Dell OPTIPLEX 745 PC Desktop Logo
Anonymous Posted on Dec 26, 2012
When i press control f11 to restore my computer it does'nt respond do anybody have any other option for me?
Justin
Level 3:
  • Dell Master 2,072 Answers
  • Posted on Dec 26, 2012
Justin
Dell Master
Level 3:
Answers
2072
Questions
0
Helped
431662
Points
5629
Did this computer come with a recovery disc(s) or is F11 your only option for recovery?
If you didn't get a disc then you probably have a recovery partition on your hard drive. If this is the case there is a good chance your hard drive is failing or has failed. This would also wreck your recovery partition. Your best bet would be to replace the hard drive and order a recovery disc set from Dell. They cost anywhere from $15-40 and you can order them on their site or call them.
4 Related Answers
Anonymous
  • 3 Answers
  • Posted on Dec 29, 2009
SOURCE: dell computer system restore control F11
Dells do not have the 'control' F11 function to recover the OS, you need to boot it from a 'recovery CD', if you do not have one, go to dell.com and you can ask for a copy, they will ask you for the service tag of your computer (have it handly).
muntejaya
Muntejaya Ginting
  • 10422 Answers
  • Posted on Feb 08, 2011
SOURCE: My Dell Dimension C521 running Windows XP with
Kindly download the sound driver here : www.nodevice.com/driver/company/Dell/SOUND.html www.notebook.driversdown.com/notebook-drivers/r_1_1.shtml
Regards
General Systems Consulting
  • 5051 Answers
  • Posted on May 28, 2012
SOURCE: when I press F8 key and it's not giving a option to restore my computer
No bootable device means the system cannot boot from where ever you are trying to boot. If you have something in the CD Drive other than a Repair Disc or Operating System Disc remove it.
Try booting from your hard drive. Turn off the computer then turn it back on and watch the screen for which key it says to hit to Change the Boot Sequence or Boot Order. Hit that key when you see the message or you will have to start over. Select the Hard Drive as your boot device. If you get a message about an unbootable device then you will need to run the Check Disk Utility. If it boots, then you will need to make a permanent change to the Boot Sequence or Boot Order.
To make a permanent change turn the computer off, then turn it back on and watch the screen for which key it says to hit to get into the Bios or System Setup. When you see the message, hit the key otherwise you will have to reboot and start over. When the Bios or System Setup window opens tab over and Change the Boot Order or Boot Sequence and save your changes.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Anonymous
  • 240 Answers
  • Posted on Aug 23, 2012
SOURCE: how to restore dell dimension 3000 to factory settings
ck its settings
How do i do a factory restore on a model Ne71b
all you need do is perform a "cold boot" and immediately begin tapping the F8 key until the computer responds. Once you get to the next screen simply select the repair option. from that point it is intuitive to getter done.
another method is to press Alt+F11 when booting the unit, then choose factory restore.
Reboot to factory settings for Dell
Try This:
If your operating system is XP, press the CTRL and F11 keys simultaneously when you see the Dell logo after turning on the laptop, and follow the instructions on the screen.
  • Put the computer on.
  • When the Dell screen appears, press and hold the CTRL and F11 key simultaneously on the keyboard, then release them both at the same time. The Dell PC Restore by Symantec window appears.
  • Click the Restore button or press the key to highlight Restore and press the key.
A caution message appears, advising that all data will be lost.
  • Click the Confirm button, or press the key to highlight Confirm and press the key.
The Progress window appears. Once the process has begun, Dell PC the restore usually takes only 8 to 10 minutes to complete. When the restore is complete, the message 'The system recovery process was successful' appears.
  • Click the Finish button or press the key to highlight Finish and press the key.
The computer will restart.
For Vista or Win 7
If your operating system is VISTA / Win 7, press the F8 key when you see the Dell logo. It will take you to the advanced boot menu options, which include 'Repair your Computer'. Select that option and enter your password if asked, then you will see a list of options like 'system restore' and 'command prompt'. The last option says 'Dell PC restore', or something along those lines. Select that option and follow the instructions on the screen.
If in both cases, the Factory default doesn't work, then your laptop's factory image defaults partition has vanished (i.e., been corrupted / deleted). In this case you will have to reinstall the operating system with the CD or DVD shipped along with the laptop. Follow the link below to install windows XP Pro on your own.
  • Start the computer.
  • As the computer starts, press the F8 key until the Advanced Boot Options menu appears on the screen.
  • Press the down arrow to select Repair Your Computer on the Advanced Boot Options menu, then press Enter.
  • Specify the language settings that you want, and then click Next.
  • Log in as a user who has administrative credentials, and then click OK.
  • Click Dell Factory Image Restore.
  • In the Dell Factory Image Restore window, click Next.
  • Click to select the check box for Yes, reformat hard drive and restore system software to factory condition.
  • Click Next. The computer is restored to the default factory configuration.
  • When the restore operation is completed, click Finish to restart the computer.
