Rusty water -
Have 50 gallon Whirlpool gas heater. Rusty water only from hot water . called Whirlpool -they say I need to replace anode probably due to water softener. Heater is 5 years old. Is this worth doing? From comments i've read seems to be very difficult.
  • 334 Answers
With the right tools and elbow grease its not that big of a deal.
Most folks try tackling it with chanel locks and a pair of pliers. without the right tools, it can be a challenge.
You may have an hours work, and less than 30 bucks in the job.
A new heater will run you 350 bucks easy.
Posted on Jan 17, 2009
I have water in the junction box on top of my hot water heater and into the electrical conduit leading to the hot water heater.
I do not see your earlier post with photo.
The problem could be the conduit.....
-disconnect the conduit and wires from water heater
-run wire into a junction box set lower than top of water heater... -then run another #10 wire from the junction box up to water heater...
-So if water is coming from conduit, it will accumulate into junction box and not in the water heater wiring cavity.
Next thing....
... a water softener can cause rusted tank.
-Softened water adversely affects anode rod...
-causing anode rod to deplete faster...
-once anode rod is gone, then tank begins to rust.
-Here are details for checking anode rod each 2-3 years:
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/How-to-maintain-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Gene
Water Heater Timers Save Money
Mar 05, 2015 | Rheem 82v52-2 Tall Electric Water Heater...
Energy factor rating
Rheem 50 gallon Pro52-2 has EF .95, which makes it ordinary 240Volt 4500 watt non-simultaneous electric water heater that produces about 21 gallons hot water per hour, with 67 gallon first hour delivery.
Recommend 80 gallon per hour first hour for oversized bathtub.
http://bostonheatingsupply.com/Rheem/Rheem%20Residential%20Electric/Professional/Rheem_ResidentialElectric_Professional%20Spec%20Sheet.pdf
Maintain electric water heater and it will last indefinitely.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Anode rod is located on top in separate port.
Anode keeps tank from rusting.
Year of Rheem water heater manufacture shows 3rd and 4th digit of serial number.
Nov 25, 2012 | Water Heaters
Is the Whirlpool Electric Water Heater Model # EE3J50RD045V energy star rated
You want to know if this heater has Energy Star label.
I don't know.
Call Whirlpool 1-877-817-6750
Energy Star is a label that means nothing to you.
Manufacturers use energy-star label to promote a product as a money-saver.
They can put an Energy Star label on a giant 10,000 square foot house, and you know that cannot be the truth that a large house saves energy vrs a smaller house.
Energy factor, (energy factor/ not energy star) on the other hand, is a comparison measure how efficient the water heater uses energy to heat a gallon of water, when water heater is absolutely new.
EE3J50RD045V has energy factor of .59, which is completely typical and ordinary for electric water heaters.
The EE3j 50 gallon is an ordinary electric water heater, with ordinary average .59 energy factor rating, so electricity to operate this water heater is same as any other typical 50 gallon electric water heater: it will cost $35-45 a month depending on incoming water temperature, hot water use, thermostatic setting, electricity pricing, and whether you operate heater at peak pricing, etc.
http://waterheatertimer.org/How-much-does-it-cost-to-run-water-heater.html
The most important measure of water heater cost does not have anything to do with Energy-star or energy-factor.
The most important measure is total cost of owning and operating the water heater.
So if you spend $100 more to purchase electric water heater with slightly higher energy factor, then it will not pay you back. The difference will be $2 to $4 per year.
All costs are energy.
The total cost of operating water heater includes purchase price, installation cost, cost of repairs, cost of parts, whether you can fix it yourself, expected life of water heater, and replacement cost.
Every water heater has expected lifespan, and will not have resale value except current price of scrap.
Electric water heaters cost more to operate per month than same-size gas water heater.
Gas water heater might cost less over the life of water heater, but gas water heaters are increasingly expensive to repair, and increasingly more complicated, and cost more up-front to buy.
Electric water heaters cost less to buy, are easy to install yourself, are fully repairable by homeowner using generic off-the-shelf parts, and can be made to last many years by keeping tank clean and replacing anode rod every 2 years.
You can make ordinary 6-year electric water heater from box store last almost indefinitely.
Avoid electric water water heater that has electronic controls.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Sep 20, 2011 | Water Heaters
How do I check the anode on my bock 32E water heater? I have flushed the tank several times but the water is still brown and now the release valve drains the whole tank every few days.
1) Anode rod is located on top of water heater.
It is 1-1/6" hex head.
It might be under a plastic plug, or you might have to take off metal top of tank.
