Question about Sub-Zero 632 / S
How important is it to vacuum coils on a 632S sub zero? How often should it be done? What happends if coils aren't vacuumed regularly?
    Problem Solver:
  • 16 Answers
Once a month would be ideal. It prevents the unit from dissappating heat which effects the way the unit cools and runs less efficiently.
Posted on Jan 17, 2009
Hello, My sub-zero refridge says, "vacuum
If the fan under neath is running, and the light is still on, look real close at the coil and into the fins for dirt or lint, they get very dirty, when they are running its literally cleaning the air.
If the unit has metal with a screen as a schroud and fan guard, you can use water to clean but the water you use will run onto the floor, I have used hand squirt bottle for washing the coil. If the fan schroud in made of a card board only use air, water will distort the card board and stop the fan from spinning, why so I know this? If you use air to blow it out using a vacuum will help control the dust.
Jun 30, 2011 | Sub-Zero Refrigerators
My Sub-Zero side-byside freezer is at 35 degrees and says "vacuum condenser". What does it mean and what can I do?
At the top or bottom of your unit you have a removable panel that covers your compressor and condenser, you should hear a fan, that is your condenser fan, those coils need to be cleaned with a vacuum or dryer brush
Sep 03, 2010 | Sub-Zero Refrigerators
My 650 sub zero vacum condensor error code is flashing and the refrigerators inside temp rose to 58. Should I try and clean the coils first or does this sound like a more serious problem
Good day,
Cleaning the coils on a Sub Zero should be a routine procedure.
At least once a year.
Unfortunately the depth, fin design and overall layout of the Sub Zero machines does not lend itself to vacuuming.
The coils, to be cleaned properly must be blown out, from both ends.
Service techs carry nitrogen tanks or air under pressure with a hose to do the job.
If you do not have access to one of these devices, a quality push/pull shop vac with a crevice tool and some patience will do the job.
It's ugly and messy but there is no other way to do it properly.
It should be done as soon as possible, and if it produces no results on frig temperature a service tech qualified on Sub Zero should be called since it could easily be a serious problem.
Mar 10, 2010 | Sub-Zero 650/SRH Stainless Steel
Have a sub-zero 601F about 10 years old and the 'vacuum condensor' light is flashing whenyou open the door in the same box as the temperature.
You should first vacuum condenser coil on top (looks like radiator coil in the car), then try to reset it by turning it off and back on. Otherwise it indicates that it's running too much and most likely it's not getting cold enough.
Sub-zero repair in Orange County, CA
Jan 23, 2010 | Sub-Zero 601R
The refrigerator/freezer is not cooling it has power just will not cool
Try cleaning the dirt off the coils. First vacuum off all you can. If there are a lot of places the vacuum cannot reach, get a refrigerator coil brush at the hardware store and losen the dirt, then vacuum again.
Dec 01, 2009 | Sub-Zero Refrigerators
I need to vacuum the condenser in a sub zero,
The condenser coil is located behind the cover on top of the two doors and when you take it off you see the coils that look like a radiator (fins and copper pipes) ,turn of the refrigerator and with a brush and a vacuum clean the coil very carefully and don't push to hard against the fins.
Aug 24, 2009 | Refrigerators
Where are the coils on a sub zero 680? Vacuum condenser signal
Hello.
On the top of your unit there is a grill. Open both door and look at the lip under the grill. Remove these four screws. Now, pull on the top of the grill. You will notice that it is held on by two springs. Unhook those springs and set the cover aside. The coils are on the right hand side. Use a vacuum with the soft brush attachment to clean them and avoid damaging the airflow. Also, check the fan on the other side of the coils to make sure it is running.
Jul 16, 2009 | Sub-Zero 680 / F
My sub zero model 561 dosent't cool when the weather outside is h
I had the same problem with my sub zero. I took off the grill on the top and vacuumed the coil that has the fan in front of it. The problem has not happened since. I'ts worth a try.
Apr 26, 2009 | Sub-Zero 561 / F
Sub-zero model#3211-rfd, side by side, freezer working fine, but refrigerator not cold enough, alwaus stays 40F, even i turn to the max.
Have you cleaned the coil? Pop the grate off the top of the fridge and vacuum the coil as well as the grate thoroughly.
J
Jul 30, 2008 | Sub-Zero Refrigerators
Sub zero side by side
evaporator leaks freon, made a video on how to replace it
Oct 09, 2007 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Sub-Zero 632 / S Logo
164 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
