Question about Reddy Heater-30-55,000 BTU Variable
Have a reddy htr pro110 need to know how to adjust fuel & air
Have a htr runs but alot of fumes has two adjustmets on back
THANKS
  • rickslbow Jan 17, 2009
    Hy muttandjeff the reddy htr I have is kerosene torpedo changed plug blew out all lines adjusted the fuel nozzle so it hits dead center of the spark but dont have a clue where the two adjustment screws should be set Wen i first fire up hearter the cloud ofsmoke looks like a large fog then trips circuit breaker reset and sometime it will run great for a while then shuts off
  • Allen Neal
    Allen Neal May 11, 2010
    OIL OR PROPANE
  • 92 Answers
Sounds like the CAD flame sensor.
Posted on Jan 23, 2009
Reddy heater 170T- terrible fumes-fuel pressure problem
Are you sure there is not water in the tank? Fuel pressure should almost never need adjusted.
Jan 08, 2014 | Reddy Heating & Cooling
I have a Reddy Htr Mod 60D kerosene-diesel heater. I need to know how to fine tune the air fuel adjusting screws on the back right by the air intake filter, and which one is fuel and air. The heater...
You only adjust the one with the hole in the center. The other one is where you install an air pressure guage (0-15psi). The pressure setting is listed on the label of the heater (somewhere between 3-6 psi depending on the heater. All this is doing is controlling the air pressure/flow to the eductor that draws fuel out of the tank. Let me know if your label is wore off and don't forget to rate the answer and leave testimonial.
Jan 02, 2011 | Reddy Heater Tools 60,000 Btu Portable...
Can i run diesel fuel in my m50a reddy heater
Yes you can run Diesel in this heater but you will have to turn the pressure up on the back of the pump.
You want the nose cone to be a good glowing orange and with Diesel you may need more air pressure to achieve the proper burning of the heater with the least amount of fumes.
Thanks
M Cramer
www.allpartsinc.com
Jan 01, 2011 | Reddy Heater-30-55,000 BTU Variable
I have a Reddy Heater Pro110. It runs for 3 or 4 sec then shuts off. What can I do to fix it?
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
0\0\0\0\0\0\0\0\0\0\0\0\0\
Dec 23, 2010 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater Kerosene 50,000 BTU produces TOO
There are2- adjustment screws on the back 1--air---#2-fuel. adjust it while running for the perfect combination for the fuel/ air ratio.!
Dec 21, 2009 | Heating & Cooling
Handy Master Fumes so Bad your Eyes can"t take the smell
It sounds like it's not getting enough air to fuel mix, check your lines.
Jan 22, 2009 | Reddy Heater-30-55,000 BTU Variable
Master Reddy 30,000 btu heater put out nasty fumes.
Sounds like it's not getting enough air to fuel mix, check your air inlet line for breaks or just put a new one on for a couple bucks. any fuel line thats the right diameter will work, got mine from auto zone.
Jan 21, 2009 | Reddy R155D Utility Heater
Fumes
One of two things, a high heat limit control or the flame sensor, also check your air line that runs to the heater nozzle could be cracked, not enoughair to fuel mix will make it burn dirty.
Dec 14, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
I have just purchase a kerosene fan force (reddy) space heater ,we use it in a very drafty garage,but the strong smell of kerosene fumes are more then we can stand.we have tried scent additives but nothing...
Try running it outside where the oxygen level is 21%. Carbon Monoxide will kill you The smell might be the product if incomplete combustion CARBON MONOXIDE, or the fuel line pressure needs to be adjusted.
If you still get the smell the unit may defective. If you want to try adjusting the fuel line pressure, you will need a low pressure gauge 0-15 psi.remove a plug from the heater and set the pressure at the documented pressure, the other plug with the hole in it is the adjustment.
Dec 05, 2008 | Reddy Heater RLP100 Portable Forced Air...
Reddy Heater-30-55,000 BTU Variable Logo
80 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
