Question about Motorola Mobility H700 Wireless Headset
H700 not working properly
Hi, I've had my H700 for a few weeks and it's been working fine with my LG8300. However, first the headset is needing to be recharged far more often than 8 hours of talk. But today it stopped working. When I put the call button, I hear 2 beeps and then nothing happens. I read in the manual how to try again to "pair" it and that didn't fix it. My phone does show the bluetooth symbol as if it's working.
  • Gloie Wall Jul 09, 2007
    Thanks. I might try to do that although now I'm using an H850 instead and haven't had any problem. In fact I now think there was some other problem with the H700 since it needed to be re-charged very frequently. The only thing that might make me try what you suggest is I do like the smaller size of the H700 and also when you push it's call button you can feel it move.
I had the same problem with my Razor and the H700. I removed the device from the phone and reinstalled and that fixed the pairing probelm...Now I have another problem. I can hear the party I'm talking to just fine but no onee can hear me...this is my second Motorola ear piece and I've had the same problem twice...I think its a microphone problem...anyway, try to unistall and then reinstall the ear piece, that should fix your problem
Posted on Jul 09, 2007
SOURCE:
Bluetooth serial # 6809501a26-0 need
1.Switch on the bluetooth on your phone.
2.Open the headset boom to initiate easy pairing. After a few moments, the indicator light will be steadily lit in purple to indicate headset is in pairing mode..Motorola H700 will be detected.
3.Go to handsfree and select 'look for devices'. 4.Select Motorola H700.Select Yes to bond. Enter the passkey 0000 and select OK.
Thank You
Sep 01, 2010 | Motorola Mobility H700 Wireless Headset
I changed phones and do not have the passkey for H700?
Hi,the passkey for your h700 headset is "0000".this is the default passkey which will work for the pairing of your phone with the headset.
Thanks and take care
Apr 30, 2010 | Motorola Mobility H700 Wireless Headset
H700 - microphone not working or am I on mute?
Ok here is the answer. There H700 have a small foam windscreen inside over the microphone that over time block the sound. The answer is to carefully open the unit and remove the obstruction and clean residue from the microphone and it will work like new. here is a link to pictures and instructions. http://www.geocities.com/jconkwright/H700fix.html
Jul 23, 2008 | Motorola Mobility H700 Wireless Headset
Won't detect Motorola H700
Hi David, I want you to go to this link for your nokia E65. Click the link.
http://europe.nokia.com/link?cid=PLAIN_TEXT_119729
On the left side of the page click Demos
When the demo window opens click, Select Demos button.
Scroll through the list until you see Sending Via bluetooth.
Follow the interactive instruction to connect to your H700.
You'll need to set your H700 into pairing mode when searching for the bluetooth H700.
It might be a good idea to book mark the main page.
Good Luck! Take your time.
Mike
Apr 04, 2008 | Motorola Mobility H700 Wireless Headset
H700 charges fine, dies in an instant
Open it and see if it has a battery. Take the battery to RadioShack and have them get you the correct battery. Use contact cement glue to put it back together.
Mar 15, 2008 | Motorola Mobility H700 Wireless Headset
H700 is paired to phone and computer but will not connect
make sure your bluetooth function on your cell phone is on then if this doesnt work delete this device from your phone an reinstall it
Jan 11, 2008 | Motorola Mobility H700 Wireless Headset
H700 Loosing Charge Quickly
I think the normal talk time is around 6 to 8 hrs if your battery is holding less you probably have a unit with a faulty battery
how old is your headset
Jan 05, 2008 | Motorola Mobility H700 Wireless Headset
H700 will not charge
Replace the ac adapter (charger) with a new one
Jan 02, 2008 | Motorola Mobility H700 Wireless Headset
Motorola H700 Problems with BB Pearl 8100
Steps to pair a H700 headset with any bleutooth pone:
  1. Make sure the H700 fully chared (very important)!!
  2. Make sure the microphone boom is folded closed, i.e. power is off!
  3. Hold the call button for 1-5 seconds until the light is steady lit purple
  4. Flip out the microphone boom, the light should stay lit purple!
Now you are ready to pair the headset with your phone, so follow the pairing instructions of your phone.
Note: When prompted for the Passkey; it is most likely 0000 but the correct Passkey should be on the headset accessory instructions.
I must add that indeed my headset on occation (once or twice every three months) also loses its connection with the blackberry (a 8703e) . At which time I have to remove the headset from my phone bluetooth device list, and start the above described steps to pair my headset with the phone again.
Jun 02, 2007 | Motorola Mobility H700 Wireless Headset
Help needed in paring my H700
In order to pair with this device you must follow these steps: 1. Close the mike on the H700 2. Hold the center call button on the H700 until the ring in the center turns violet. 3. Open the mike on the H700 4. Have your phone search for bluetooth devices and follow the propmts 5. If your phone requests a passkey, enter 0000 This is the default for all Motorola devices Hope this helps.
Apr 01, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
289 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
