Question about Seagate (ST3100203U2-RK) (ST3100203U2RK) 100 GB Hard Drive
Tool to remove bottom plate
It's a star with a pin in the middle, anybody have any ideas whaere I can get one.
Use 320 external hard drive with 2 pc's?
Posted on Jul 17, 2007
  • 385 Answers
The screwdriver you need is a Torx T10 screwdriver. Just get it from a hardware store, ask for a Torx (size T10) screwdriver. Good Luck!
Posted on Jun 20, 2007
SOURCE:
1999 cheverlet c2500 ignition switch replacement
Usually star head or security star head. If there's a small pin in the middle, you'll need security torx bits. Otherwise standard torx bits.
Oct 22, 2017 | 1999 Chevrolet C2500
How do I remove hinge pins from everbuilt door hinge
You'll need a punch tool that has a diameter slightly smaller that the pin itself. Take a hammer and use it to drive the hinge pin out.
Sep 23, 2014 | Everbilt Hinge. 3-1/2 in. Zinc Plated...
Change the water pump
  • Tools Required
  • J 43651 Water Pump Holding Tool
  • Remove the thermostat housing.
  • Remove the water pump access plate from the front cover.
  • Remove the right hand fender liner.
    1. Important: A drain plug has been provided at the bottom of the water pump assembly for additional coolant drainage from the engine block and water pump.
    Drain the coolant from the water pump using the plug at the bottom of the pump.
    1. mportant: The water pump holding tool supports the sprocket and chain during water pump service. The tool must be used or the balance shaft must be re-timed.
    Install the J 43651 into position.
    1. Tighten the bolts on the water pump holding tool into the threads on the water pump sprocket.
    2. Install the access cover bolts that were removed earlier to secure the water pump holding tool to the front cover assembly.
    3. Remove the 3 inner water pump sprocket to water pump blots.
      1. Important: Be sure to remove both water pump bolts from the front of the engine block.
      Remove the 2 water pump bolts.
      Remove the rear 2 water pump bolts.
      1. Remove the water pump.
      2. Remove and discard the water pump O-ring seal.
      Installation Procedure
      1. Important: Prior to installing the water pump, read the entire procedure. This will help avoid balance shaft chain re-timing and ensure proper sealing.
      Install a NEW water pump O-ring seal.
      1. Important: A guide pin can be created to aid in water pump alignment. Use a M 6 m x 6 mm stud. Thread the pin into the water pump sprocket.
      Using the guide pin, align the pin with the water pump holding tool.
      1. Position the water pump against the engine block and hand tighten the water pump bolts.
      2. Notice: Refer to Fastener Notice.
      Install the inner water pump sprocket bolts. After 2 are snug, remove the guide pin and install the 3rd bolt.
      Tighten the bolts to 25 Nm (18 ft. lbs.).
      1. Tighten the water pump sprocket bolts last. Tighten the bolts to 10 Nm (89 inch lbs.).
      2. Remove the J 43651.
      3. Install the water pump access plate and bolts. Tighten the bolts to 10 Nm (89 inch lbs.).
      4. Install the right hand fender liner.
      5. Install the thermostat housing.
Aug 29, 2011 | 2006 Pontiac Solstice
How to remove drum from shoes. very worn
On the back side "backing plate" behind drum, there's a small opening in the bottom (sometimes they have a black rubber oval plug) remove plug (if equipped) insert straight blade screw driver and try turning adjuster
Jan 18, 2011 | 2005 Chevrolet Silverado
How do i get the calapers off the rear of a 2006 grand caravane?
Using a C clamp depress the claiper. There a spot right in the middle to do this. Now the fun part hope you have metic hex key set. The 2 caliper guide pins are on the back inside the boots. Which need to be in great condition. Using the metic hex keys some are 7mm or 8mm turn to your right to remove. Rmove the caliper mounting bracket bolts. Fun part #2 removing the disc rotor. Theres parking brake pads or a durm brake system on the inside of the rotor. If the rotor does not slide off. You must remove the rubber gromet on the back of the backing plate. Using a screwdriver or the old brake adjuster tool turn the star wheel to adjust the parking brake in to remove the disc rotor. All brake guides on the calipers & guide pins need to have high temperture brake grease applyed to them. Buy the big bottle for $10 for the front brakes & future use it comes with a bush. Note ** Remove a guide pin take to auto store buy socket to reinstall guide pin/bolt. Why Caliper guide pins 26lbs torque. Caliper mounting bolts 125lb torque
Dec 05, 2009 | 2006 Dodge Grand Caravan
How do you remove the rear rotors from a 2007 Dodge Minivan?
Disc only!!! Remove rear tire. Remove 2 calipar bolts. Hang calipar. Don't leave hang loose. Slide rotor off. If stuck you must adjust the emer. brake, Going around the back side of the backing plate on the bottom. Remove the rubber boot. Using a brake tool or screwdriver adjust the star wheel adjuster to remove the rotor.
Oct 08, 2009 | 2007 Dodge Grand Caravan SXT Minivan
Trying to remove rear brake drum cover,have already adjusted star wheel and still won't remove. what am i doing wrong? for a 93 plymouth grand voyager
  1. Raise and support the rear of the vehicle on jackstands.
  2. Remove the wheels and tire assemblies.
  3. Remove the brake shoe adjusting slot cover from the rear of backing plate.
  4. Insert a thin tool through the adjusting slot and hold the adjusting lever away from the star wheel.
  5. Insert an adjusting tool and back off the star wheel by prying downward with the tool.
  6. Remove the center hub dust cover, nut, washer, brake drum, hub and wheel bearings.
To install:
  1. Inspect the brake lining and drum for wear.
  2. Inspect the wheel cylinder for leakage. Service as required.
  3. Remove, clean, inspect and repack the wheel bearings.
  4. Install the brake drum and tighten the hub nut to 20-25 ft. lbs. (27-34 Nm), then back off the nut until bearing pressure is released.
