Question about Denon AVR-1802 Receiver
I cant get the dolby sound going
I tried changing the channels and cant get it to work,i have sound but not dolby . i remember at one time i had to turn it on and now i forgot what i did
  • 431 Answers
I suggest you contact the manufacturer's support department / Customer Services either by phone or online .
They will probably be able to tell you the proceadure , but faiing that a good local enegineer will probably be able to advise you .... Regards vortash
Posted on May 02, 2009
No center channel sound on my Yamaha receiver
Is the center channel amp blown? How about checking the center channel input wire for signal?
Jan 06, 2017 | Yamaha Audio Players & Recorders
SOunds shut "off" when changing from HD channel to non-HD channel.
I think you need to look at the sound settings. In particular the type of sound. HD channels often carry AAC sound, suitable for Dolby 5.1 and Standard Channels don't. So the sound system will switch modes when you change channels. However the receiver is not switching back to picking up PCM signals, the type used on SD channels.
Jan 01, 2018 | Harman Kardon AVR 7000
Samsung ht-c453 remote stopped working
kindly check the battery of your remote control...
Mar 08, 2013 | Samsung HW-E551 Home Theater Speaker...
I have comcast basic cable. Recently I have six channels (always the same ones) that don't have sound. All the other channels are fine. We have a small tv in the bedroom also connected to the cable and...
Try changing the audio settings in your tv. Sometimes changing from pcm to dolby digital or vice versa can get your audio back up on these channels. Remember some stations are broadcasting in digital pcm and or dolby digital. I would leave tv on pcm. If that doesnt work check to make sure your not in a second audio mode (meaning set is on sap) sometimes a customer will accidentally hit the sap button. Put unit on stereo setting
Oct 22, 2010 | Panasonic Viera TH-42PX80U Plasma TV
When playing dolby digital 5.1 surround dvds it.is not getting decoded.i get the sound in all the speakers.
go to your control panel
click the sound icon
under the playback tab select the audio device you want to configure
right click properties
check each tab make sure you have dts / dd ticked
you may have software from creative installed check this to make sure you have the soundcard setup to output 5.1 when available
make sure the sound is configured on power dvd
if you cant get it working that way i suggest trying windows media player 11
also remember the soundcard will only output 5.1 if the source is 5.1 a copied dvd for example could be 2 channel stereo
i hope this helps you out !
May 28, 2009 | Creative Labs Sound Blaster X-Fi Xtreme...
Home theater
Just go into your sat box setup menu and under setup system option select audio and make sure to go to the dolby digital option and turn it on. This feature is turned off by default from the factory. You will always get 2 channel sound unless that is on. Also remember to go to a hd channel as they are broadcast in surround sound and non hd channels are broadcast in 2 channel.
Nov 08, 2008 | JVC THD-50 System
Center channel
Back to basic to advance:
Be sure you have all speakers connected correctly behind the receiver.If you center channel don't have any sound,it could be 7 different issues,but you could try to just hook up your center channel to either the right or the left speaker output to be sure the center channel speaker does work.
Check your the speaker wiring tip(if there is any),i will use just the speaker wire go straight to the center speaker output,go to the receiver to change it to pro-logic or dolby digital and of course you should put in a dvd in the dvd player to have a good quality movie to play the dialogue through the center channel for you test.
If you have tried the above step and still have no sound,you might consider hiring a troubleshooting master to take care of your issue.
Let me know what you need!
solutiondoct
Nov 05, 2008 | Pioneer VSX-455 Receiver
No sound from optical or coax digital inputs
You have to use the system setting using the remote and turn on the inputs you want to use. Hope this helps.
Keith
Oct 16, 2008 | Denon AVR-1602 Receiver
Speaker Channels? STR-DE505
Hi There,
Maybe can clarify the reasons you have different output configurations.
I worked for Dolby in London for ten years and cinema processing was an area close to me.
To cut a long story short;
The number of factors and different combinations possible for a fully equipped cinema offering Dolby and / or other protocols to the guest is large to say the least even within the Dolby formats.
For Sony to try to offer a range of home units (recievers or tuner/amps/decoders in this case) was to say the least ambitious .but hey!..........who else can give the public what they think they need.,,,good old Sony
I have looked at this unit and it seems the "amplifier section" is used for various configourations
and power output ratings vary depending on the configuration you choose.
Stereo 2 ch L+R is 2 x 75w
Surround requires more channels (centre and mono rear) and of course new signal routing to and from these blocks which of course will draw from the modest power supply.
So 4 channel surround will deliver 4 x 50w.
etc. etc.............what you hear are the relays which are reconfiguring and re - routing the signals.
Basically you cant have all the sections working all the time due to cost /design restraints
So speakers A OR B can be used but not BOTH when in surround mode....where the centre and surround are needed. .you cant have A and B at any time....push both buttons an NEITHER will work ....release one button and there you go.............it saves "letting the smoke out of the box".........which you should never do...........cos they never work without it. :)
Sorry for boring you ...............but I think you will find the unit is working just fine.............you could read the manual but that's not too informative.
Right...off to get a life now
Nik
Aug 01, 2008 | Sony STR-DE505 Receiver
Harman kardon avr-147
Hi Javis. This is perfectly normal ! This mode change is done because the receiver auto detects the digital audio signal and sets the receiver's DSP to decode the signal correctly. You can go into the OSD menu to bypass the auto detection of it, but it's not recommended at all ! You're getting the best audio quality by doing so. Thanks ! cheebster.
May 07, 2007 | Harman Kardon AVR 240 Receiver
Denon AVR-1802 Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
