Question about Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700 can't power up 2nd time in car
Hello, My Magellan Roadmate 700 can't power up. When I powered it up in my car, it worked just fine. When I turned it off and later turned it on, I received a gray/white screen and nothing happen. I had to take it into my home and plug it into an outlet to power it up. Every time I used it in the car with the cigarrette light, it only worked once and then died again... By the way, how do I reload my GPS software? I have the data in the 20-gb internal hard drive. Thanks.
    Problem Solver:
  • 6 Answers
Many people are having problem powering up the 700 Magellan Roadmate has BAD cradles by design. I would try a new cradle first. can be found for just under $30.usd online.
Posted on Sep 29, 2007
    Problem Solver:
  • 5 Answers
Are you willing to part with it, I may be able to use it for parts denisdsouza@hotmail.com
Posted on Aug 22, 2007
SOURCE:
Magellan RoadMate 700 GPS does not work properly
It seems that Magellan is not good with the power connectors on their units, I believe the problem is with the power adapter plugged into the cradle. Sorry I have no information about a repair center. Usually for an absorbent amount of money, Magellan will repair.
Dec 23, 2008 | Magellan RoadMate 700 GPS Receiver
Magellan roadmate 700
go to the magellan website and all your answers are there.
Sep 13, 2008 | Magellan RoadMate 700 GPS Receiver
All navigation units are GPS Receivers - that is - they receive satellite signals. So, no there is no difference.
Apr 19, 2008 | Magellan RoadMate 700 GPS Receiver
Power wont come on
get a new unit like any magellan mastreo series 4000 or higher or roadmate 800 or higher,i had a 700 they start having alot of problems after i did my research on here.i have the mastreo 4000 and the roadmate 800 both work great.
Feb 23, 2008 | Magellan RoadMate 700 GPS Receiver
Road mate 700
The flash card hole is supposed to be empty - all you need should be on the hard disk BUT the first Roadmate 700 I purchased was empty i.e. no software loaded. The second failed due to bad power connection, the third worked but was factory refurbished! what a crass organisation Magellan is!!!
Try fiddling with the power connection that goes into the cradle that the unit sits on. The power connection is ultra sensitive. BUT, if you've only just bought the unit then you are in luck - return it and get your money - back Magellan Support is extremely poor.
I am binning my Roadmate and getting a Tomtom720 Go series with maps and cameras preloaded - it auto updates when it is on its cradle attached to my PC/internet.
Bin the Magella - 4 years of problems!!!!
Oct 24, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700 does not power on
Hello, Rafster! Cigarette lighter plug problems are not uncommon, and - hopefully - this is the source of your problem. Because the green LED on your plug is lit, it would suggest that the FUSE inside is okay. Still, it's worth checking! The plug is easy to open, and the fuse easy to inspect/replace. IF the fuse is okay, the cord itself or the plug end that attaches to your Roadmate could be damaged. In order to determine this, you would have to check for voltage at the output end. But, you'd need a circuit tester and a wee bit of electronics knowledge to test it. If you don't have access to a tester, then the easiest test is to simply purchase a NEW cigarette lighter cord. You can get them at most retail discount stores (BestBuy; Circuit City; WalMart; etc.); RadioShack; or directly from Magellan. They're generally less than $10.00!
Jul 20, 2007 | Magellan RoadMate 700 GPS Receiver
Yes, get a new car connector. -Daniel
Apr 23, 2007 | Magellan RoadMate 700 GPS Receiver
Doesnt stay powered-up
Small IC chip on the back of your I/O board is losing connection. Look at my posts to other users with the same type problem. -Daniel
Mar 31, 2007 | Magellan RoadMate 700 GPS Receiver
I know there's the Magellan Repair Center in Fort Worth,TX. That would be the place to send it to if your wanting to use them. Other then them, I might have a chance at fixing it.
Apr 12, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
180 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Damen Wong
Damen Wong
Are you a Magellan GPS Expert? Answer questions, earn points and help others
