Cassette door will not open
I put a tape in - play slow .no FF or RR and cannot open door.Tried same troubleshooting for a previous posting for a Sony model
Found more issues, got top off and door open but touch controls did not move flywheel in any mode for long and internal noise. Will abandon repair as probably too costly.Thanks
Posted on Jan 18, 2009
Panasonic RR-930 does not backspace with or without pedal. It engages the mechanism but appears stuck when tape is inserted. Runs fine without tape in deck.
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
Apr 20, 2015 | Panasonic RR-930 Desktop Cassette...
Tape deck wont play only makes noise
The drive system is not functioning. Could be belts
Oct 19, 2012 | Sony Audio Players & Recorders
Plays tapes to slow
some time u can push play and ff or the rew and it work
Nov 06, 2010 | Sony Walkman TCD-D8 Personal Cassette...
Unit accepted cassette, won't eject
It is likely that either the drive belt has broken or is slipping. Because the unit is still in "play" mode, the mechanism won't let the door open up. If you have not opened up these units before, do not attempt it now. This unit should be taken to an experienced tech for repair. Where are you located?
Dan
Apr 08, 2010 | Sony EVC100 Hi8 VCR
Sony SLV-N71 VCR makes a rattling sound (ff, rew)
I make no claim to being any kind of an expert techie but it sounds to me like there are one or more loose or badly worn parts inside your machine. If you haven't had a look at the innards, try that. Loose things can usually be re-secured and, sometimes, worn parts can be replaced.
Rod
srives@shaw.ca
Feb 04, 2009 | Sony SLV-N71 VCR
Aiwa AD-F800 Cassette Door problem
95% of all tape deck mechanical issues are caused by the belts going bad. if they have not been changed, then goto turntableneedles.com and click on the "find my player" link it will take you to the two most commonly failed belts for your model. They are square belts. If you open it up and see flat belts then email them measurement information by threading a piece of string from around the pulleys where the flat belt is found. ONLY OPEN AND ATTEMPT THIS IF THE POWER UNPLUGGED & YOU ARE QUALIFIED OR EXPERIENCED WITH ELECTROMECHANICAL DEVICES.
Jan 16, 2009 | Audio Players & Recorders
Can not eject tape
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
Oct 14, 2008 | Sony Handycam CCD-TR416 Camcorder
TC-WR99ES
Not knowing what brand/model tape deck you have, I would suggest you make sure the belts are good before you get into replacing servo ICs
Jun 23, 2008 | Sony Audio Players & Recorders
 Grubhead
Grubhead
