Question about Alpine CDA-9856 CD Player
Problems with amp or stereo
I have the Alpine CDA 9856 CD Player and also have an amp my dad wired it up when he had the car i got the car and amp and all and the amp is working fine i guess its working fine from the rear speakers the front are un hooked but this only works on radio only if i switch it to a cd then no sound out of rear speaker and can only play on front speakers. so i need some help please.
  • 11,896 Answers
Check out www.installer.com
this site has your stereo's wire diagram.
The amp wires only go to the rear output (rca jacks on back of cd player)
It wont work right if it is connected to the front outputs on the back of cd player
Posted on Jan 16, 2009
Hi there I have alpine cda 9856 cd player and it turns on and does every normal however it won't output and sound on either radio or cd. I have checked for any bad connections and can't seem t
Did you make sure you have no shorted or grounded speakers or speaker wires? Make sure you don't have a bad speaker also. If everything checks out, you may have a bad internal output ic.
Jan 15, 2013 | Alpine CDA-9856 CD Player
I need to know how to reset the time and date on my Alpine CDA-9856 car cd player
all stereos have a PIN button
press it and this should reset the unit
or
disconecct the power
Dec 06, 2010 | Alpine CDA-9856 CD Player
What is the color code for sub woofer control on alpine cda-9856 wiring?
Well I found out on Pages 34 & 35 of the following Alpine manual:
http://vault.alpine-usa.com/products/documents/OM%20CDA-9856.PDF
The Remote / Amplifier Turn On is a Blue/White wire.
May 15, 2010 | Alpine CDA-9856 CD Player
Alpine CDA-9856 interrupt message
theres a wire loose, bring your car to an audio tech and he'l sort it
Nov 06, 2009 | Alpine CDA-9883 CD Player
Minimal sound output
Very well could be your amp setup. The only reason you would get lound sound from the stereo is if the mute is on or the audio outputs are fried. have you tried to hook up the stereo directly to a single speaker?
Sep 03, 2008 | Alpine CDA-9856 CD Player
I got a Alpine CDA-9856 car cd player. When I turn it from radio to CD or Ipod it turn my amp off.
do you have another amp other than the one built into the head unit?
try checking all of the wiring and make sure the RCA cables are connected.
Aug 24, 2008 | Alpine Car Audio & Video
Bass sounds only
That is tricky one. Did you try adjusting the EQ on both the stereo and the amp? Is the Mute turned on because it will act like that? Is both rca jacks plugged in on stereo and amp?
Aug 20, 2008 | Alpine CDA-9856 CD Player
Radio sound but NO cd or ipod sound
Radio is screwed.
But try these these steps:
Clean the eye of the head for reading CD. Must open up the radio.
IPod: check for good connections from Ipod to PCB.
Feb 23, 2008 | Alpine CDA-9856 CD Player
Sound Issues
The player has a built in safety device which only allows it to turn up so high. It help to avoid burning out your equip ment. Best way is to put sound on one device 3/4 ways up and then use the other device for adjusting the volume from there.
For sound in one channel; either there is a wire unplugged or not getting a good contact, or the player is set for mono instead of stereo
Jan 22, 2008 | Alpine CDA-9856 CD Player
Instaling alpine car/cd stereo cda 9807
Its probably your wiring harness that came with the stereo. Which can cause many more problems. alpine changed their wiring harness around that time. But they used the same plug, just wired different. So now there are crossed wires, but the plug fits, causing the amp chip to fry. maybe even further than the amp chip. an amp chip replacement runs about 80$ at a repair shop. if its just that.
Nov 18, 2007 | Alpine CDA-9807 CD Player
Alpine CDA-9856 CD Player Logo
165 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
