Question about Maytag Performa PAV2200
No draining there is still water in at the end of the cycle. and it's still soapy. i guess the water doesn't drain at all thru the cycle.
  • 61 Answers
There is a pully and bearing on the bottom of this machine with a small tempered spring it is called a thrust bearing it is slipping. this need to be replace this will fix your problem.
Posted on Jan 16, 2009
Water does not drain at end of cycle
Could be drain pump , float switch, or PCB. Does it initially go thru a drain cycle when you start a cycle? Is there water in the bottom of the tub?
Oct 02, 2013 | Bosch 24" Built-In Dishwasher - SHE43R55UC...
The door won't open after a cycle...and all the clothes are soaking wet..even after 2 spin cycles it still has a lot of (soapy) water at the bottom..Help!!
the most common problem is a blocked or restricted drain pump.You can use a wet/dry Shop vac and attach it to the end of the drain hose to remove all the water.
Once the water is removed then your door should unlck and you can remove all the clothes.
after that you need to look at your drain pump remove the hoses be sure to check the hose that comes down from the bottom of the tub to the drain pump and look for any obstruction also check your drain pump inside there could be something stuck in it.
Feb 24, 2010 | Washing Machines
Water fails to fully drain at end of cycle and dishes still have soapy residue.
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Dec 09, 2009 | Kenmore 24 in. 16034 Built-in Dishwasher
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Seem like its not draining. soapy water when finished cycle.
found a kink in the drain hose, shortened hose-problem solved.
Mar 22, 2009 | Dishwashers
Dishwasher not rince & when cycle ends not clear water remains
check the drain connection where it connect to the sink these are bad to clog. In your case it may be a partial clog also check for any kinks in the drain line.make sure your line go above the connection point and then back down .This will stop water from flowing from the sink.
You can take apart the pump usually torx screws and remove any debris. Do this last
Dec 12, 2008 | Frigidaire FDB658RA Built-in Dishwasher
My lg intellowasher wd1290 error code OE
I think your "OE" is really a "DE" or drain error. Open the access door on the lower left of the front panel on the machine, drain the remaining water with the small drain hose there, and unscrew and remove the larger thing, which is a filter. Clean filter. If filter was not blocked, check for loose impeller on drain pump motor, which requires replacement of drain pump motor. (just sticking it back on will result in it coming off again)
If this helps, a "fixya" rating would be appreciated. Thanks.
Sep 21, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Hotpoint aquarius 1000 washer/dryer
cleared blockage from end of drain from machine.
Jul 27, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
