Question about Epson Stylus 1400 InkJet Photo Printer
Printer won't accept paper
It says close CD/DVD ?????????
  • rodrigo padron Feb 27, 2009
    Please tell me where is the CD/DVD sensor located and how to repair it. Thanks
  • buddy4344 Feb 28, 2009
    happens sporatically. Problem occurs after computer/printer have been restarted. sometimes I can reboot and the problem goes away.
  • Epson Master
  • 419 Answers
If didn't realise the 1400 had a CD/DVD printing tray but not to worry...
Basically there's a sensor on the printer which tells the printer (and software) that the CD/DVD tray is in the open position.. Check to see if the tray is up and closed properly and also check for any damage to the sensor.
Posted on Jan 29, 2009
Artisan 730 keeps ejecting CD/DVD tray?
Possibly the the eject switch is stuck, open the case carefuly check and rectify.
Mar 25, 2015 | Epson PRINTER,ARTISAN 730
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
Two Red LIght Blink
CD/DVD guide error
When turning on the printer or printing on paper, the CD/DVD guide is open.
Close the CD/DVD guide.
Carriage error
The print head carriage is obstructed by jammed paper or other foreign material and cannot return to the home position.
Turn off the printer. Open the paper support and the printer cover then remove any paper or other obstructions from the paper path by hand. Then, turn the printer back on.
Sep 25, 2010 | Epson STYLUS R230 InkJet Photo Printer
Try to print directly to DVD with a canon pixma
>> It tells me to close the door so it can resume printing on paper normally A4.
It is trying to "ignore" the "bypass" try.
Tell the printer to *ACCEPT* the disk from the "bypass" tray,
rather than from the stack of paper in the A4 tray.
To tell the printer, click the OK button on the printer.
Nov 08, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Close the cd/dvd guide
Is there a button for to close the CD/DVD guide? Your Printer stays on CD/DVD printing mode, that's why
Use it. IF NOT Reset the all settings, Check for your userguide Troubleshooting.
Check epson support page for helfull links.
Aug 12, 2009 | Epson Stylus Photo R300 InkJet Printer
Espon 1400 prob. with vista close the cd/dvd guide. It is CLOSED!
I am having the same problem. I am on my 3rd printer from Epson in 2 weeks.
The solution may be to buy another brand, but I have more in Epson ink & paper than I have in the printer.
Jun 04, 2009 | Epson Stylus Photo 1400 Printer
Red light on steady
If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
I have an Epson R 300. It worked fine with my PC. I recently got a new I-Mac and I cannot print CD/DVD's. I have the Epson "Print CD" application loaded but when I try to print on a DVD I keep getting an...
If you are using a leopard operating system, you have to install easyprint. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=26322&prodoid=37368458&infoType=Downloads&platform=Macintosh,
Trash / re-install epson print cd.
There is a work around for that. Please contact epson.
Apr 30, 2009 | Epson Stylus Color 300 InkJet Printer
Won't print a 4 x 6 print. Paper passes right through printer
Hi-
Double check on printer properties under printers and faxes if 4X6 is selected, then access printer properties as well on the application or program where you are printing the images by clicking File then print option. Make sure Epson is the default printer.
Keep us posted, thanks!
Aug 23, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus  1400 InkJet Photo Printer Logo
273 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
