Question about Zyxel P660HW-D1 Router
I need to secure my Zyxel wireless connection
Connected pc via ethernet cable then went to 192.168.1.1.in IE deleted dots in password box and entered 1234. Clicked continue and ignore on next page. Then found menu on left. Followed my sp tech support tecnician and was able to connect
Posted on Jan 17, 2009
I cannot access the internet on laptop it shows I am connected to the router but won't connect to the internet. I was told I may need to Upgrade the firmware but the sight is down, how can I do this?.
I suspect the issue is not the firmware- check the security settings you have for your wireless network. If you are using Windows Vista/7, it would be through Network > Network and Sharing Center > Manage Wireless Connections > right click on the appropriate connection, go to properties and look for security. Check with a wired pc what the settings are in your Zyxel- match, and you should be able to connect wirelessly
Dec 26, 2010 | Zyxel Prestige P-330W Wireless Router...
I dont know ho to change the password on the PK5000Z Wireless Router
I just set up my new ZyXEL PK500Z, so happen to know this answer. In the ZyXEL Qwest Modem Configuration (launch 192.168.0.1), select Wireless Setup, then Wireless Security. Scroll down to Enter Security Key/Passphrase. Unless you changed this, Use Default is selected. If you want to use a password of your own creation, select Use Custom, then enter the password you want. Finish with Apply. Everything connected to your network will be prompted to re-enter the password. Is this what you were after?
Dec 25, 2010 | Zyxel (91-004-361002) Wireless Router
My Zyxel modem is working with a cable but the wireless is not - just fixed the hardline with the operator but wire still out
You have to go into the menu of the router and activate the wireless, and then have it open while you are connecting wireless and with some "default" name, if that works you should change the security and use the WEB key part to secure your wireless.
Nov 14, 2010 | Zyxel (91-004-361002) Wireless Router
NBG-419N can not connect to the internet thru router?
Have you connected your Zyxel to your cable/DSL modem? Is your access problem issue with Wireless computers? The first thing you must do with a new router is to set it up, using a CAT-5 cable connected to the router. Connect it to http://192.168.1.1 and proceed through the setup items, after logging in to the router. One of the more important items, Security, must be set up by choosing your network name (SSID) and security passwords --- I prefer using the WEP-PSK[TKIP] for its simplicity. You will need the passcode you choose whemn you try to access the router wirelessly, once this is set up. Not too much access unless this is done. Use this as a guide:
http://www.zyxel.com/guidemo/NBG419N/local/networkmap.html
Nov 10, 2009 | Zyxel NBG-415N Router
HELP!!!!!! Trying to enable wpa-psk security on my laptop?
You should set the security on your computer wifi card to wpa-psk and then type in the securitycode which is written in your Zyxel Router.
If this is not possible with your networkcard, change to wpa or wpa2 inside the Zyxel. And do the same procedure with your networkcard, when detected the Router.
May 04, 2009 | Zyxel P660HW-D1 Router
I have a Zyxel 660HW modem/router - I can't access wireless
switch it on, it will search for wireless accespoint in ur network. connect to it and given security passphrase and then ut will connect permantently.
Apr 24, 2009 | Zyxel P660HW-D1 Router
How can I secure my zyxel Router P-330W at home?
hi...
you need to go to the computer which is connected wired to the zyxel box,in the computer click on start,run,type in cmd,and hit enter,on that black box type in ipconfig,hit enter,you wil get a list of result check default gateway(eg of default gateway is 192.168.0.1)go to internet explorer page,in the address box type in the default gateway without http or www,it will open the zyxel page for you,it might prompt you to put in the user name and the password,if it does then donot put anythingin the name of username and put 1234 as password,in this page you will see an option that says wireless,click on wireless and then click on advanced,under you will see the wireless security option where you can go ahead and make you wireless connection secured.
http://us.zyxel.com/upload/download_library/P330W_UG_V_1%201(5).pdf..this is a link for user guide u can download this to udnerstand other features that there in you router..
vedhick
Feb 26, 2009 | Zyxel P660HW-D1 Router
Can't connect my Ipod touch to my router?
You must be sure to what router you are trying to connect. I understand you have a ZyXel and a linksys. You must have 2 wireless networks. Your wireless network must be secured, so you just have to use the correct password. I need more details. Try this http://technicalsupport.blog.friendster.com
Feb 08, 2009 | Linksys Wireless-G WRT54G Router
Modem router
I can tell that your network topology is not the most complicated ever.So u ve got 3 terminals,1 desktop pc and 2 laptop.Simple,reset your zyxel(from the button on the back) and reconfigure the Local area interface connection(ip & subnet mask for the zyxel),reconfigure your internet connection,(WAN zyxel interface) in case the zyxel is your Internet gateway too.Third,make sure NAT & Firewall are up and running(usually are by default) Finally,reconfigure the WiFi interface with the correct SSID name & WEP key or whatever security you prefer.Write down the security pass for your wireless and you are done.Good Luck.
Apr 19, 2008 | Zyxel Prestige 660H Router
Installing wireless router
um is it compatible with vista and/or upgradable?
Jan 15, 2008 | Zyxel Prestige P-330W Wireless Router...
Zyxel P660HW-D1 Router Logo
76 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
