Question about Maytag Performa PAV2200
Noisy washing machine
I have a maytag performa model#pavt454eww washing machine. it works through the whole cycle, but during the wash cycle it makes a squeeking noise. i do not know if it is a belt drive or gear drive. i do not know if it is a seal gone bad or bushing gone bad. the drum has slack from side to side. help if you can. thanks.
  • Anonymous Apr 12, 2008
    My Maytag Performa washing machine also tends to whistle... but only in the wash cycle. It's pretty loud and annoying because I timer-set our laundry for 3 AM! Other than that the baby runs perfectly.
  • 02 2b fishin Aug 02, 2008
    My Maytag Performa washer model PAVT454EWW ser# 23335475GL has started making a horrible loud noise. The noise is coming from the pulley near the water pump and sounds like something metal is caught behind the pulley next to the water pump. I don't know if the pulley has gone bad or some sort of spacer maybe. I'm not sure all the names of the parts. I read something about the series 22 having noise problems and was wondering if that might be my problem. If so what do I need to do?
    Thank You!!!!
  • 183 Answers
Side ways movement is normal, possible dry bearing seal, try running through on hottest wash, this should resolve the problem. Regards Engineer
Posted on Jul 30, 2007
SOURCE:
Maytag performa washer noise
sounds like the bearing on the drum is noisy or you have some small change between the drum and the casing
Apr 27, 2012 | Maytag Washing Machines
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag performa washer during spin cycle tub is making loud banging noise and continues even when clothes are evenly distributed
This sounds like the transmission is going. Better get another washing machine other than a Performa.
Jan 03, 2010 | Maytag Washing Machines
IUs very loud during spin cycle and you would
It appears Maytag no longer produces the type of quality product we have purchased since 1970... we've owned three Maytag Washers - our last "performa" is a piece of ****!
Dec 23, 2009 | Maytag Performa PAV2200
Maytag PAVT454EWW pump 21002240
Don't worry about it, you can install the new pump with out the plate. It will work just fine. They must of redesigned it. I get them this way all the time, Catriver
Sep 22, 2008 | Maytag Performa PAV2200
Washer noise during spin cycle
remove the belt and spin the motor by hand to see if its noisy then the pump.if its the gearbox you would be better to replace the machine,i havent seen to many last more than 5 years the gear box could cost about 500.hope this helps.
Mar 26, 2008 | Washing Machines
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
Washing Machines Logo
291 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
