,pico fuse most often burn too.The kit also came with a instructional DVD.
Nov 19, 2010 | JVC AV-48WP30 48" Rear Projection...
The picture is not clear-the colors do not line up-they are not aliened
Convergence failure is causing that. You can get the AV48WP30 Convergence repair kit from www.tvrepairworld.com the kit contains the IC's Resistors and the CD with step by step repair instructions.
Aug 15, 2010 | JVC AV-48WP30 48" Rear Projection...
JVC AV48WP30 Projection TV..Half picture distorted and flickering
Ur convergence is dead.Must replaced the 2 convergence ICS and all it resistors.The shop will cost U $300 for parts and parts.
Feb 10, 2010 | JVC AV-48WP30 48" Rear Projection...
Jvc blue color wont align
The AV48WP30 convergence repair kit from www.tvrepairworld.com should repair that issue. The kit contains the parts and the Cd with detailed instructions.
Jan 14, 2010 | JVC AV-48WP30 48" Rear Projection...
I have jvc av-56wp30 all of a sudden the red in the picture is doubled. any ideas what that could be?
That sounds like a convergence failure. The AV48WP30 convergence repair kit from www.tvrepairworld.com should solve the issue. The kit contains the components and the CD with instructions.
Dec 14, 2009 | JVC AV-56WP30 56" Rear Projection...
Our TV has, almost what appears to be, a double, colors are shadowing
You can get the JVC AV48WP30 convergence repair kit from www.tvrepairworld.com which should repair that issue. The kit contains the parts and detailed instructions on CD
Nov 23, 2009 | JVC AV-48WP30 48" Rear Projection...
I have a 48 inch projection tv that gets a scrambled picture when you turn it on. is it trash or is it worth getting fixed?
its most likely the flex converter module
its still worth getting fixed these sets have a great picture unless your just ready to replace it
Oct 30, 2009 | JVC AV-48WP30 48" Rear Projection...
Split color red blue
THE JVC AV48WP30 convergence repair kit from www.tvrepairworld.com usually will fix that issue. The kit contains the parts and the CD with detailed instructions.
Sep 28, 2009 | JVC AV-48WP30 48" Rear Projection...
I need access codes for jvc av48wp30
Press "Sleep Timer" on the remote, while "0 Minute" display on screen press both "Display" & "V.Status" @ same time, this should bring up the service menu....
May 08, 2009 | JVC AV-48WP30 48" Rear Projection...
I have a jvc av48wp30
you have bad convergence circuit.
Aug 19, 2007 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
97 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
