Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
1 ice cube gets stuck when the maker dumps ice
More often than not, 1 cube of ice gets stuck in the same spot when the maker dumps ice. since it freezes to one of the the prongs, for lack of a better term, it cannot refill to make more ice. we can't ever get a full bucket of ice. as soon as you pry the cube off, it immediately resumes making ice but this has recently started happening too many times per day to keep up with.
    New Friend:
Not level
Posted on May 15, 2013
  • 298 Answers
Look at the 2 blades where the cube sticks carefully.
My bet is that the blades are ever-so-slightly bent toward one another - or the factory remove-before-use lable remmnants are still on one of the facing blades.
If label is there, remove with edge of credit card. Don't force, USE NO TOOLS
If they are metal and bent, simply bend very slightly beyond parallel and check again until straight
If they are plastic and bent, bend farther than needed and let slowly loose. Check and repeat
Good Luck!
Posted on Jan 17, 2009
Shannon,
Stop being such a chintzy **** (you know you are, fatty) and buy a new fridge already.
Karma's a *****.
Posted on May 06, 2009
Water collecting in the water compartment
what is question as well as make ,model of unit
Nov 13, 2016 | Refrigerators
GE side x side When ice maker switch is on, freezer warms up
It sounds like the ice maker is stuck in the harvest ( dump ) mode , in the area of mold heater activation . This area , heats up the ice mold to unfreeze the cubes , and keeps rotating to dump the cubes . This heater , gets hot enough to actually burn you if you touch the mold .
I would remove the 2 screws holding the ice maker , unplug from the ice maker receptical , and replace the ice maker .
Oct 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Sep 27, 2009 | GE Refrigerators
The ice maker suddenly stopped making ice. The "arm" is down. Should it be up?
arm down ...Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 16, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Ice Maker stopped making Water Whirlpool model (ed5phexnq00)
Aug 15, 2009 | Refrigerators
Mod. GS6NBEXRS01 not dumping ice. there is ice in the ice-maker. the dispenser for the water working ok.
take the bin out and check for a jammed ice cube in the ice cube making mechanism. Many times they have a rotating finger that gets stuck on a cube that does not drop entirely. Hope this helps
Jul 13, 2009 | Kenmore 74252 / 74254 / 74259 Top Freezer...
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
Apr 27, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker "ticking" sound?
Mine started doing the same thing. The problem with mine was that the part that spins around to eject the ice is hung up... first, it was trapping an ice cube in it... I cleared the cube and it stopped making noise for a while, then a cube hung up again. Now I found that one of the 'teeth,' all the way to the right, was stuck under the housing... the part is bent, and needs to be replaced.
Check the part that spins to make sure nothing is stuck. Service is expected in home soon (I hope).
Jul 05, 2008 | LG LRFD25850 French Door Refrigerator
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
455 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
