Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Will not come on light comes on 3 times and goes off witch borad
Do you heat up with a blow dryer
  • RCA Master
  • 8,617 Answers
Thats the classic sign of a bad flyback and the CP150 capacitor. You can get the 259296 flyback and the CP150 capacitor at the following link with instructions on how to replace the parts.
http://servicemanuals.vstore.ca/
Posted on Jan 16, 2009
Dryer heats up and blows air but is not spinning. What's up?
The problem most likely is a stretched or broken belt. This will have to be replaced to restore proper operation.
Feb 28, 2015 | Dryers
Blowing lint dust from the bottom
most probably blower wheel is loose on shaft,need to replace or shaft witch leads to exhaust is blocked by something creating a back draft in dryer
Apr 17, 2014 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer wont stay lit
if the flame is liting most likely problem is bad air movement.go outside with thedryer running and check the hood to see how strong the air is blowing out,if there's a cage or anything blocking the hood remove it,if the vent line is a long run remove the vent line from the back of the dryer,stick a leaf blower into it and blow out the lint to the outside.also with the dryer unplugged,remove the bottom panel,remove the lint filter and metal duct the filter slides into,clean that out and blow out the blower wheel with a shop vac,you can blow out the gas tube where the flame ignites to make sure it's clean blow off the motor and the cabinet and vac up all lint that blows forwards.you can try running the dryer with the vent line removed to see if it runs any better.when the dryer first heats up the flame will come on until the temp. is reached and it will shut down,one more thing to check,when gas coils start to fail you'll have heat for like the first 15 to 30 minutes,then when the coils heat up the ignitor will glow but no flame,after the coils cool down they will work again.how are you running it on timed dry or more or less dry,if you run it on auto or more or less dry there's a sensor inside where the lint filter is,try cleaning it up or try running it on timed dry to see if it runs any different,when on auto the heat comes on,when it reaches temp. the heat stops and the timer will advance,when it calls for heat the timer stops and the heat comes back on,it will do this until the clothes are dry.your model has an even heat board in it that can also cause problems but if the flame is liting it sounds like you have a block somewhere.go here this will tell you a little more about your model dryer.
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
May 23, 2013 | Dryers
Maytag gas dryer m# ldg9800aal. Heat element comes on each time I start the dryer BUT turns off after a few seconds each time. I hear a soft "click" each time it turns off. Heatl does not come...
Check your high limit on the heater housing. It could also be the light sensor on the side of the heater housing if it dont see light it will turn off the gas . Looks like a little glass window.
Sep 18, 2011 | Maytag Dryers
The dryer is taking a couple of ctlces to dry items. I opened the door and depressed the button, so that the dryer would run while I was checking for heat. The heat comes on but then after a couple of...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101'
Mar 12, 2011 | Kenmore 72802 Gas Dryer
My Kenmore HE5 dryer will not run without blowing an internal fuse. The repairman replaced the fuse, and it blew again. The dryer heats up but will not turn it's heating element off until the fuse blows....
Has any one checked the exhaust vent,other than a bad thermostat the number one cause for the thermal fuse to open is a clogged or restricted exhaust vent flow, the entire vent system needs to be checked ( not just the hose from the unit to the wall) for proper air flow. Turn the unit on TIMED ,AIR DRY (NO HEAT) and go outside to the exhaust vent and check the air flow,if there is any question as to weather the air flow is sufishent get someone out to clean the exhaust vent ,it always a good idea to clean out every few years regardless to help prevent build up of lint witch could cause a fire......Hope this Helps Good Luck
Dec 14, 2010 | Kenmore HE5 Electric Dryer
Kenmore Series 80 gas dryer, clothes take 3 hours to dry
Hello, This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safety valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Nov 04, 2009 | Kenmore Dryers
Not heating up
some times the heating coil breaks or the thermal resistor goes bad
Nov 02, 2009 | Bosch Logixx WFT 2806 Front Load...
Fan keep,s blowing
Your thermostat is calling for blower, your fan relay is stuck, or that model had a time delay blower solid state board on it which had the blower relay on it, and it could be bad. I would turn the power off to all of your system for a few minutes and see if this could make something happen.
Nov 20, 2007 | Heating & Cooling
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
41 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