  5. Retighten the nut finger tight, align the cotter pin hole and install the cotter pin.
  6. Adjust the rear brakes as described in the beginning of this section.
Removing the rear drum adjusting hole cover plug
Oct 07, 2009 | 1993 Plymouth Grand Voyager
How to install rear brakeshoes
REMOVAL & INSTALLATION
If you are not thoroughly familiar with the procedures involved in brake replacement, only disassemble and assemble one side at a time, leaving the other wheel intact as a reference.
1983-88 Vehicles
See Figures 1, 2 and 3
  1. Raise and safely support the rear of the vehicle with jackstands.
  2. Remove the tire and wheel assembly.
  3. Remove the brake drum, as outlined earlier in this section.
  4. Place Brake Cylinder Clamp D81L-1103-B or equivalent, over the ends of the brake cylinder.
CAUTIONBe careful that the springs do not slip off the tool during removal, as they could cause personal injury.
  1. Remove the shoe-to-anchor springs, using Brake Shoe R and R Spring BT-11, or equivalent, then unhook the cable eye from the anchor pin.
0900c1528006be0f.jpgFig. 1: Place the brake clamp tool over the ends of the wheel cylinder, then remove the shoe-to-anchor springs using the correct tool
  1. Remove the shoe guide (anchor pin) plate.
  2. Remove the shoe hold-down springs, shoes, adjusting screws, pivot nut, socket and automatic adjustment parts.
  3. Remove the parking brake link, spring and retainer. Disconnect the parking brake cable from the parking brake lever.
  4. After removing the secondary brake shoe, disassembly the parking brake lever from the shoe by removing the retaining clip and spring washer.
0900c1528006be10.jpgFig. 2: View of the drum brake components-1983-88 9-inch brake shown 0900c1528006be11.jpgFig. 3: View of the drum brake components-1983-88 10-inch brake shownTo install:
  1. The brake cable must be connected to the secondary brake shoe before the shoe is installed on the backing plate. To do this, first transfer the parking brake lever from the old secondary shoe to the new one. This is accomplished by spreading the bottom of the horseshoe clip and disengaging the lever. Position the lever on the new secondary shoe and install the spring washer and the horseshoe clip. Close the bottom of the clip after installing it. Grasp the metal tip of the parking brake cable with a pair of pliers. Position a pair of side cutter pliers on the end of the cable coil spring, and using the plier as a fulcrum, pull the coil spring back with the side cutters. Position the cable in the parking brake lever.
  2. Apply a light coating of high temperature grease to the brake shoe contact points on the backing plate. Position the primary brake shoe on the front of the backing plate and install the hold-down spring and washer over the mounting pin. Install the secondary shoe on the rear of the backing plate.
  3. Install the parking brake link between the notch in the primary brake shoe and the notch in the parking brake lever.
  4. Install the automatic adjuster cable loop end on the anchor pin. Make sure the crimped side of the loop faces the backing plate.
  5. Install the return spring in the primary brake shoe and, using the tapered end of the brake spring service tool, slide the top of the spring onto the anchor pin.
CAUTIONBe careful to make sure that the spring does not slip off the tool during installation, as it could cause injury.
  1. Install the automatic adjuster cable guide in the secondary brake shoe, making sure the flared hole in the cable guide is inside the hole in the brake shoe. Fit the cable into the groove in the top of the cable guide.
  2. Install the secondary shoe return spring through the hole in the cable guide and the brake shoe. Using the brake spring tool, slide the top of the spring onto the anchor pin.
  3. Clean the threads on the adjusting screw and apply a light coating of high temperature grease to the threads. Screw the adjuster closed, then open it 1/2 turn.
  4. Install the adjusting screw between the brake shoes with the star wheel nearest to the secondary shoe. Make sure the star wheel is in a position that is accessible from the adjusting slot in the backing plate.
  5. Install the short hooked end of the automatic adjuster spring in the proper hole in the primary brake shoe.
  6. Connect the hooked end of the automatic adjuster cable and the free end of the automatic adjuster spring in the slot in the top of the automatic adjuster lever.
  7. Pull the automatic adjuster lever (the lever will pull the cable and spring with it) downward and to the left and engage the pivot hook of the lever in the hole in the secondary brake shoe.
  8. Check the entire brake assembly to make sure that everything is installed properly. Make sure that the shoes engage the wheel cylinder properly and are flush on the anchor pin. Make sure that the automatic adjuster cable is flush on the anchor pin and in the slot on the back of the cable guide. Make sure that the adjusting lever rests on the adjusting screw star wheel. Pull upward on the adjusting cable until the adjusting lever is free of the star wheel, then release the cable. The adjusting lever should snap back into place on the adjusting screw star wheel and turn the wheel one tooth.
  9. Expand the brake adjusting screw until the brake drum will just fit over the brake shoes.
  10. Install the brake drum and wheel and tire assembly, then adjust the brakes.
  11. Carefully lower the vehicle.
Dec 08, 2008 | 1987 Ford Thunderbird
Open Questions:
See all Seagate (ST3100203U2-RK) (ST3100203U2RK) 100 GB Questions
Seagate (ST3100203U2-RK) (ST3100203U2RK) 100 GB Hard Drive Logo
155 people viewed this question
Top Seagate Computers & Internet Experts
Ekse
Alun Cox
Argospete
Argospete
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
