Question about Canon SPEEDLITE 580EX TTL Flash
580ex not flashing at all
After have used it very strongly (many flashes at 1/1 power) the strobe doesn't work anymore. Everything seems to be OK looking all over the LCD, but the strobe doesn't charge anymore, it is not even audible the normal noise it makes when the capacitor charges any further. the "ready light" never turns on at all...
  • 7 more comments
  • johnnydeb May 06, 2008
    Same symtoms as canonist's reported. Everything else seems to work except it just won't flash anymore after 2 years of great service.
  • Anonymous Jun 08, 2008
    I have the same problem after only 16 months minimal use.  it will not charge nor will it light up.
  • PDpics Jun 14, 2008
    in the middle of shooting a graduation. No more power and it will not power up again. Two years old min. use My batteries were very very hot
  • bec8614 Jun 16, 2008
    i just had the same problem...what's the solution?
  • survic2 Jul 23, 2008
    Same exact problem x6 or so at this point. Have a 580EX that is 2 years old, has been repaired three times and is down again. Have a 430 that is less than a year. Just had it repaired by Canon less than a month ago and guess what, the lights come on, but it won't flash. My little Sunpak is much more reliable. My big Canons are only good for a few months. Next purchase will be another brand.
  • chrisjo888 Aug 22, 2008
    I purchased a Canon SPEEDLITE 580EX TTL Flash and with minimal use it does not work any longer. It does not flash, the led panel does not work and when i was working with the settings right before the panel went out it made a loud pop the flash went off and now nothing. Piece of junk and at 350.00 is not a good buy. Really sucks......Was using it with a canon eos20D. Do not buy a Canon Speedlite 580ex in my humble opinion.
  • Shawade Dec 26, 2008
    My 580EX is 3 years old and has worked perfectly until this last week, I can get a red (adequate flash charge) light but cannot get a green light for even a single shot. Tried new alkalines and new/old rechargables. Cameras (G9 and EOS40D) do not show flash ready symbol either.
  • bahogg Jan 21, 2009
    My 580 was working fine on my 20d then when I put it on my 30d it would come on but will not flash. I thought maybe I did something crazy to it but it sounds like this is something that is happening to other also.
  • tmsridar Mar 16, 2009
    my canon 580 eos flashlight is not working
After using it many flashes at 1/1 power the strobe doesn't work anymore
Posted on Apr 24, 2008
SOURCE:
The flash ratio between a master unit mounted on my Canon 5D Mark II and slave doesn't work properly. A couple of shots are fine but then all of sudden the slave unit fires ar full power, then a few week...
If you had the ATG Gold MG8k Flash Kim X3, then your 430EX II or 580EX II can transforms into wireless radio ATG ETTL II.
If you are using the outdated wireless IR ETTL with a 580EX II as a Master. Then you have to set the Slave (ATG/580EX II/430EX II) body facing close to the Master.
[email protected]
May 20, 2014 | Canon Speedlite 580EX II TTL Flash
The E-TTL does not appear in my canon speedlite 580exII anymore, only shows Manual and Multi-, is it faulty now?
What camera model are you using?
Try this:
1. How flash on camera.2. How USB cable to camera to Window PC.3. Run my software (EOS Utility)4. Click on Camera Settings/Remote Shooting5. Click on flash menu.
Any questions?
[email protected]
Sep 18, 2012 | Canon Speedlite 580EX II TTL Flash
Canon 580ex II strobe issue
This depends on the mode you have selected on the flash gun. If you have Multi selected you will get the strobe effect. The strobe effect is all so present to help the flash set the correct exposure. It's not a problem with the flash or the camera. Spend some time reading through the flash gun manual. I have to admit it is not always clear. Also try Youtube for a video.
Sep 21, 2017 | Canon Speedlite 580EX II TTL Flash
My 580EX seems to have low power
Hi Doug,
Try putting in 4 brand new batteries Lithium Energizer.
Or feed the Turbo Battery into the 3 pins port.
You flash is over 5 years old.
Or your NiMh are no longer holding a charge.
Do you have a DVM?
[email protected]
Feb 22, 2010 | Canon SPEEDLITE 580EX TTL Flash
I can't get flash to work on my camera
Make sure you have good strong batteries. "Strobe Charge" is what the camera says when it's sending power to the strobes that make the flash. It can take alot of juice and if you're using weak or old batteries they may not be able to handle the load. I found with my DSLR that the Energizer Lithium batteries are great for cameras and have been using those exclusively in all my cameras. I just got the Aiptek about a month ago, have not changed batteries yet. My other digital video camera ran for over two months on one set of them, and I used it alot. It's on it's second set now and my husband has it.
Feb 10, 2009 | Aiptek ISDV2.4 Flash Media Camcorder
Flash quit flashing
To test the flash to fire without the camera:
Cut a wire about 4" long.
Strip both ends to about 1/4" to exposed the wire.
Turn on flash, wait until fully charged.
Touch one end of wire(lead) to Center of flash contact and hold in place.
Touch other end(lead) to side of flash.
This should fire the flash, if the tube or the cap is good.
Hope they are helpful.
Alexander
[email protected]
Dec 09, 2007 | Canon SPEEDLITE 580EX TTL Flash
Canon Digital Rebel XT Bulit-In Flash Strobes in Low Light
use more light:)
its very normal that it does that. it dosent get enough light so it cant focus. the only way it can autofocus is that it stobes the flash to adjust the focus automaticly. use an external flash like 580EX and u will get an focus asisten thru a red grid throne by the flash unit.
Nov 01, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Not working with my Rebel XTI
ALL Canon digital EOS cameras will work with E-TTL only. Solution: you need EX flash for full auto.
Oct 20, 2006 | Canon Speedlite 540EZ TTL Flash
Canon SPEEDLITE 580EX TTL Flash Logo
692 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
