Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
What DVD Disk do I use with this product
I have a Magnavox MWR 20V6 Recorder, Which disk is compatiable with this player DVD - R's or DVD+R's. The disk sometime don't work what could be the problem
  • 3 Answers
THE BEST DISK I HAVE FOUND AND BELIVE ME I HAVE TRYED MOST OF THEM I HAVE 6 DECKS ZV42OMW8 AND MWR 20V6 THE BEST DISK THAT WORKS IN ALL OF THEM IS MAXELL
DVD-R 16X 4.7 AND MOST OF THE DVD-RW
Posted on Jan 25, 2009
  • 395 Answers
From what i could find it will record on DVD+R • DVD+RW only
Posted on Jan 16, 2009
Magnavox DVD/VCR Recorder ZV457MG9 How do I finalize my DVD on this player/recorder?
http://www.ehow.com/how_8623235_do-finalize-magnavox-dvd.html is how to finalize a disk on Magnovoz! I have the ZV457MG9 - its model takes with
1) loading disk
2) select the set up button
3) select DVD edit
4) select finalize DVD
Then you finalize the DVD!!!
Jan 31, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recording Error, Can not record on this disc, E 4 54040990 Just trying to record from TV on a Memorex DVD+RW. Keep getting this error. Any ideas?
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs. Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd "e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder? Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Mar 28, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Want 2 record from my DVR 2 Magnavox DVD Recordable/VCR MWR 2046
should have avi scrat out at back of DVR place scrat lead here and the other end into avi scrat input on your DVD recordable & feed to screen as normal.
if no scrat scoket avaible you can get a converter to switch from one to other.See your local dealer.
And happy days of u go.
Aug 07, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a Magnavox MWR 20v6, I keep on getting error messages.
I figured how to get the Memorex DVD-R's working again. I went and bought a DVD lens cleaner and all the errors stopped at least for a while I hope.
May 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Lost Manual
www,funai-corp.co - free manuals at this site
Dec 21, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recorded dvds wont play in other dvd players
You have to finalize the disc. if the disc goes to the end it will finalize the disc automatically. If there is some part of the disc not used you have to do it yourself. IN DVD MODE PRESS SETUP, THEN DISC EDIT, THEN FINALIZE. FINALLY PRESS YES. That should do it.
Sep 03, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
WHEN I RECORD A DVD IN MY MWR 10D6 DVD RECORDER IT IS NOT ABLE TO BE PLAYED IN MY OTHER DVD PLAYER WHICH IS A TOSHIBA. WHEN YOU PUT THE DVD IN IT ALWAYS SAYS PLEASE CHECK DISK. THIS ONLY HAPPENS WITH DVD'S...
When you burn your DVD the disc has to go thru a FINALIISATION process before it can be used on other DVD players. Sounds like either your recorder hasn't run the finalisation or it doesnt do one, in which case your DVD's wont work on another player. Check thru your menu's for a FINALISATION option and make sure you run it.
Marty.
Dec 29, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Finding a code
Look under Funai with dish network.
Nov 19, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
216 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
