Question about Zanussi FJS1225W Front Load Washer
Zanussi We have a Zanussi WJS1665W Washer dryer and keep getting the error codes E20 and E90 can you please let me know what these mean? Thank you Emma
  • Anonymous Mar 15, 2014
    zanussi washer dryer error 40
  • Anonymous Mar 22, 2014
    what is wrong
 The drain filter is clogged (E20)
online manual
http://www.serviceforce.co.uk/pdfs/U21039.pdf
Posted on Oct 31, 2008
    Problem Solver:
  • 5 Answers
E20 = Problems with water drain in wash phase ALARM CODES E20 Is the drain filter clean; Problems during draining phase (Machine tries to drain for 10 min without emptying the tub) Checks to do: E20 Is the drain pump working? Is the value of the pump about 200Ω? (Measure directly the connector by the board, between J2-2 and J2-7) ; If No Change the pump and run again Clean the filter; Is the draining system OK (drain hose and plumbing where machine is connected) Free and check the draining system; Is the pump blocked? Is there any burn mark on the control board; if yes Change the board E90 = Communication error between user interface and main board. Verify the connector between the main board and user interface board by plugging and unplugging the connector few times on both sides, OR replace the blue ribbon cable. The fault could have been caused by oxidized contacts in user interface plugged in the main board. Kind Regards David Marsh
Posted on Jul 18, 2007
SOURCE:
What does e90 mean?
  • E90 Error - YouTube www.youtube.com/watch?v=IhHvw2K7XO0
    • BY D CUTHRELL
    • 3 MIN
    • 24K VIEWS
    • ADDED 2012-11-16
    Video embedded · E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow www.ehow.com > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? howtomendit.com > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    Zanussi washer dryer showing e20 error message in dryig cycle
    Hi
    This means that the filter is clogged. Unscrew the filter it'll be full of lint. E20 also means drain problem. If it actually goes through the Spin cycle then there is most likely some water still not drained out at the time of the tumble dry. Check the drain and the hose to make sure it isn't clogged.
    Please get back to us if you have further query else please accept the suggestion.
    Thank you for contacting fixya.com
    Jan 03, 2011 | Zanussi Washing Machines
    AEG Lavamat Turbo 12830 - error code E20
    Hi
    E20 means there is a bolckage in there
    remove filter and clear any debris in there and check impeller is turning ok.
    regards
    Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
    Problem
    Check the drain hose, and inspect the filter for any foreign object.
    I report :"E20 means your fluff filter / waste pipe is getting blocked and the machine cannot pump out the water. Try unblocking the fluff filter first at the bottom of the machine. This should work, if the fault appears again though and the fluff filter is clean your waste pipe is blocked and you need to flush this through. Can you tell what I've just spent my weekend doing, I have had to get the most unbelievable amount of limescale out of these 2 areas but machine is now working fine again."
    From how to mend it
    See also E20 Zanussi Washer Dryer WJD1667
    Oct 15, 2008 | Zanussi FJS1225W Front Load Washer
    Zwd1471s washer dryer
    E20 code on Zanussi washer dryer ZWD1471
    washing machine working but dryer is not .
    Any advice please
    Mar 24, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
    E20 message
    Hi Helenw,
    The error message E20, simply means the filter plastic cage which is located behind the trap door bottom right side of the machine is full and needs to be cleaned out.
    All the fibres and lint gets trapped in here and prevents the waste water from escaping, hence Error code E20.
    Regards,
    David
    Sep 12, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
    E10 error code
    I had this problem, the washer/dryer stopped working while in the drying cycle and displayed e10 message. It was caused by a faulty three-way inlet valve. The solenoid controlling flow to dryer condenser proved to be open circuit. Pulled washer out from under counter top, unplugged, removed top cover, tested solenoid circuits with ohm meter and found one solenoid was faulty. The filter going into the unit was clear. Replaced whole three way component with one ordered on Internet and all now works fine. Noticed that during drying cycle, water to condenser is constantly being switched on and off, explaining why the green condenser solenoid is the one that wears out first.
    Mar 03, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
    E90 Error Code
    an E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
    Nov 08, 2006 | Zanussi FJS1225W Front Load Washer
    Zanussi Electrolux ZWF 1430 W (E20 error)
    Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
    Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
    Zanussi FJS1225W Front Load Washer Logo
    932 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    jimorris77
    Marvin
    Marvin
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
