We put new plugs in it and when we try to start it, it acts like it wants to turn over but it wont like it just gets there and wont finish the circle. just stopped turning over.
Are you sure that you had the plug wires on in the correct order? If you have a couple of them switched and it fires at the wrong time it can stop the engine from turning momentarily.Are you sure that you had the plug wires on in the correct order? If you have a couple of them switched and it fires at the wrong time it can stop the engine from turning momentarily.
remove all off the spark plugs again make sure none are fouled crank the mtr over how dose it crank now let me know kdc744remove all off the spark plugs again make sure none are fouled crank the mtr over how dose it crank now let me know kdc744
its got nothing to do with plugs how was the truck running b4 this happened call me 870 497 1765its got nothing to do with plugs how was the truck running b4 this happened call me 870 497 1765
You can't post conmments that contain an email address.
Yes it is possible the distributor has turned enough to be out of time. Not a common thing, but its possible. Did you check to see if you have spark at the plugs ?
i have a 1993 suburban gmc 1500. when i put the key in an turn it nothing happen at all.befor the car stop running it use to act crazy like start up in run great but when u turn it off it dont start back up. u wll have to wait than it will start..can u tell me what that can be..
Replace the sparkplugs or try holding the gas pedal to the floor and try to start but keep pedal to floor until engine starts and revs, this may take a few trys, dont crank more than 10 to 15 seconds, if this doesnt work then replace the plugs,
Have these things checked for #1:
Spark plug
plug wire
#1 fuel injector
and the throttle position sensor, also have a fuel pressure test done, especially for the hesitation.
its just not starting wont crank all the way over
this is the 1500 5.7 350 it is getting spark but it seems slightly random sparks not a constant spark.
plugs not fouled i just curiois if it might be the coil not giving out enough the starter is less then a year old
i changed them one at a time to be sure i didn't put them out of order
then the starter is ok, it turns the engine fast enough?
doe the engine crank over and just not start, unclear about this.