Sometimes you cannot remove anode rod because it is rusted too badly.
I have used impact wrench sometimes and been unable to budge them.
2) Open following links for anode illustrations and resources:
http://www.thisoldhouse.com/toh/video/0,,20047047,00.html
3) Rusty water implies that anode is bad.
But water released by TP valve implies overheating, or bad TP valve.
4) Replace TP valve.
http://waterheatertimer.org/How-to-replace-TP-valve.html
5) Check your burner and combustion parts for orange-or-yellow flame and sooting on parts that implies the water heater needs to be cleaned. You do not want overheated combustion chamber to cause ECO event that might require new gas control thermostat.
Gas should burn with clear blue flame.
6) Overheating tank can also imply that gas control valve thermostat is not working correctly and may soon fail. This would be evidenced if water is very hot and new TP valve doesn't stop hot water release.
7) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | RTO Bock Water Heaters 32E 32 gal 104,000...
Ariston GL6+ Occasional rusty water. Can this be remedied? Thank you Ed
Ariston GL6 6-gallon electric water heater has anode rod to prevent steel tank from rusting.
Once anode rod depletes, the tank rusts.
All tank-type water heaters have replaceable anode rod that can stop rusting, but will not repair damaged tank.
Open following links for resources + manual with parts number and illustration on page 7 and 10. Part number is shown as 570241 anode rod.
http://waterheatertimer.org/pdf/Bosch-GL_English.pdf
Jul 12, 2011 | Bosch Ariston GL6-plus GL6+ Point-of-Use...
I have 40 gallon Gas hot water heater. I need t replace the anode rod. I need to know the size
Normally, gas tanked water heaters do not have a an anode rod.It's not required. Only electric tanked water heaters do.
To help you to understand the workings of a gas tanked water heater, click on the following link.
http://homerepair.about.com/od/plumbingrepair/ss/hwh_tank_gas.htm
Apr 05, 2011 | Heating & Cooling
Where is anode rod located on 100 Gallon rheem water heater natural gas
Anode rods for tank-type water heaters are located on top of tank.
This is true since anodes are about 44" long.
Top of anode is standard 1-1/16" hex nut.
Anodes can be located in 2 different places: either directly screwed into top of tank -or- attached to hot water nipple.
Most times the exploded parts diagram in manual simply shows 'anode rod' without specifing exact location. If your tank has long warranty, then it can have two anode rods, and 1 will be on top and the other probably attached to hot water nipple, or there could be two anodes screwed into top of tank.
If anode is screwed into top of tank, then it will be under a plastic cap -or- it will be concealed under the top cover of tank.
Look for plastic cap, and if none shows, then remove screws holding down metal cover and look there for 1-1/16" hex nut.
Lastly, remove hot water nipple and check for anode located there.
If you have 2 anode rods, then replace with same metal for each.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 22, 2011 | Rheem Water Heater Anode Rod AP12938
Low boy water heater leaks at point where cold water pipe enters caseing.The leak is below the threads.The caseing is rusted at the point where the pipe goes through.Can this rusted place be patched or...
1) Your water heater needs to be replaced.
It cannot be repaired.
Tanks rust out after anode rod is depleted unless anode is inspected and replaced 1-3 years.
Water softener causes anode to deplete quicker, so inspect every 2 years.
Also stray household current can cause tank to rust out. Put bare copper ground wire between hot and cold pipes on new heater.
2) First thing is protect yourself from tank rupture where water heater bursts open and water runs until it's shut off. Ruptured tanks are big topic in homeowner insurance industry today because they cause major damage inside house.
- Turn off heat source so tank is not under pressure:
Gas: Rotate dial to pilot so pilot light stays lit, but burner does not turn on
Electric: turn off circuit breaker
- Turn off water going into tank using shut off above tank.
- Open hot side to bathtub to relieve pressure from tank.
- Check label on side of tank to get tank specifications for replacement.
3) What to do until replacement.
You can get by for a while on leaking tank by turning it ON only when needed.
Make sure tank is full of water before turning heat source back on.
This will buy time until replacement.
Electric tank heats 21 gallons water per hour.
Gas water heater 41 gallons per hour
Shower uses 6-9 gallons hot water, bath uses 12-15 gallon hot water.
4) Additional reading so next tank lasts longer
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Dec 05, 2010 | Water Heaters
New hot water heater cause smelly hot water.
U can clorinate ur water heater 1 gallon will do it. But you should try changing the anode rod(to aluminum) or removing it first followed by a complete drain, purge and refill.
Mar 29, 2010 | Water Heaters
Heating & Cooling Logo
141 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
