Question about Canon imageRUNNER 1023N Black and White Copier
ImageRunner 1023n is printing vertical bars on page edge
Our printer is printing vertical bars at the edge of the page. Is this something I can fix with a simple parts replacement?
Thanks in advance,
Alan
  • alanforsythe Jan 17, 2009
    Thanks Officetech1 - I really appreciate your candid response.
    After asking around I found that the problem began when someone in the office removed from the tape from a toner cartridge before inserting it into the unit. The toner is everywhere. I have cleaned the drum manually and ran the internal cleaning routines but the vertical lines persist. Is there another component I need to clean or does the unit need an overhaul?
  • 100 Answers
Needs a new drum unit most likely if the narrow glass is spotless clean on top. If you print and get a line, then its an internal problem and usually just the drum.
Posted on Jan 16, 2009
  • Mike Jan 17, 2009
    Maybe toner is on the laser unit glass. There isnt much more you can do. Actually when toner spills all over, you can really just about destroy a machine like this. I would drop it off at a Canon dealer or service center. It will cost more to call them to your site and they might want to take it back to the shop. Could cost a few hundred dollars in labor to get all cleaned out and running right again. Good luck!!
How do I print envelopes using my Canon Imagerunner 1023N?
load your envelope in stakbypass and chose free size and enter your envelope size then you have to custome size your pc as envelope then print your document.
May 17, 2011 | Canon imageRUNNER 1023iF Black and White...
Black lines are being printed on one edge of paper. It's not from the original.
u have to replace drum unit in your machine as a solution of this problem.
Apr 13, 2011 | Canon imageRUNNER 1023N Black and White...
The printer copies turn out with a faint gray background through half of the copy. Its as if something is dirty and it printing the dirt.
it could be few things,
Its probably drum unit fault, probably the cleaner is worn out and doesnt clean drum surface enough.Remove the drum unit and see if there is "leftovers" on drum surface and if Yes change the drum unit.
If the copie isnt baked enough that means that the fixing roller is worn out and you need to change it.
If You are using replacment toner, not genuine from Canon, also it can cause problems like bacground, dots, spots,...
Hope that helps!
Sep 09, 2010 | Canon imageRUNNER 1023N Black and White...
Keeps flashing "change papersize" and won't continue copying
most likely someone has sent a print job in wrong papersize.....delete job in print que on copier
Sep 30, 2009 | Canon imageRUNNER 1023N Black and White...
Blank scans- canon imageRunner 1023N
Blank image = transfer/separator unit/corona is not working. Please check the transfer unit.
Aug 19, 2009 | Canon imageRUNNER 1023 Black and White...
ImageRunner 1023N.. assign IP
Press the additional funktion buton,press the arrow keys until 9 system settings is displayed press ok press the arrow again until 5 neywork settings is displayed press ok.TCP/IP settings will be displayed press ok and change the ip to your network adminatrators specifications.
Aug 17, 2009 | Canon imageRUNNER 1023 Black and White...
Printing graphics
Is it outside the normal printing area? It seems strange-Could there be something stuck in the machine over there? or an ink blob on the paper roller?
Aug 15, 2008 | HP LaserJet 1020 Printer
The memory is full how i do to print it
hi im jules_09,just clear the memory in the program.so you can print sometimes when the copier memory is full it will not let you print,just be carefull not to clear all program seting
Nov 12, 2007 | Canon imageRUNNER 1023N Black and White...
Canon imageRUNNER 1023N Black and White Copier Logo
281 people viewed this question
old marine
old marine