In both cases, if the factory default does not work, then your laptop's factory image defaults partition has vanished (i.e. been corrupted / deleted). In this case you will have to reinstall the operating system with the CD or DVD shipped along with the laptop. Follow the below link to install windows XP Pro on your own.
Good Luck!
Factory reset on my laptop
Dell system includes a restore utility called 'Dell Symantec System Restore' to reset or restore your Dell system to factory setting. This utility is convenient because you're not forced to use the Windows startup CD to restore your computer.
Step 1: First backup all your important data and restart your computer.
Step 2: Press 'F8' if you are using Win7/Vista or 'Ctrl + F11' if you has Win Xp. 'Advanced Boot Option' menu options will be opened.
Step 3: Choose 'Repair your computer' from the 'Advanced Boot Options' from the menu and press 'Enter'.
Step 4: Select language setting and press 'Enter'. Now Login window will be appeared.
Step 5: Now login as administrator to continue the factory reset process.
Step 6: Click 'Dell Factory Image Restore' followed by the 'Next' button.
Step 7: Choose the check box marked 'Yes, reformat disk drive and recover system software to manufacturer condition'. Once the check box is chosen, simply select the 'Next' button and your Dell computer/laptop is renewed to factory setting.
Step 8: Press 'Finish' once it has been done. ...
This process will erase all your previous changes that have been made to the Dell computer and reset the configuration settings to factory setting.
Feel free to get technical assistance anytime at http://www.vtechsquad.com/dell-support/
Windows xp hard reset
This is what you manual said to do, unfortunately most times the Recovery does not work. I prefer a clean install over recover because I don't get all the unwanted programs.
Instructions from Manual below:
Turn off the computer. If necessary, press and hold
the On button until the computer turns off.
2 Disconnect all peripheral devices from the
computer, except the monitor, keyboard, and
mouse.
3 Press the On button to turn on the computer.
4 Immediately, when you see the initial company
logo screen appear, press the F11 key on your
keyboard repeatedly until the Recovery Manager
window appears.
5 Click Advanced options.
6 In the Advanced options window, click System
recovery, and then Next.
7 Click No to back up files (if you have already
done so), and then click Next.
System recovery begins. After system recovery is
complete, the computer restarts.
Have you tried doing a System Restore to a restore point (date and time) before you started having problems?
A clean fresh install of windows might be your only and best option.
2answers
How do i restore to factory settings my Dell Vostro 1000
Try here...(http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=gen&docid=DSN_336966&isLegacy=true#Issue3).........or here........(http://www.techsupportforum.com/forums/f108/solved-dell-vostro-1000-restore-from-recovery-partition-issue-445057.html)
3helpful
3answers
HOW TO RESTORE A DELL INSPIRON 1100 WITHOUT A DISC
Resetting a Dell Inspiron 1100 laptop to the factory settings allows the user to restore the Dell Inspiron to the original operating condition as if it was just taken out of the box. Dell system includes a restore utility called 'Dell Symantec System Restore' to reset or restore your Dell system to factory setting.
Step 1: Before reset any Dell Inspiron 1100 laptop, backup your all important data and programs, otherwise you may lose it. It is recommended to use an external storage device for your entire data backup, so that you couldn't lose it in any sudden occurring issue...
Step 2: Remove any other unnecessary external drive and restart your Dell Inspiron laptop.
Step 3: Press 'F8' key continue until 'Advanced Boot Options' wouldn't be appear.
Step 4: Use your keyboard arrow key to select 'Repair Your Computer' from the list and hit 'Enter'.
Step 5: Now click 'Next' and login as the administrator account.
Step 6: Click 'Dell Factory Image Recovery and Data Safe options', select your language option and click 'Next'.
Step 7: Click the check box 'Yes, reformat hard drive and restore system software to factory condition' and click 'Next' to start Dell Inspiron reset process...
This process will erase all your previous changes that have been made to the Dell Inspiron laptop and reset the configuration settings to factory setting.
Feel free to get technical assistance for all models of Dell Inspiron 1100 laptop at
1helpful
4answers
Dell laptop inspiron 1000
Put recovery disk in the CD drive. On reboot, hold down F12 key. You should get a choice of drives to boot from. Make sure the first two are in the correct order:
1. CD-ROM (optical drive)
2. HDD (hard drive)
then press F10 to save and exit.
Now the laptop should boot correctly from the recovery disk.
37helpful
6answers
I want to restore my DELL LAPTOP to the factory settings?
Okay, do as follows.
(a) Boot the computer. When you see a blue bar with www.dell.com on the screen, hit Ctrl + F11.
(b) On the next screen, click "Restore".
(c) Next, click "Confirm".
(d) Let the restore process run. It will probably take 10-ish minutes. Don't touch it while it's doing it's thing.
(e) When prompted, click "Finish" to reboot the computer.
(f) When prompted, click "Yes".
(g) When prompted, click "Next".
(h) After the computer restarts, click "OK".
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
