Most top loader machines have some sort of fastener in the center at the top of the agitator. You should look right at it when you open the lid. Once you figure out how you remove the fastener, the agitator should pull straight up. It is usually connected by a spline. You may have to pull pretty hard if it has never been apart. Once the agitator pulls out, you should be able to see the debris you are looking for.
I am not familiar with your exact machine, but yours should be similar. Hope this helps.
I have inherited a Hoover Nextra HNF6147 with no operating instructions. Need to know which setting...
(More)
I have inherited a Hoover Nextra HNF6147 with no operating instructions. Need to know which setting in best for my requirements. Thank you, Donna
i have a Hoover washing machine heavy duty 10.1 kg Giant Capacity Plus with same problem, cold water...
(More)
i have a Hoover washing machine heavy duty 10.1 kg Giant Capacity Plus with same problem, cold water doesn flow but warm water yes. Please help
The springs on the drum doors have now both gone. It has been difficult to open for a while. Now I...
(More)
The springs on the drum doors have now both gone. It has been difficult to open for a while. Now I can't close it as if I press the grey knob the door just presses into the drum. I think both springs need to be replaced. How do I replace the springs and what are the part numbers. Thank you, Gill from Scotland.
When you pull out the programme selector knob at the start of the cycle you hear a humming noise but...
(More)
When you pull out the programme selector knob at the start of the cycle you hear a humming noise but no water flows into the machine.This is the same for all three programme options.When the selector is turned to the spin cycle and knob is pulled out motor does spin
