Question about Hoshizaki KM-1600S Stackable Crescent Cuber Ice Maker
Hoshizaki KM-1600S too much water supply
Water stays on too long, excess water in ice bin, low ice production
    Problem Solver:
  • 7 Answers
If water is standing in the bin the drain is clogged. If water is raining down into the bin, Machine may not be level or the drain on the ice machine maybe partially clogged. If machine freezes up water will rain into bin too. Water fills ice machine while in harvest and continues to fill until ice machine`s suction reaches 49 degrees and the defrost timer times out.(usually 1-3 minutes after suction line reaches 49 degrees)
Posted on Feb 05, 2009
Hoshizaki km-900mah ice maker won't start the freeze process
cycle is, fill cycle for 1 minute first. If there is not water entering the unit when first turned on, look for that issue. Water turned off, water valve not working or some restriction, clogged water filters, etc. That is got to happen first. Don't over look the bin stat being bad. Nothing happens if teh bin stat is bad. It sends voltage to the control board that runs the unit.
Jul 28, 2012 | Hoshizaki Freezer Commercial Ice Machines...
How do you adjust the bin level control on a hoshisaki cube star
typically clockwise is colder and counterclockwise is warmer. hold a cube on the end of the prob for testing and or re-locate the probe to where you want your ice level to be
Jun 04, 2012 | Hoshizaki KM-1600S Stackable Crescent...
Hoshisaki makes ice to slow
not sure what "too slow" is to you. Hoshi machines are designed to make more ice per batch but less batches per day. It is not unusual for a batch to take 25-35 minutes for one batch. The 1600 makes a lot of ice per batch. Look for some obvious things. If air cooled condenser, be sure it is clean. Make sure the water to the machine is not Hot water. It is not unusual to get Hot water feedback in a restaurant environment. Check for a leaking water valve. A sticking float can also cause long freeze cycles. Start with that and let me know if I can be of any further help,.
I STARTED A HOSHIZAKI TOOK TAPE OFF CURTAIN LOWERED BIN CONTROL INTO BIN CONNECTED BIN CONTROL HARDNESS UNIT WORKED GOOD BUT NOW WATER IS LEAKING INTO BIN MELTING ICE IN BIN ANY IDEA OF WHAT COULD BE...
Start by looking for water valve leaking. Turn machine off and if water is entering machine, water valve is not seating. Let me know if you need more than this.
Feb 14, 2011 | Hoshizaki KM-1300S 3-Phase Stackable...
Hoshizaki KM-600mah beeping
PCB requires to be reset. White button power needs to be on or it wont reset.
Feb 19, 2010 | Hoshizaki KML-600M Low-Profile Crescent...
NEED TO REPLACE PREFILTER CARTRIDGE AND HOUSING
Please call your local Distributor heres the link put in your Zip code and it will give you a Dist. in your area that may be able to help.
http://www.hoshizakiamerica.com/techsupport/dist_loc.asp
Jun 02, 2009 | Hoshizaki KM-1600S Stackable Crescent...
KM 280MAH
Check the condenser if it is restricted in any way it will decrease ice production. Check for water overflow from the sump. Any more water than necessary entering the sump will also cause a decrease in ice production.
Sep 04, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Harvest cycle on ice machines
My ice machine Hoshizaki km-500 mah is cycling to fast. Causing poor production of ice it's real small and it doesn't produce enough ice aswell. Wha seems to be the problem.
Jun 20, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki KM-1600S Stackable Crescent Cuber Ice Maker Logo
381 people viewed this question
Top Hoshizaki Kitchen Appliances - Others Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Hoshizaki Kitchen Appliances - Other Expert? Answer questions, earn points and help others
